Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 01-05-2009, 10:18 PM   #1
jaimebenlasnow
Member#: 188065
Default EJ20G tuning
Hi guys,
Just want to know where i can get tuned without going stand alone.
jaimebenlasnow is offline   Reply With Quote
Old 01-05-2009, 10:48 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
you can't.
Old 01-06-2009, 12:03 AM   #3
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
i say get a $1000 apexi PFC for the ej20g, or get something niceee.
gc8awdsti is offline   Reply With Quote
Old 01-07-2009, 09:49 PM   #4
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Keep your eyes on the classifieds as I'm contemplating selling my NIB PowerFC, Datalogit and PowerFC BC and going to a different EM.
beaviscih is online now   Reply With Quote
Old 01-07-2009, 11:12 PM   #5
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
let me know when^
Old 01-08-2009, 03:31 AM   #6
jaimebenlasnow
Member#: 188065
Default !
I just need to know if i was ok and what type of power will i do with
EJ20G
evo 3 16G
Stock injector
Stock ecu
94 octane
Ebay FMIC
Old 01-08-2009, 03:55 AM   #7
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
EJ20G
evo 3 16G
Stock injector
Stock ecu
94 octane
Ebay FMIC
Which ecu you are running will have an impact on how much boost the car has. It should be pretty quick regardless, but there are better stock ecu's which will run more boost. If you dont already have one, you might try finding a Z4.
blkgm8 is offline   Reply With Quote
Old 01-08-2009, 03:59 AM   #8
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
... Also our ecu's can be chipped to run a few more psi. Most chips will bring you to around 16psi or so and give you more pump gas friendly timing maps.
Old 01-08-2009, 09:35 AM   #9
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
his ej20g is the wrx RA. has the W6 ecu. from the 93 wrx ra motorset. id recommend if using a stock ecu, go with a Z4 or a SC ecu. can be found fairly cheap. around $200 and less. then buy a manual Boost controller man.
Old 01-08-2009, 09:35 AM   #10
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
also....what kind of gas can you get over in quebec canada?
Old 01-08-2009, 10:13 AM   #11
jaimebenlasnow
Member#: 188065
94 pump gas in here can be found pretty much anywhere
But will i be ok with this setup for a year running on a stock ecu or will i just broke that thing cause I have a bigger turbo thant stock one with FMIC
Old 01-08-2009, 10:29 AM   #12
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
wrx ra means...closed deck...forged..nice flowing heads. i think witha evo 16g....you should be good to go. not alot to worry about. also if you blow it up, it is an easy fix. for cheap.
Old 01-08-2009, 10:44 AM   #13
suberdave
Member#: 101865
88 GL-10 STi
EJ20G
evo 3 16G
Stock injector
Stock ecu
94 octane
Ebay FMIC
i had a simmular setup in my wagon, but stock TD05h 16G. made 245AWHP at 15+-PSI.
but the injectors were maxed out. you may wanna look into larger injectors.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 01-08-2009, 11:13 AM   #14
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
just grab a set of the jdm sti yellow side feeds.
Old 01-08-2009, 11:38 AM   #15
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
480s aren't enough
start with 550s
Old 01-08-2009, 07:18 PM   #16
jaimebenlasnow
Member#: 188065
Yeah i just want to start with 250hp for now don't want to go too far till next year..
Next year power fc with big injector
Old 01-09-2009, 02:13 AM   #17
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Why an evo3 16g anyway?
Did that ra motor not come with a 16g on it already? It should have had the td05 "16g" to begin with... Not really any kind of upgrade going to an evo3 from that... basically another stock jdm car that came with a 16g on it... The real upgrade is the turbine section... which you cant use on your car. You would have to swap in your subaru td05 turbine housing to make it bolt up to the up-pipe.
Old 01-09-2009, 02:17 AM   #18
jaimebenlasnow
Member#: 188065
I didn't have a turbo with my motor so i had to buy one.. I can use a 90 degree inlet pipe no?
Old 01-09-2009, 02:31 AM   #19
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
you can do the 90 degree, what kind of shape is that evo 16g in? i know someone with another jdm 16g with the 90 degree inlet that would probably do a trade with you. no play and very low miles, if u are willing to do a even trade and ship to the usa. shipping should be around 33bucks via UPS with a weight of 14lbs.
Old 01-09-2009, 02:46 AM   #20
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Rob.....(the guy who made the coil conversion thread)
he chips stock ecu...
he told me something like, he ups the boost to 18psi..no speed limiter. ups the rev limiter.. and some other stuff... talk to him... i was thinking about doing it... its a WAY cheaper solution then getting a standalone
azn0boi04 is offline   Reply With Quote
Old 01-09-2009, 02:47 AM   #21
jaimebenlasnow
Member#: 188065
Yah but i don't have the same performance than a Evo3..
So i get kinda screwed..
I might just go on and check for another turbo i got this one for free.
Old 01-09-2009, 02:50 AM   #22
jaimebenlasnow
Member#: 188065
Yeah buy you don't have the same performance cause i'm going bigger injector and bigger turbo than the stock ecu has with some bolt on
The project is to get over 300WHP by next year.. cause i've never driven turbo car so i need to get used to it for a bit especially here in our weather one day you wake up and you door is blocked with snow, the other day there's nothing..
Old 01-09-2009, 04:00 AM   #23
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
i understand completely. Trust me. overall, stock the motorswap will be more than fun and fast.
Old 01-09-2009, 04:39 AM   #24
jaimebenlasnow
Member#: 188065
Yeah ahah it will be very nice to see those ****ty civic say goodbye and craving for turbo..
But next year is power year
Old 01-09-2009, 05:12 AM   #25
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
throw some coilovers on there and just go. you will be more than happy.
JR Tuned / TURBOTRIX Racing Built / 10.1@138 @25psi DRAG STi OVeRBOOSTn Proven Power Bragging 1727 03-25-2013 12:19 AM
EJ20G Intercooler,harness,gauge,boost controller,rob's tuned ecu jaimebenlasnow 1993 - 2001 Impreza Specific Parts 5 01-07-2010 07:16 PM
EJ20g, SAFC? Budget tuning XanRules Pre-2002 Factory Turbo Powertrain 17 09-11-2008 02:44 AM
Where can I get a EJ20G using Electormotive TECII Tuned in SO CAL!?!?! jsavage Southern California Impreza Club Forum -- SCIC 1 06-27-2008 01:42 PM
TUning for the ej20g phunkeeHomosapien Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-12-2004 11:56 PM
