Old 03-20-2009, 11:17 PM   #26
Cyclops
Member#: 95017
2000 2.2RSTI stroker
2010 SWP STI
Originally Posted by thejean View Post
I think can reuse the struts if you use 04 STI hubs... is that correct?
Sure is from what I've heard as well. Those 5x100 knuckles are all the same.
Cyclops is offline   Reply With Quote
Old 03-21-2009, 12:43 AM   #27
thejean
Member#: 17763
Well, I'll know for sure tomorrow as I am putting them on my car.
thejean is offline   Reply With Quote
Old 03-24-2009, 09:01 PM   #28
zGb
Member#: 206410
2006 WRX
i have both edm '06 wrx and '06 sti...the sti is totaled and now i'm trying to put everything on my wrx...can i install sti cluster and make the dccd to work without installing the STI ecu on my wrx?
zGb is offline   Reply With Quote
Old 03-24-2009, 11:42 PM   #29
Cyclops
Member#: 95017
2010 SWP STI
The DCCD on the cluster won't work with your stock ECU. The easiest way I know to get the DCCD to work is to get the newest Spiider DCCD controller. It ties into your STI cluster to make your DCCD indicator on your cluster work. Besides that you WRX cluster doesn't have the necessary wiring so you'd need the whole ECU and all that.
Old 03-29-2009, 03:00 PM   #30
bigboy
Member#: 117384
2003 WRX
sonic
my question to you is...what if i bought an 07 sti tranny and was goin to do all of this BUT i want to keep 5X100 wheels??
does the year of the axle matter at all...or is it the hubs and knuckles that cause the offset to change in the different years of cars??
Im kinda confused on this matter...cause i have a set of brembos already on my 03 wrx and want to stay 5X100
Any help would be great
dustin
bigboy is offline   Reply With Quote
Old 03-29-2009, 03:17 PM   #31
Archetype_
Member#: 206969
Originally Posted by Cyclops View Post
I'm actually doing that exact swap this month some time. All my 07 drivetrain is going in to a 2000 RS. I think I'll need a clutch slave for sure, also a rear crossmember for the rear diff.
Hey I would like to hear how this goes and total cost out the door... I have a 99 rs that I have considered doing a swap on.
Archetype_ is offline   Reply With Quote
Old 03-31-2009, 05:12 PM   #32
Xenri
Member#: 166777
2011 WRX Wagon
dustin
bump for an answer to this.
Xenri is offline   Reply With Quote
Old 04-01-2009, 08:43 PM   #33
RallyDrvr
Member#: 207352
02 Wrx 4eat
Rally Blue
What will i need clutch assembly wise for the auto to 6speed swap?
RallyDrvr is offline   Reply With Quote
Old 04-01-2009, 08:59 PM   #34
snwboard4life69
Member#: 166788
2003 subaru wrx
stage 3 race car
also curious, i am going 6 speed but can you swap in the stock dcdd controller if the person gives it all to you? what would you need?
snwboard4life69 is offline   Reply With Quote
Old 04-02-2009, 01:39 AM   #35
Cyclops
Member#: 95017
2010 SWP STI
Depends on the year. The 07 has some extra sensors I need. I'm pretty sure you at least need ECU and a few of the DCCD sensors but honestly I'm not sure what. I know the aftermarket stuff is easier and cheaper.
Old 04-02-2009, 01:40 AM   #36
Cyclops
Member#: 95017
2010 SWP STI
You'll definitely need the clutch/pp/flywheel, clutch fork, and slave cylinder. I'm thinking you'll also need master cylinder and the lines that connect it to the clutch pedal but again I've never done it so I can't be sure. If someone can chime in I'll edit my original post.
Old 04-02-2009, 01:42 AM   #37
Cyclops
Member#: 95017
2010 SWP STI
dustin
If you have an 07 STI tranny the 07 tranny has a 1:1.1 center diff, same as the WRX. I don't think you can run the WRX rear axles on an R180 so AFAIK you'd keep the R160, run an auto drive shift, then do stubs up front. You also might be able to rig an r180 from an 04 to match up axles but I've never done it so I'm not 100%.
