09-11-2009, 12:36 AM | #76 |
Member#: 150108
Vehicle:2001 LGT Green |
Is it possible to put the 6mt into a 4eat car and have it look pretty? ('05 Leg), Since I do a lot of highway, I figure the longer ratios would be nice.
09-21-2009, 05:44 PM | #77 |
Member#: 152781
I have a 99rs with an sti swap, engine and tranny from an 05 sti, except i have the 05 rs rear diff to keep my 5x100 set up. i want to change to the stronger sti rear diff so i would need the sti driveshaft, sti axles, and 04 sti hubs correct? is there anything else that i would need and also i have the 06 wrx 4 pot brakes front and rear. if i change to the 04 sti hubs will my brakes still fit or will i have to get brembos?
09-21-2009, 07:12 PM | #78 |
Member#: 166777
Vehicle:2011 WRX Wagon SWP |
You will need the STi brakes. The bolt pattern will stay the same, but pretty much everything else changes.
09-22-2009, 01:22 PM | #79 |
Member#: 152781
10-04-2009, 07:13 AM | #80 |
Member#: 196013
NWIC
So, I had an 07 STi transmission with the rest all 02 WRX crap until yesterday. I swapped in the rest of the 07 STi junk, but it seems the e-brake (parking brake) cables are too short to reach the bell crank thing under the center console by about an inch. Anyone had that problem before? Even better, is there a remedy? Thanks!
~T.J. |
10-25-2009, 08:35 PM | #81 |
Member#: 196013
NWIC
I solved my parking brake problem a while back, and figured I would post the solution that worked for me. Again, this was 07 STi suspension going into an 02 WRX and the parking brake cables were too SHORT and wouldnt reach the cable coming off the hand brake lever.
The solution was easy enough, I just ordered up the cable that goes on the lever for an 07 STi (P/N 26051SA050). It was about 1" - 1.5" longer than the WRX version, which netted me enough room to connect the cables to the parking brake lever. They moved the brake lever in the newer cars, thus, that had to be longer, and it just happened to work perfect for my setup. The WRX parking brake handle cable had two nuts, but the way the STi cable fit into the WRX handle, there wasnt enough threaded part showing to fit two yet. There are currently about 5 threads showing past the top of the adjusting nut, but the brake doesnt engage until the handle is up higher than I want (about 3/4 of the pull) anyway, so Im going to jack up the rear end and tighten that nut while making sure the parking brake isnt dragging until I get it more in the middle of the pull where I want it. Once thats done, I suspect there will be quite a bit more threaded shaft past the top of the nut and I may be able to double nut it the way the WRX version was set up. I highly doubt it would back off anyway, but you never know. Ive seen plenty of cars that run a single nut there anyway and everything is fine. Im sure it will work just fine for years to come. ~T.J. |
10-27-2009, 03:01 AM | #82 |
Member#: 222792
hey i am thinking about doing drive train swap on my 1998 Subaru impreza outback sport can i get some peoples opinions with i should go forward with it or save up for a wrx??? please and thanks.
11-24-2009, 03:20 PM | #83 |
Member#: 169624
Vehicle:2003 WRX Midnight Black?? |
so im thinking of doing a 6spd swap being that i blew my stock trans, and im on a tight budget.. unless im mistake, what i picked up from this thread is that i can get an 07 sti trans, axles, and any year automatic driveshaft? and be ok?? was wondering if anyone can give me some insight to what i may need if this is incorrect...
11-24-2009, 04:58 PM | #84 |
Member#: 166777
You need an 07 trans, an auto driveshaft from any impreza model (or a yolk from a wrx with an sti driveshaft), and front axle stubs. Of course, you can use your wrx clutch, but the sti ones are bigger, so if you are buying a new one (which you should) get an sti clutch and flywheel. You will need an sti clutchfork and linkage/shfter as well, but if you buy it used, it will probably have all that. Be aware that only the 07 trans gets you out of swapping you rear diff, thus making you swap axles, hubs, brakes, etc. You will NOT need new axles if you keep the rear diff the same, just get 04 axle stubs for the front and it bolts right in.
11-25-2009, 01:23 AM | #85 |
Member#: 178712
NWIC
Vehicle:2017 WRX Black |
okay so i have an 05 2.5rs that is currently auto i was originally planning on doing a 6 speed swap sometime next summer if everything goes right since i am only 18 and parents do not want to pay the insane insurance prices on a wrx or sti. this will sorta be my grad/get into college present i guess.
anyways i will have 5k to spend for the tranny swap but am thinking that it would be better just to do the entire drivetrain swap since i plan on sti swapping later on, alot later on. so my question is about how much more would i need to save for a complete drivetrain swap if it was to be done at a shop? or should i just do the 6 speed swap now and save the rest for later? |
12-21-2009, 08:36 PM | #86 |
Member#: 77308
Vehicle:'05 STi White |
Cyclops, could you edit you original post to include a section for a bares bones swap. Also, maybe add some info 07 tranny with WRX diff and stuff like that?
In post #61 you added some good info as well as some of Xenri's posts. I spent a little time reading this thread and it would be nice to see it summarized it the beginning post. I am thinking of doing a swap like this and it would be nice to see what my options are and some of the pro/cons to go with the choice. |
12-24-2009, 09:16 PM | #87 |
Member#: 185603
SCIC
Vehicle:2002 stock wrx wrb |
Whoaaa so confusing! I swear if your dropping an 04 6speed into a 2002 rex wagon, you just need 04 axles and not swap out the whole knuckle. 04 sti's come with 5x100. Correct me if im wrong.
