Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 07-09-2011, 04:16 AM   #151
AlbanianImpreza
Member#: 38506
2000 NEW hotness RSC
SRP SON!
welp, ill be doing a 05 sti 6sp into my 00RS 4eat. i have a 02 wrx donor car. i will be using my R160s after reading up about it. so i know you guys said that you can use a wrx auto driveshaft? why not an RS auto driveshaft?
AlbanianImpreza is offline   Reply With Quote
Old 07-11-2011, 02:39 AM   #152
AlbanianImpreza
Member#: 38506
SRP SON!
are they the same??
Old 07-11-2011, 03:17 AM   #153
Xenri
Member#: 166777
2011 WRX Wagon
Yes. The transmission is identical, and they both use R160 diffs. Therefore, the driveshaft should be the same. The driveshaft in my 02 WRX swap came out of an RS.
Xenri is offline   Reply With Quote
Old 07-11-2011, 01:34 PM   #154
AlbanianImpreza
Member#: 38506
SRP SON!
there we go. thank you kind sir!
Old 07-12-2011, 02:31 AM   #155
AlbanianImpreza
Member#: 38506
SRP SON!
one more question the front axles? will i be using the STI stubs and using legacy axles? is that how id get the front part done up?
Old 07-24-2011, 01:46 PM   #156
FastAdams
Member#: 280714
1998 Look below.
98 rs 99 forester
Hey guys newbie here, what about someone that, instead of swapping my auto for a 5 speed, just skipped the 5 speed altogether and went straight for the 6 speed?
FastAdams is offline   Reply With Quote
Old 07-24-2011, 06:40 PM   #157
Xenri
Member#: 166777
2011 WRX Wagon
To Albanian Impreza:
Uhhh I just used 04 stubs in an 07 transmission with my stock 02 axles. Not sure how the legacy parts fit in there, but I have never looked into doing the swap into one of the older cars, and so I don't know what you need to go into your hubs. The important factors are:
1. The axles fit into the stubs on the transmission (04 STi matches 02-03 axles, after that, it's all different)
2. The axle fits into the wheel hub (STi axles ONLY fit STi wheel hubs, as they have more splines and are thicker.) Not sure how the legacy axles would meld into all this, but that doesn't mean it doesn't work, just that I have no idea.
To FasAdams:
Shouldn't cause any problems. I don't know what all it takes to make the 4eat to manual swap other than the obvious stuff (clutch pedal, master and slave cylinders, etc.) but those parts work for either the 6 speed or the 5 speed manual transmissions. I think the STi master and slave cylinder are a bit different (bigger I think) but the WRX ones still function just fine with the 6 speed clutch and transmission (that's what I have in my car right now.) Other than the extra parts and labor needed to make the car a manual, the swap should be identical to a 5speed to 6speed swap.
Old 07-24-2011, 06:45 PM   #158
FastAdams
Member#: 280714
1998 Look below.
98 rs 99 forester
Ok thanks i appreciate it.
Old 07-26-2011, 11:15 PM   #159
AlbanianImpreza
Member#: 38506
SRP SON!
so the stock 02 axles fit? im pretty sure the wrx axles are the same. i have to double check, sounds like this is kinda easy. not sure if thats good. ish
Old 07-27-2011, 11:00 PM   #160
AlbanianImpreza
Member#: 38506
SRP SON!
also im bolting it up to my r160. but im hearing a 3.90 rear diff. does anyone have input on this?
Old 08-23-2011, 07:07 AM   #161
05Scooby
Member#: 153216
2005 WRX stage 3
CGM
theres a sticky on all the drivetrain (or majority of them) fd's.
read and you shall find an answer.
my question.
Are sti axles interchangable?
05Scooby is offline   Reply With Quote
Old 08-23-2011, 09:42 AM   #162
Xenri
Member#: 166777
2011 WRX Wagon
I believe the 05-07 sti axles are, but the 04 are not. I'm basing this on the idea that 04 STi stubs fit on 02-03 WRX axles while the others do not.
Old 08-23-2011, 10:23 AM   #163
05Scooby
Member#: 153216
2005 WRX stage 3
CGM
anyone else?
Old 08-23-2011, 03:41 PM   #164
05Scooby
Member#: 153216
2005 WRX stage 3
CGM
bump for some desperately needed info lol
Old 09-03-2011, 12:25 PM   #165
vf22Bugeye11
Member#: 272096
2002 6Speed swap wrx
WRB DCCD PRO-Retro JDM's
I have a couple of questions, I just did a 04 STI Sixspeed into my bugeye i love the treanny solid as hell...but last night i blew my rear diff off a 96 impreza...so i replaced it today with another one...im deciding on what dccd controller to get to prevent this of happening again..DCCD Pro offers 2 the manual only and the other could i just get the manual one and just set it to 50/50 and will it feel like my wrx 5 speed ? i really don't wanna spend 400 for the other one
vf22Bugeye11 is offline   Reply With Quote
Old 11-18-2011, 11:17 AM   #166
ppayer38
Member#: 234407
04 Self-tooned
STi
Been researching a 6spd swap so I have an excuse to build a 2.5 or atleast upgrade my 2.0 further...
