Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 12-25-2008, 04:53 PM   #1
sonic03dz
Member#: 144056
03 wrx
sonic yellow stage 2
Question oil pump leak @ 60k..what other parts to change?
I got an 03 WRX turbo w/64,500 miles. The car has a SUBARU PLATINUM WARRANTY.
I know the oil pump is THE ONLY PART covered by warranty, however should I be changing other parts if it is going to save me on labor costs?
if so...
What Parts?
-spark plugs(still original)
-oil pump
-timing belt
-water pump
-pulley assembly
-thermostat
-alternate belt
Will probably be less expensive to bring it to a local mechanic and save on labor and get parts wholesale(including oil pump), than go to SUBARU?
sonic03dz is offline   Reply With Quote
Old 12-26-2008, 09:19 PM   #2
mikeythejew
Member#: 141672
Do your homework and find out.
mikeythejew is offline   Reply With Quote
Old 12-26-2008, 10:24 PM   #3
beanbeanbean
Member#: 132935
02 rwx
round
thats a nice answer i thought people came here for help?... how do u know it's the oil pump... and if it's under war. let them change it out for free the timing belt/wp (correct me if im wrong) isn't really needed till 100k if i rember and the plugs are not part of that sys. the aces belt is easy to do that urself... pulley ass.? is there a bad pulley? other wise leave it alone... car over heating? i don't know the service intrevall of the thermostat tho
beanbeanbean is offline   Reply With Quote
Old 12-26-2008, 10:51 PM   #4
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
For less than $10 a seal, you might as well replace the crank and cam seals. This is my first post in a long while, but if my memory serves me correctly, there are 5 phillip screws on the back of the oil pump that could have worked loose.
Chuck
ImprezaVA is offline   Reply With Quote
Old 12-26-2008, 10:54 PM   #5
sonic03dz
Member#: 144056
03 wrx
Default oil pump
Thanks for the response......i know the timing belt does not need to be changed until 100k, but I know the front end will already be taken apart to get to the oil pump, so it would save on labor.
Oil pump I was told was leaking because there is oil around it, however I am not losing a significant amount of oil but since its under warranty it isnt a issue...just all the other parts is the question?
Old 12-27-2008, 02:16 PM   #6
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Crank Seal
On occasion, mechanics misdiagnose the oil pump as the culprit for the leak when in actuality it is the crank seal.
Here are some pics you might find useful from a 2.2L, but should be very similar to your 2.0T:
If you plan on keeping the car for a while, I agree with your process of going ahead and replacing all the wear items even if it is 40K miles early.
Chuck
Old 12-27-2008, 02:43 PM   #7
sidewayz
Member#: 5810
2001 S366 2.5RS
99% of the time it isn't even an oil pump or crank seal leak...
but *GASP* a Power Steering pump leak :/
the WRX pump is a notorious leaker
sidewayz is offline   Reply With Quote
Old 12-27-2008, 02:54 PM   #8
RoadTrippin
Member#: 161175
if so...
What Parts?
-oil pump
-timing belt
-water pump
-pulley assembly
-thermostat
-alternate belt
Did that exact same service about 20k miles ago (I have 120k on my 02)
Now this is assuming you have a shop do ALL of the work.
-Oil pump, water pump, timing belt, thermostat, accessory belts: puts you right around $1000 (you save $$$$ if you do it yourself)
-The spark plugs are a real PITA. If you have the right tools you can do it fairly easily, otherwise a dealer will charge somewhere around 250-300ish.
RoadTrippin is offline   Reply With Quote
Old 12-27-2008, 03:43 PM   #9
Sudafed
Member#: 70090
2002 2.5 RS
i wouldnt go to a local place. timing belts arent something that a lot of places can do, even if they say they can. i cant tell you how many local shop timing belt jobs i have had to fix, and sadly most come with new valves.
Sudafed is offline   Reply With Quote
Old 12-30-2008, 10:47 PM   #10
weston666
Member#: 198759
Default hmmmmmm
hmmmmmmm
weston666 is offline   Reply With Quote
Old 01-05-2009, 10:15 PM   #11
sonic03dz
Member#: 144056
03 wrx
Default power steering
Subaru told me its the power steering leak not oil pump even though its dripping down on the oil pump case.......
Old 01-06-2009, 09:10 PM   #12
n2oiroc
Member#: 141952
03 11 wrx/13 brz
oil dye works wonders for situations like this.
n2oiroc is offline   Reply With Quote
