Old 01-07-2009, 01:32 PM   #1
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
Default wrx brake
hello .... i got a 06 2.5i ...
and im trying to get whole brake system from 05 wrx ....
does anyone installed on their 2.5i ??
i wanna make sure it fits on 2.5i without any modification ....
thank you
06impreza2.5i is offline   Reply With Quote
Old 01-07-2009, 01:52 PM   #2
2.5i
Member#: 112986
N/A Cam'd & Cornfed
DOM TUNED 06 Impreza
The only real benefit I believe is bigger rotors in which case your going to need the WRX brakets that hold the caliper on, everything should bolt up otherwise. Why switch to the 05 and not the 06 they came with the better calipers? The 2.5i brakes aren't as bad as everyone things I would just get some better pads, DOT 4 fuild, and the H6 rear rotor upgrade.
Old 01-07-2009, 01:59 PM   #3
obs2008
Member#: 163068
08 outback sport
i wouldnt even bother with pads for right now. get some SS lines for $100 and that will make a huge improvement
obs2008 is offline   Reply With Quote
Old 01-07-2009, 02:22 PM   #4
SHARP_DAL
Member#: 183247
2005 WRX
^^ SS lines don't actually do anything but improve feel slighty.. 05 wrx brakes are very good and I would save your money for 4 pots subaru or something better if your think you really need it.
Otherwise, spend the money on pads and fuild.. that will set you back a couple of hundred..
SHARP_DAL is offline   Reply With Quote
Old 01-07-2009, 04:33 PM   #5
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Stick with stock calipers and go with better pads and fluid, that will make a big difference.
chazly413 is offline   Reply With Quote
Old 01-07-2009, 04:51 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
go ask in the brake section, they might help you more.
Old 01-07-2009, 04:59 PM   #7
mdungelman
Member#: 97251
'13 Impreza 2.0i
This might be better suited for the Brakes, Steering & Suspension forum.
From what I read on this thread.
http://forums.nasioc.com/forums/show....php?t=1265631
The only benefit as far as rotors is a larger diameter front rotor. The rear is the same size. We run the same pads front and rear as 05 WRX's.
mdungelman is offline   Reply With Quote
Old 01-07-2009, 05:25 PM   #8
Back Road Runner
Member#: 60082
2004 Forester STI
pads make the biggest improvement. SS lines do very little.
Yeah, this thread is kind of out of place here and is better suited for the other forum section. The NA powertrain section has been mainly the engine and little else.
The WRX fronts are a step up in rotor size, meaning slightly more torque and slightly better heat dissipation. However, you'll want to upgrade the rear to the Outback rotor and bracket too ("H6 upgrade") to neutral out the brake bias, otherwise, you will create a front tire lock happy setup.
Pad choice will play a big roll in how the brakes function. Choose smartly because the pads will dominate how the brake system feels and operates.
Old 01-07-2009, 06:36 PM   #9
obs2008
Member#: 163068
08 outback sport
oh they do very little???? man, for the average dude, you will get the biggest pedal improvement out of ss lines.
Old 01-07-2009, 08:41 PM   #10
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
thank you for all the reply ....
my front and rear pads are done ... someone was asking 320 for the whole brake kit from 05 wrx with 200 miles on the pads ... so i figured i pay little more for 4 pots ....
i hate the look of stock 2.5i calipers.....
neway what is the differences between 05 and 06 wrx 4 pot ??
should i look for the 06 or just get 05 ??
Old 01-07-2009, 09:01 PM   #11
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
The USDM 05 are NOT 4-pots, they are sliding 2-pots exactly like yours only with a longer bracket to clear the larger rotor. IIRC the 05 WRX rears are EXACTLY the same as yours. They will be of limited benefit, if anything the swap will just increase your front bias UNLESS you also do the larger 'H6' rotor conversion at the rear.
See the Compiled brake information thread and Notes on Brake Interchangeability in the Brake Supersticky.