Doing the swap to a 05 WRX
*Looking to do it fairly cheap and not swap in a full STI drivetrain
What year(s) trans can be used? 05+ or 07+
6spd clutch fork
6spd mount
6spd shifted assembly
04 STI axles
STI flywheel and clutch assembly(depends how my WRX assembly looks)
DCCD controller??
Please explain this as to what years trans mates to my diff as there is not much info I've found on doing the 6spd swap to 04-05 WRX's...(I'm trying to find gear ratios and understand why "X" trans works with "X" diff or car
What changed from 02-03 to 04-05 in the WRX?(other than the factory 5spd gears being a little stronger and the obvious things body, interior, etc)
ppayer38 is offline   Reply With Quote
Old 11-21-2011, 01:08 AM   #167
Evo-killr
Member#: 252905
2002 Fully Built Wrx
gon rotated psm
If you wanna do a 6speed swap your gonna have to do the brembo swap too. Sti axels won't fit in the wrx hubs and knuckles. Just for your information even though the 04 sti has the same bolt pattern, the teeth on the axels between the wrx and sti are different. And If you wanna do a 6 speed your gonna have to use a sti rear diff too. Sti's have different final drive ratios than the wrx r160 diffs. But what you can do is get a jdm/sti 5 speed RA gear set and still use the wrx diff. do your research and make sure the gear set has the same gear ratio as the r160( i know its possible) and its About the cheaper if not the same price
and just as strong and you won't have to spend money on brembos knuckles axels hubs and blah blah blah
Evo-killr is offline   Reply With Quote
Old 11-22-2011, 01:26 PM   #168
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Stop giving advice.
You can definitely run a 6MT without doing the STi axles, hubs, Brembos, or STi rear diff. You are right, you have to match ratios, but you can find WRX R160 in the 3.90 ratio needed for the 04 STi trans.
RA gears are stupid and will be destroyed just as fast a WRX gearset. What a waste of money.
Old 12-31-2011, 01:33 AM   #169
cmarin21
Member#: 189747
2002 Wrx PSM
VF48 EWG EJ257 Hybrid
Ok read threw this because im purchasing a ver7 sti 6spd (non dccd) and r180 w/ driveshaft and doing research to find out exactly what I need for complete install. post 134-137 it says I just need ver7 tranny, rear hubs and axles, rear diff and DS I have red 4 and 2 pot brakes from 06wrx. My question is would I need shift linkage or more and a slave cylinder? feel free to pm me. thanks
cmarin21 is offline   Reply With Quote
Old 01-22-2012, 08:20 PM   #170
BLAZE2099
Member#: 271588
2011 WRX
Lightning red
looking for a nice quick answer please,
Our USDM trannys from 02, come in an AA or a BA, which we all know the BA is better.
Question is, do JDM V7 trannys have the same similarities? I know some end in AA, but are there ones out there coded with BA as well?
...........................THANX!!!
BLAZE2099 is offline   Reply With Quote
Old 03-19-2012, 06:55 AM   #171
scoobin22
Member#: 300554
2002 wrx
Default Built 5 speed
I picked up an 02 about a month ago and to everyone's surprise the glass shattered lol. I'm looking for an R/A spec rebuild kit. This is my daily and I need her back on the streets! Pullin tranny this morning should be a fun day.
scoobin22 is offline   Reply With Quote
Old 04-11-2012, 07:35 PM   #172
cwa831
Member#: 222304
2001 2.5 RS
Just to be sure. That list for the 00' rs, that is complete right? I have an 01' and I am wanting to do the same thing. Also where did you find most of your parts? PM me if its easier. Thanks. Also on rs25
cwa831 is offline   Reply With Quote
Old 04-17-2012, 05:27 PM   #173
Zseme39
Member#: 317183
I have been wondering a lot about this, good luck with the build. This looks really cool
:ba nana:
(he's left out, just quick description)
Zseme39 is offline   Reply With Quote
Old 05-02-2012, 04:42 AM   #174
Jimmy P
Member#: 297302
2006 WRX
So much reading! I just read all seven pages, and still not 100% sure what I need. Can someone help me out?
I have a 2006 WRX, with STI springs and strut0 installed. I want to do the 6MT swap, while keeping the 5x100 pattern.
Parts I have. All came of 2005 STi
FRONT AXLES
STI clutch
COMPLETE 6-SPEED TRANSMISSION WITH SHIFT LINKAGE
CENTER DRIVESHAFT
STI STARTER
TRANSMISSION CROSS-MEMBER
HELICAL LSD
What else would I need? I swear I read through every post in this thread, but it seems very few of you guys did the swap in a 06-07 WRX so there isn't as much discussion about those years.
Jimmy P is offline   Reply With Quote
Old 05-08-2012, 07:19 PM   #175
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
With the 05 STi trans your going to need hubs knuckles and suspension from an 05-07STi. This means you're converting to 5x114. Unless you use conversion axles of course.
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 792 10-01-2014 07:58 PM
Feeler: 06 wrx sti 6-speed drivetrain swap... 06TRDude Drivetrain 8 02-23-2009 07:50 PM
Cost estimates for 6-speed swap into an 02 WRX? aasim_a Transmission (AT/MT) & Driveline 24 05-31-2008 04:37 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle Subaru Conversions 15 11-04-2006 01:11 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle South West Impreza Club Forum -- SWIC 2 10-31-2006 04:15 PM