Old 04-02-2009, 01:42 AM   #38
Cyclops
Member#: 95017
2010 SWP STI
I think I've sourced parts on everything and have it all up there but I'll let you know when I do it. Should be the next couple of weeks.
Old 04-02-2009, 06:47 PM   #39
snwboard4life69
Member#: 166788
2003 subaru wrx
stage 3 race car
where can you get the spiidder dcdd controller from?
Old 04-02-2009, 06:48 PM   #40
Cyclops
Member#: 95017
2010 SWP STI
Old 04-07-2009, 08:32 PM   #41
bigboy
Member#: 117384
2003 WRX
sonic
thanks for your answers...i figured i would keep the stronger STI rear end and somehow adopt some rear axles that would allow me to keep my 5x100 setup!
im goin to have to look into it some more
Old 04-08-2009, 12:31 AM   #42
Cyclops
Member#: 95017
2010 SWP STI
I think Drive Shaft Shop made some custom axles just for that purpose buuuuut I don't think they were too cheap.
Old 04-08-2009, 11:32 AM   #43
thejean
Member#: 17763
Yep, and they don't make them anymore. I used to have a set but sold them recently.
Old 05-01-2009, 12:13 AM   #44
tx868
Member#: 209882
hey can you guys tell me a little more about the DCCD controller, I just finished a swap 06 sti into a 2000 rs, everything went in nice. but i cant seem to figure out why its throwing this code ( p0502 vehicle speed sensor A circuit low input). And i cant control the DCCD or switch it to auto. but i can before i start the car on key power. ive checked all my wiring over, cant find anything. any ideas?
tx868 is offline   Reply With Quote
Old 05-01-2009, 12:22 PM   #45
thejean
Member#: 17763
Do you have the vehicle speed sensor plugged in?
Old 05-14-2009, 12:24 AM   #46
Diabolus
Member#: 72620
where did you get STI Knuckles and hubs for $100? I'm assuming that's for all 4, so $25 each corner. That's insanely cheap.
Diabolus is offline   Reply With Quote
Old 05-14-2009, 12:52 AM   #47
Cyclops
Member#: 95017
2010 SWP STI
I got them together with a little bit of other stuff so that might be a bit of a discount.
Old 05-15-2009, 04:06 PM   #48
Xenri
Member#: 166777
2011 WRX Wagon
I posted this in the suspension forum, but thought I might have some luck here as well as people reading this are planning on doing, or have already done, a 6 speed swap.
I have an 02 wagon and have an 05 STi trans kit with the diff and hubs and etc on the way. I need suspension and did not realize how complicated that can be until just the other day. The rear suspension on my wagon differs from that off the sedan, and that looks like it is going to create some complications for me. Anyone have any experience putting sedan suspension in a wagon? Or putting the STi suspension in a wagon?
Old 05-15-2009, 04:10 PM   #49
Cyclops
Member#: 95017
2010 SWP STI
Yup, what part are you worried about?
STI struts and springs bolt up fine to the rear top hat perches and the struts bolt to your 05 knuckles. STI lateral links will bolt to STI knuckles and WRX cross member. You can use your stock lateral links, too. WRX sway bar will mount right up to your WRX cross member and WRX lateral links. If you use STI lateral links you just need to make sure you get STI end links, the bar will be the same either way. STI rear diff bolts right in to your cross member, axles bolt right up.
Old 05-15-2009, 04:19 PM   #50
Xenri
Member#: 166777
2011 WRX Wagon
So if I get some STi Lateral links and some STi endlinks, I can run any 05+ struts, springs, and tophats, and everything else can stay wrx? Is that true for the front and the back? I thought the wagon had different rear control arms (though I do not know in what way they differ) and that would interfere with having everything bolt up.
Im new to the suspension game so any info is appreciated.
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 808 08-12-2015 09:01 AM
Feeler: 06 wrx sti 6-speed drivetrain swap... 06TRDude Drivetrain 8 02-23-2009 07:50 PM
Cost estimates for 6-speed swap into an 02 WRX? aasim_a Transmission (AT/MT) & Driveline 24 05-31-2008 04:37 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle Subaru Conversions 15 11-04-2006 01:11 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle South West Impreza Club Forum -- SWIC 2 10-31-2006 04:15 PM
