Old 01-05-2009, 01:35 PM   #1
jddelrosso
Member#: 171832
Default CEL P0420 - Catalyst efficience low-bank 1
Hey guys,
I have a 2002 WRX. I have just replaced the Front and Rear O2 sensor because of this CEL code P0420. I am stumped. It stayed off for 1000 miles after replacing the front 02 sensor and it is back now. I have noticed a drop in Fuel Efficiency too. I was getting 29mpg now only 23mpg. I have talked to multiple Subaru dealers. They didn't give me a straight answer. One said front cat, one said rear cat. PLEASE help. Any insight would be greatly appreciated.
~thanks,
Aaron
jddelrosso is offline   Reply With Quote
Old 01-05-2009, 02:32 PM   #2
mikeythejew
Member#: 141672
PO420 is a code that often requires an expensive fix. What you should do is inspect the cats for breaking apart & or being clogged. Not a fun task for sure. Does your car consume any oil?
mikeythejew is offline   Reply With Quote
Old 01-05-2009, 02:49 PM   #3
mikeythejew
Member#: 141672
Link shows an example of a failing cat. http://www.2carpros.com/how_does_it_work/images/catalyst_material.jpg
Whats scary is that on some cars, if the cat(s) go out, it can ruin the engine. Some engine desings that eliminated the use of an EGR valve have the valve overlap set as that it creates reversion. When a cat goes out, it sucks the fine paricles into the engine, wearing out the cylinder walls. Nissan QR25DE engines in altimas, the 02' up SER and the toyota MR2 spyder are known for thisw problem.
Old 01-05-2009, 02:59 PM   #4
jddelrosso
Member#: 171832
The car doesn't consume any oil, which would eliminate the threat of oil leakage into exhauset valve guide seals or piston rings.
Old 01-05-2009, 03:35 PM   #5
mikeythejew
Member#: 141672
Cat(s) could still be shot. I think there may be a low incidence of 2.0L WRX precat failures if you search. I absolutely would not drive this car until it is fixed.
Old 01-05-2009, 06:01 PM   #6
jddelrosso
Member#: 171832
Thanks for the help. Every little bit counts. I am going to do more and more research and try to fix this issue the cheapest way possible. Luckily, I do all the work myself and don't have to pay for labor.
Thanks again
Old 01-06-2009, 12:56 PM   #7
Davidwrx
Member#: 141028
2002 WRX Wagon
If you end up having to replace the cats, you can usually get a stock downpipe (has 2nd and 3rd in it) used cheap here. Maybe $100. Shipping will be a bit high as they are usually heavy. Check model years, but I think any 02-05 will work. I think in 06 they changed lengths of some of the pieces.
There is plenty of guidance on how to change the downpipe.
Davidwrx is offline   Reply With Quote
Old 01-24-2009, 02:03 PM   #8
D.C.W.J.
Member#: 153334
2006 STI
SGM
I have a friend of mine who says her wrx is throwing this code now. The question i have is it normally just the cats in the downpipe that are going bad or would we need to replace her uppipe as well?
D.C.W.J. is offline   Reply With Quote
Old 01-24-2009, 02:15 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
The only cat montitored is the one between the Front AF sensor and the Rear Oxygen sensor, the ECM has no idea if the upipe cat or rear cat is efficient because it does not monitor them.
BNIB exedy stage 1 clutch 15804 $335 picked up Wannascooby SCIC Private Classifieds 19 07-15-2010 04:18 PM
help!!! flashing cel and no one can help tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-05-2010 07:26 PM
valentine 1 - needs to b fixed ? AMOS GT Car Audio, Video & Security 3 06-04-2010 03:31 PM
HELP!! flashing cel tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-04-2010 01:38 PM
FS : Innovate LC-1 Wideband with XD-Gauge alcoolaid VIC Private Classifieds 0 06-04-2010 04:12 AM