UkNuck is offline   Reply With Quote
Old 01-07-2009, 09:34 PM   #12
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Brake setup I like is the LGT front brakes and H6 rear rotors
Patrick L is offline   Reply With Quote
Old 01-07-2009, 09:56 PM   #13
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
oh shoot .... i thought all the wrx has 4 pots .....
what about 06 ??
lgt front and H6 rear rotors with same rear brake ??
Old 01-07-2009, 10:32 PM   #14
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
well the 05 LGT (315x30mm rotor) fronts require use the whole front brakes. Caliper, brakets, pads and rotors. Stock line will work. The H6 rear requires only the different caliper braket and rotor as it's just large in Diameter and you will have to remove the dust plate.
Old 01-07-2009, 10:35 PM   #15
mdungelman
Member#: 97251
'13 Impreza 2.0i
06/07 WRX are the only ones with 4-pot/2-pot. And the H6 upgrade involves your stock caliper with a different caliper bracket to accomodate the larger rear rotors.
Old 01-07-2009, 10:35 PM   #16
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
what is H6 rear ??
Old 01-07-2009, 10:38 PM   #17
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
better to get 06/07 wrx brake set ??
cause i want something that looks good .... ^^
thank you
Old 01-07-2009, 10:42 PM   #18
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
please... read the threads I posted and then post back if you still have q.s
don't forget wheel clearance
Old 01-07-2009, 11:03 PM   #19
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
I'm a bit skeptical of the whole stainless lines thing. I've heard everything from "huge difference" to "unnoticable."
I have next to zero experience with them, however there is something which nags me: brakes run at very high pressures. This makes me think that brake lines, from the factory, probably integrate a braid or two somewhere along the line. I've certainly used full plastic hose rated all the way out to 5kpsi, but it's actually a hell of a lot stiffer than any braid-reinforced hose.
Actually, on searching, it seems that most patents describe 5 layers: one tube for contact with the fluid in question, two braids (fiberglass is mentioned several times) and two rubber layers (one outside, one between braids). My guess is that no stainless braid is going to be any better than that.
sniper1rfa is offline   Reply With Quote
Old 01-07-2009, 11:21 PM   #20
mdungelman
Member#: 97251
'13 Impreza 2.0i
I don't think its so much about a brake lines ability to hold 5,000psi as it is its non-ability to expand under hard braking.
And the 4/2 pot brake setups obviously perform better(and look better) than the 05 wrx brakes. Hence a 6 piston difference. Don't get these just because they "look" better than the stock brakes. Function>Form. All depends how much you're willing to spend brother. Get used stuff on teh cheap.
Old 01-07-2009, 11:26 PM   #21
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
I'd wager that glass is far stiffer than most steel.
Old 01-08-2009, 12:51 AM   #22
chazly413
Member#: 151079
2005 2.5RS RBP
You also want to remember that you can only stop as fast as your tires will let you. Don't go upgrading to some huge brake kit if you're still on all seasons.
Old 01-08-2009, 12:53 AM   #23
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
this is more complicate than i thought ..... T,T
Old 01-08-2009, 12:57 AM   #24
chazly413
Member#: 151079
2005 2.5RS RBP
You should read this thread. PLENTY of GREAT info.
http://forums.nasioc.com/forums/show....php?t=1154081
Old 01-08-2009, 08:17 PM   #25
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
thanks for all the info .... im just gonna get pads ...
which company brake pads are good for 2.5i ??
Old WRX brakes vs. New WRX brakes Guru Imakuni Brakes, Steering & Suspension 20 03-14-2006 08:30 PM
Difference between a 01 2.5rs brake and 02 WRX brake iimiketii Brakes, Steering & Suspension 1 12-29-2004 01:57 AM
Impreza L brakes to WRX brakes SubaruPreza Brakes, Steering & Suspension 4 06-14-2004 02:22 AM
Goodridge WRX brake lines (on an RS) Ceramic brake pads yamarocket630 Car Part Reviews 2 12-11-2001 06:11 PM
WRX brake pads, was re: New WRX-STI Brakes Joel Gat, 1.8L Brakes, Steering & Suspension 6 04-12-2001 12:23 AM
