Old 04-01-2002, 10:02 PM   #1
blkntz74
Member#: 12757
2002 Impreza WRX
WR Blue Pearl
Default Cusco exhaust hangers
I'm getting a prodrive exhaust this weekend and will eventually be doing the whole exhaust. Should I get some new hangers? Who sells them and how much? What's the install like? TIA
-Scott
blkntz74 is offline   Reply With Quote
Old 04-01-2002, 11:21 PM   #2
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
Aftermarket hangers tend to make the exhaust system sit higher since they don't sag as much as the stock ones. That being said it's usually best to confirm with your vendor that stiffer hangers won't cause any fitment issues.
I bought Cusco hangers from Irvine Subaru.. although a few vendors sell them, and you should also remember Kartboy has developed some as well.
They tend to sell for about $10 a piece.. although you generally get a slight discount for buying 4 at a time.
lenyx is offline   Reply With Quote
Old 04-02-2002, 12:03 AM   #3
txjunglist
Member#: 11926
2011 Outback Limited
Dark Grey
Default Use the factory Hangars
I used Kartboys exhaust hangars and they suck . I'm just pissed cause like the last person said they ride too high. I almost rubbed a hole in my exhaust system with my axles.
txjunglist is offline   Reply With Quote
Old 04-02-2002, 10:09 AM   #4
blkntz74
Member#: 12757
2002 Impreza WRX
WR Blue Pearl
Thanks for the tips. I should be getting the prodrive from Irvine Subaru this week. After I receive it, I will call back and ask about the hangers. I eventually will be doing scoobysport turbo back (leaving in the 3rd cat). Just need the cash to do it....
-Scott
Old 04-02-2002, 10:42 AM   #5
mynew02
Member#: 13726
2002 WRX - 264 AWHP
ION-Turbo&LINK [email protected]
Does anyone know of hangers that hang lower than stock... My exhaust sits too high as it is...
mynew02 is offline   Reply With Quote
Old 04-02-2002, 06:32 PM   #6
lenyx
Member#: 8221
-Scott
Just to let you know.. I had to modify the *mounting arms* (for lack of a better word) of my scoobysport to get it to sit right with the cusco hangers.
Ken recommends against aftermarket hangers altogether. I like them.. just need to modify a little to accomodate them.
Old 04-04-2002, 08:59 AM   #7
blkntz74
Member#: 12757
2002 Impreza WRX
WR Blue Pearl
Lenyx, can you clarify on the modification you had to do.
TIA
-Scott
Old 04-04-2002, 10:13 AM   #8
Psi-Fire
Member#: 6498
blkntz74,
The installation is a snap, you just unhook them and replace. I am thinking of getting some aftermarket hangers too but I'm hesitant now after hearing these problems. I have the Tanabe SRM and didn't feel the need for new hangers, but I have some vibration noises I'm hoping stiffer hangers will get rid of.
If anyone knows of any stiffer hangers that let the exhaust sit lower, please post.
Psi-Fire
Psi-Fire is offline   Reply With Quote
Old 04-04-2002, 02:21 PM   #9
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
I use the Cuscos on my BPM. With only two of the four in place, it fits where it should. I need all four in there for security, but as others have said, that will require me to bend some of the mounting hardware a bit. This is not terribly hard Probably alot easier than trying to source special off-length hangers (exhaust hangers are nearly universal...mine weren't even "for" the impreza, they just happen to be identical to about three other brands of car ).
Conduit is offline   Reply With Quote
Old 04-04-2002, 03:43 PM   #10
twinz
Member#: 13423
Cusco hangars for WRX exhaust are a waste of money. totally not necessary and a total bitch to install. anybody want a set of 4? I'll sell 'em all for $25.00 shipping included.
twinz is offline   Reply With Quote
Old 04-04-2002, 08:46 PM   #11
rexecutioner
Member#: 10540
2002 WRX sedan
I'm wondering if they wouldnt help me out, my TXS rearsection is just barely touching the frontmost diff protector bolt. I dont hear it vibrating while running but I notice a slight clank when I shut off the engine or shake the car or the exhaust. If they picked up the exhaust about a 1/2" it might be worth a try. I will PM you
rexecutioner is offline   Reply With Quote
Old 04-04-2002, 09:52 PM   #12
SpooledRex
Member#: 10216
2002 WRX - WR Blue
The Cusco hangers were a bit of a pain to install. I just used some WD-40, sprayed the mount and the inside of the hanger and they went on pretty easily after that.
I have all four on my car. I would definately recomend them to anyone with the HKS Car/Ti. I know with mine, the exhaust hung a bit low and would "wobble" around with the factory hangers.
Once replaced the exhaust sits a little bit higher (looks better IMHO) and is very stable.
I checked to see if the exhaust was hitting anything, but it still clears with ease. Also with the HKS there were no modifications necesary to use the Cusco hangers.
Chris
SpooledRex is offline   Reply With Quote
Old 04-05-2002, 08:37 AM   #13
txjunglist
Member#: 11926
Dark Grey
Default My hangers are for sale too
Used 1 day. $30 shipping inc. Black color.
Old 07-24-2002, 02:58 PM   #14
Psi-Fire
Member#: 6498
I installed all four Kartboy exhaust hangers and I couldn't be happier. They fixed all the vibration problems I had, and my Tanabe SRM doesn't sit too high. It sits perfectly and is very stable now, I definitely recommend them to anyone with the Tanabe SRM.
Psi-Fire
Old 07-24-2002, 05:20 PM   #15
Titanium
Member#: 10749
2006 WRX Wagon SGM
2006 BMW E85 3.0si
...for a cheap and easy fix (maybe a little ghetto :P), try wrapping a hose clamp around the hanger and tighten to get rid of vibration or to raise the exhaust a little....it works.
Tom
Titanium is offline   Reply With Quote
Old 07-24-2002, 06:02 PM   #16
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Here is a page with pics of the Kartboy hangers:
http://www.scoobymods.com/forums/sho...hlight=hangers
Peaty is offline   Reply With Quote
FS: (IN) - Prodrive Oval Tip Cat Back Exhaust + Cusco Exhaust Hangers downeyer Engine/Power/Exhaust 12 03-05-2010 09:19 PM
where to buy cusco exhaust hangers? wRx14pSi Tri-State Area Forum 3 06-09-2003 07:42 PM
Cusco exhaust hangers? MrWRX2 Newbies & FAQs 0 10-10-2002 06:42 PM
Cobb/Cusco? exhaust hangers Arnie Car Part Reviews 7 08-29-2001 09:05 PM
