#1 |
Member#: 54203
NESIC
Vehicle:2011 WRX |
This started just yesterday...I have an 04 wrx, with about 92k on it. The noise sounds like a whining that increases in pitch as the engine RPM's increase. My first guess is that the A/C clutch is broken (as pushing the a/c button no longer causes a change in engine vacuum). Anyone ever have this problem?
#2 |
Member#: 160154
Thats the turbo..
(lol) Check all IC hoses / pipes / couplers? |
#3 |
Member#: 54203
NESIC
Vehicle:2011 WRX |
it's not the turbo, i'm not that much of a noob. it is almost certainly the A/C compressor. it sounds like supercharger whine. I was just wondering if anyone knows if the clutch is separate or the thing is sold as whole unit.
#4 |
Member#: 160154
Haha, I know. I was just playing.
#5 |
Member#: 152261
SCIC
Vehicle:2007 WRX 2.5 Crystal Gray Metallic |
whining similar to your car in reverse?
#6 |
Member#: 54203
NESIC
Vehicle:2011 WRX |
update: i just removed the belt to the a/c compressor and the sound is gone.
#7 |
Member#: 147306
Hey, I just got the same exact sound, and I pinned it down to the AC compressor Clutch, however I haven't taken it apart to find the problem, does anyone know how to take the Compressor Clutch assembly apart?
#8 |
Member#: 33868
Vehicle:2003 wrx srp |
How about that $35 pulley (AC tensioner)? Mine made that noise before I changed it.
Put a screwdriver on the bolt and the other end to your ear and it sounded rough. |
#9 |
Member#: 147306
No, it's not that, I put WD-40 on the AC clutch and the sound started to stop except at high RPM, it doesn't do it on startup anymore, but at around 3000 rpm it starts to sound like a supercharger. Thus, I'm almost positive it's the compressor clutch, do you know how to get lube down to the clutch bearing?
#10 |
Member#: 33868
Does it sound like the you tube recording in this?
http://forums.nasioc.com/forums/show....php?t=1487622 |
#11 |
Member#: 147306
That was very helpful, thanks. I'll probably try to pull the AC belt and see if the noise stops
#12 |
Member#: 54203
NESIC
Vehicle:2011 WRX |
UPDATE: Swapped out the pulley, belt, etc, today, and the sound is gone and the a/c functions perfectly. So for anyone whose wrx sounds like it's superchargd: one of your pulleys went!
#13 |
Member#: 2133
Vehicle:2005 STi WRB/Gold 2005 S4 Avant |
Thanks for the update. I am experiencing a similar whining noise that tracks with engine RPM in my '05 STi. I was hoping it was the idler pulley for the A/C belt. Took the belts off yesterday and drove around with the A/C belt off and the whining noise is still there.
![]() So it appears that it's coming from either my alternator or power-steering pump. I can't determine which is making the noise so I'm not sure what I'm going to do at this point. I may just live with it until it gets worse and is easier to pinpoint. *sigh* |
#14 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
use a stethoscope, i.e. - a long screwdriver held to your ear. That helps pinpoint noises.
#15 |
Member#: 2133
#16 |
Member#: 12344
Vehicle:2002 2JC blue |
A stethoscope for about $10 can be used in more locations than a screwdriver.
There is a rubber hose that separates the probe from the head set ear phones. You can touch the probe it to a lot of other places where your head and the screw driver won't fit. The sound is amplified a lot when you put it on the source. For example near a bad alternator bearing. |
| Thread Tools | |
| Display Modes | |
| Top jokes about Subaru that is made by the wifey or girl friend??? | fastblueufo | South East Region Forum | 75 | 03-03-2010 09:41 AM |
| A car that is powered by air. | Brad Pittiful | Off-Topic | 19 | 03-17-2008 09:18 AM |
| my car developed a whining noise (it is RPM dependent) | dubya-R-ex | Factory 2.0L Turbo Powertrain | 2 | 10-16-2007 05:06 PM |
| Another question -- Whining noises from engine at low rpm = good/bad? | cerelius | Newbies & FAQs | 31 | 06-09-2005 03:00 PM |
| Am i the only one that is bothered by this? | HighWayDrifter | Off-Topic | 5 | 07-30-2004 01:11 AM |
