Old 01-07-2009, 01:29 AM   #1
Rhymesayer
Member#: 181389
13 Sti WRB
93 K20 Hatch
Default Hesitation under acceleration when cold
My 03 wrx hesitates under acceleration when cold. Makes the car shake. Is this normal? Its bone stock.
Rhymesayer is offline   Reply With Quote
Old 01-07-2009, 09:31 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
shuddering car when cold, irregular idle, these are beginning signs of a failing front 02 sensor
has your front 02 sensor ever been changed?
Old 01-07-2009, 10:33 PM   #3
Rhymesayer
Member#: 181389
13 Sti WRB
93 K20 Hatch
Not as far as I know. Im second owner.
Old 01-08-2009, 10:23 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
you may want to (even though this will cost $$) take the car to Subaru
have them put the car on the select monitor
and check the tolerance levels for the af/02 sensor
if the tolerances are far too high, the car is working overtime to correct itself
this will cause the shuttering/sputtering and idle issues.
it really is best to KNOW what the problem is
rather than guessing and throwing parts at it.
I could be way off base, but I am relaying to you based on my personal experience...
Hesitation/bucking under acceleration DSM-2-WRX Service & Maintenance 4 12-10-2008 08:56 AM
2004 STI Hesitation Under Accel in Cold Weather InsatiableAmos Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-08-2008 03:36 AM
jerky acceleration when cold k mier Warranty Issues & SOA Problems 20 12-20-2005 11:45 AM
hesitation under acceleration WRX PL Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 02-23-2004 12:27 PM
Squeal/shriek accelerating when car is cold Willman67 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 02-03-2002 05:53 PM