12-24-2009, 09:36 PM | #88 |
Member#: 185603
SCIC
04 sti 6speed into 02 wrx wagon-
04 sti 6speed 04 r180 diff 04 sti driveshaft 04 sti axles aftermarket dccd clutch fork,disc,pressure plate, flywheel, and slave cylinder add or correct please |
12-27-2009, 05:27 PM | #89 | |
Member#: 95017
NWIC
Vehicle:2000 2.2RSTI stroker 2010 SWP STI |
12-27-2009, 09:58 PM | #90 |
Member#: 77308
01-12-2010, 01:00 PM | #91 |
Member#: 109121
SWIC
Vehicle:2002 Impreza WRX WRB-world rally blue |
So I might be reading into this wrong, I have an 02 wrx that I am planning on doing a 2.2 stroker kit on, if I was to use the sti trans lets say from an 04 would I be able to just bolt it up and use basically all the stock wrx suspension stuff minus the drive shaft or would/should I change the axles and brakes. Would the wiring be different or would that stay the same. I know that the trans is bigger than the 5 speed therefore the driveshat would need to be changed. But could I use the stock axles, knuckles and hubs with just changing the trans.
01-14-2010, 11:11 AM | #92 |
Member#: 35944
South East
Vehicle:'03 EJ257/EFR/G4+ MBP |
I've read half a dozen 6 speed swaps threads and still am unclear on a couple things:
For a 06-07sti budget swap into 03 wrx, Do I need the slave cylinder? And same question for 04-05 sti swap instead? As for the auto driveshaft, exactly what models and years will work? |
02-07-2010, 05:04 PM | #93 | ||
Member#: 178045
South East
Vehicle:22 Sorento SXP Gravity Grey |
Will I be able to just swap everything from the 04 STi and keep the wheels and brakes (since they're from an STi) that are already on the car? I found a "complete" 04 STi tranny swap that I think would work. Am I correct in looking at 2004's instead of 2005+ ? *edit - the car already has an STi suspension (v6 struts, eibach springs) too Last edited by pezcore; 02-08-2010 at 12:04 AM. |
02-14-2010, 11:16 AM | #94 | |||
Member#: 178045
South East
Halp! I can't bump the thread because it's a sticky
Here's what's on the car currently: Quote:
Do I HAVE to get Brembos or are the STi 22B brakes on the car "ready" for the swap? Is the suspension ok for the 6SPD swap? I've searched but most of the info that has to do with the RS doesn't assume the engine has already been swapped and that the rest of the car is stock. I'm trying to see what WILL fit with what has already been done with the car. *edit - also, what about the DCCD. If I'm using an STi ECU, shouldn't the DCCD work if I have the brain and dial for it? I would be ok with it working and me not having the display on the dash. Last edited by pezcore; 02-14-2010 at 11:27 AM. |
02-14-2010, 12:55 PM | #95 |
Member#: 234783
Vehicle:2004 STi Aspen White |
im doing this swap sometime next month, can i do it with out the suspension? or should i just spring and get a decent set of 04 sti coilovers? im running an 02 wrx with drop springs.
02-14-2010, 02:15 PM | #96 |
Member#: 196742
VIC
Vehicle:2000 Impreza 2.5rs Silver |
well if the bone stock 2000 2.5rs suspension fits on the 04 hubs. I don't see why the 02 WRx which has the same bolt pattern wouldn't fit on a hub that is the same bolt pattern.
if it is the 05 hubs then I'd say no you need suspension |
04-12-2010, 04:47 AM | #97 |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 EJ207 S204 Wagon |
Maybe too late, but you'll also need the 04 STI rear hubs. The 02 WRX rear hubs is not going to work with the R180 and STI axles.
04-12-2010, 09:21 PM | #98 |
Member#: 196045
BAIC
Vehicle:02 wrx silver |
where did you get cobb springs w/ struts for $200?
04-24-2010, 03:09 PM | #99 |
Member#: 213987
International
Vehicle:1996 Legacy Black |
Thank you for great thread, I was able to swap 6spd tranny on my legacy BG without having to wonder what was needed
05-24-2010, 12:36 PM | #100 |
Member#: 247553
Vehicle:2002 Subaru WRX Maroon |
(im typing this for my husband btw) He has a 02' WRX first gear does not work but all other gears are fine the trany couldn't handle the horsepower and needed to be upgraded, would you reccomend a swap or upgrade the parts?
Master swap list for 04-07 Sti 6 speed into WRX | crashtke | Transmission (AT/MT) & Driveline | 817 | 02-11-2021 02:07 PM |
Feeler: 06 wrx sti 6-speed drivetrain swap... | 06TRDude | Drivetrain | 8 | 02-23-2009 07:50 PM |
Cost estimates for 6-speed swap into an 02 WRX? | aasim_a | Transmission (AT/MT) & Driveline | 24 | 05-31-2008 04:37 PM |
Parts needed for an STI drivetrain swap into an 01 RS | SubeSTIle | Subaru Conversions | 15 | 11-04-2006 01:11 PM |
Parts needed for an STI drivetrain swap into an 01 RS | SubeSTIle | South West Impreza Club Forum -- SWIC | 2 | 10-31-2006 04:15 PM |
