Old 01-06-2009, 10:06 PM   #1
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Default Clockspring to support 10-15 wires and ~10 turns lock to lock?
Hi,
I'm working on a small electrical experiment that involves a rotating part...
It needs to rotate a good bit, which makes traditional wiring an issue.
Anyone know of a clockspring setup that'll support this much wiring, or possibly a better option?
Thanks,
-- Dave
AcquaCow is offline   Reply With Quote
Old 01-06-2009, 10:13 PM   #2
RumblingREX
Member#: 41087
You could build something like the below link where each circuit is on a tier above the other. This would minimize the overall width, but the depth would be greater.
http://www.power-delivery.com/z_swiv...nnector_01.php
Or you could go with the tradition slip ring approach.
RumblingREX is offline   Reply With Quote
Old 01-06-2009, 10:19 PM   #3
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Ooh... that could simplify things a lot... I may just be able to install what I want on the rig and use external power, instead of trying to feed video signals through clocksprings...
I could just put the entire unit on the swivel...
Hmm...
-- Dave
Old 01-06-2009, 10:23 PM   #4
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Actually, maybe not...
I don't know how I'd support a central rotating axle with that power connector...
I'd have to be able to run the axle through it, centrally... which is why I originally went for a clockspring...
-- Dave
Old 01-07-2009, 05:41 AM   #5
spongejosh
Member#: 62783
Midnight Black Pearl
what about a circuit board with "rings" that can spin with the device, then "fingers" on the solid side that pickup on the rings. may be too wide for your application though. Hard to explain without a diagram.
spongejosh is offline   Reply With Quote
Old 01-07-2009, 06:14 AM   #6
NightHawk
Member#: 175181
it stinks like sex in here
NightHawk is offline   Reply With Quote
Old 01-07-2009, 08:21 AM   #7
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
that would be a slip-ring. They are available 'OTC' but can be pricey and maybe not practical with a high number of connections or high power.
'Wetted' slip-ring will probably be best to cut down on noise. If they are still made (mercury inside)
Maybe 'flexible' circuit board like used in cameras and other applications? Just VERY long so it could spiral in-out.
Any possibility of doing some data transfer wirelessly?(Zigbee or ?) maybe just need 2 or a a few slip-ring connections that way. Or On-board battery power + wireless comm.
Carl
1 Lucky Texan is offline   Reply With Quote
Old 01-07-2009, 09:31 AM   #8
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Can you pre-wrap regular ribbon cable 10-11 times? maybe spiraled down a shaft?(candy cane style) Just prep it for the maximum twist to the 'lock' in one direction. If the shaft has some length, the actual diameter the cable 'unwraps' when turned to the the opposite lock may be minimal. If wrapped around itself, yeah, could get kinda wide I guess.
Carl
Old 01-07-2009, 12:11 PM   #9
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Actually, if the ribbon/flat cable would reliably 'flip', you only have to pre-wind 1/2 the number of turns. Let it wind-unwind in both directions.
Also, if you feed the wires out throug the middle, or interior of a hollow shaft, you only need to pre 'torque' 1/2 the number of turns. And the longer the cable/harness is, the less total deflection/force is on the system.
Carl
Old 01-07-2009, 12:14 PM   #10
Kiel
Member#: 133439
2003 WRX
Sonic Yellow - Stage Taxi
Use a moebius clock spring, it makes wiring much easier since there's only one side.
Kiel is offline   Reply With Quote
Old 01-07-2009, 12:45 PM   #11
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
and if you cut it along the middle all around it - you still have one that is just bigger in diameter!
Old 01-08-2009, 09:31 AM   #12
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
AC - did you find a solution?
what was it?
Carl
Old 01-08-2009, 12:06 PM   #13
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
what was it?
Carl
Nope, nothing yet...
May end up stacking 3-4 normal clocksprings to get enough wiring...
-- Dave
Volts reading 15.2 and raido turning off? jdmSpecC760 Electrical & Lighting 5 10-27-2009 08:30 AM
If I get to Heaven and it turns out to be your ass... Matt K Off-Topic 5 01-10-2007 02:42 PM
Is there a local who would be willing to spend a lil time and teach me how to weld? DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 16 12-21-2005 12:13 PM
I have never been to a book signing before, and they worth going to? Cjchaps Off-Topic 0 10-06-2004 10:21 AM
OK....so who is going to the meet in MD, and who is going to the meet in PENN? AustinSTi Mid Atlantic Impreza Club -- MAIC 4 06-28-2002 01:28 AM
