Old 01-07-2009, 04:10 PM   #1
ryan_13
Member#: 191604
2004 STI Stage 2
Default DIY: Gutter Guard Mesh Grill
I got bored this afternoon while it was snowing out so I decided to make something out of the grill off my 04 STI that I accidentally ran over a few weeks ago. It was already ruined so I figured I might as well try something to make it look better than the white striping paint job I had on it.
Here's the write up.
What I bought from Lowes:
(1) Snap in Gutter Guard - $1.98
(1) 7' All purpose Snips - $8.98
(1) .85 oz. Plastic Epoxy - $4.98
(1) Valspar Plastic Spray Paint - $4.97
Borrowed a friend's Dremel for cutting the factory grill
I then outlined the factory grill on the Snap in Gutter Guard
Then I cut out the outline leaving approx. 1/4" from outline to give myself a little room to screw up.
Then took the Dremel to the factory grill to remove the pillar. (notice the cracks in the grill to the left...looked like hell)
I then put a layer of epoxy on the front rim of the grill and put the cut piece of Gutter Guard centered on it. I then found a few paper waits left over from the weekend to keep presure on the epoxy. I let it sit for about 30 mins.
After it was dry enough to handle I took the Dremel and cleaned off the extra grill guard. Then I took some fine grained sand paper to clean up the edges a bit more.
I then took the plastic spray paint and put 3 coats on it. This paint did not require any primer.
Let it dry by my heater for an hour or so...
Went out to throw it on the car to see how it looked.
This mini project took roughly two hours and I did it right in my apartment with very minimal tools. I did not make this to win any awards, I just did it to make the broken grill look a little better until I can buy one that I like.
This is my first DIY write up so be kind.
If I missed anything or you have any questions/comments feel free to post up.
Thanks for looking!!!
ryan_13 is offline   Reply With Quote
Old 01-07-2009, 04:14 PM   #2
STIckySTIfee
Member#: 162812
2004 STI
Like the idea of bringing the mesh to the front, makes the front of the car look more...whole i guess. Not a big fan of the solid lines down the front tho, wonder how it would look if the pattern was un-obstructed the whole way across.
good work tho
STIckySTIfee is offline   Reply With Quote
Old 01-07-2009, 04:21 PM   #3
ryan_13
Member#: 191604
2004 STI Stage 2
I actually have a 20' roll of mesh guard that I was going to used if I didn't like this one. I'll deal with this one for now and if i get sick of it I'll do it over with the un-obstructed stuff.
thanks for the input!
Old 01-07-2009, 04:28 PM   #4
25mphnext2miles
Member#: 192879
2003 wrx
silver...till i wrap it
can i get a bite of that number one cheeseburger?
not too bad man, and i kinda like the solid lines. Do they not sell black gutter guards? JW.
pretty cool DIY though.
25mphnext2miles is offline   Reply With Quote
Old 01-07-2009, 05:42 PM   #5
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
I think I would have liked it more if the gutter guard was stuck to the back instead of the front. Good work on a DIY though.
100_Percent_Juice is offline   Reply With Quote
Old 01-07-2009, 05:50 PM   #6
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Or if you take a little off all edges and get it in the middle! Another way to achieve this would be to saw right through the middle of the whole thing lengthwise and epoxy sandwich it all back together with the new grille in between. I've been wanting to do this for a while just haven't had the cajones.
Good work on this though I like it in the front for a 2hr diy! Props!
JavaBot is offline   Reply With Quote
Old 01-07-2009, 06:06 PM   #7
2.5GTLegacy
Member#: 111219
Looks really cheap, but whatever floats your boat.
2.5GTLegacy is offline   Reply With Quote
Old 01-07-2009, 06:26 PM   #8
sleepersti04
Member#: 146554
2004 STi WRB
30R
nice DIY
sleepersti04 is offline   Reply With Quote
Old 01-07-2009, 07:59 PM   #9
Pohenegamook
Member#: 134262
cyka blyat
yea the solid line make it look ghe-to!
Do it again with a consistent mesh and
Pohenegamook is offline   Reply With Quote
Old 01-07-2009, 09:46 PM   #10
ryan_13
Member#: 191604
2004 STI Stage 2
I considered doing this but then its almost just as stock because of the stock mesh that comes with it. I thought I would try something new that I haven't seen.
Thank you all for your posts!
Old 01-07-2009, 09:54 PM   #11
dub c
Member#: 145069
Keep It Sleazy
blueberry stoli for the wwiiiin! hahaha
looks alright, put it on!
dub c is offline   Reply With Quote
Old 01-07-2009, 11:17 PM   #12
DC16A2
Member#: 174357
2002 OBS
I'm surprised you went for this gutter guard type (with vertical lines), because there should be gutter guard mesh that's uniformly diamond shaped with no breaks. Available almost any hardware place. Clean job though =)
DC16A2 is offline   Reply With Quote
Old 01-08-2009, 07:04 PM   #13
ryan_13
Member#: 191604
2004 STI Stage 2
in my first pic i actually have a roll of the plain mesh. I just started with the other stuff to see how it would look. If i get sick of it Ill change to that stuff.
Old 01-08-2009, 07:13 PM   #14
d0ugch0i
Member#: 198861
2004 WRX
nice writeup. but putting it behind and a consistent mesh guard would look sickkk.
d0ugch0i is offline   Reply With Quote
Old 01-08-2009, 07:22 PM   #15
arrowscooby
Member#: 176615
??? sleeper
rex
not a big fan but to each his own. good effort though.
arrowscooby is offline   Reply With Quote
Old 01-08-2009, 07:42 PM   #16
1SiKWaGoN
Member#: 100263
2003 WRX Wagon
Looks pretty good. Very creative. Should have thrown it on with it being white just to see what it would've looked like. I'm interested in seeing that now. Looks great non the less.
1SiKWaGoN is offline   Reply With Quote
Old 02-20-2011, 10:05 PM   #17
TaylorAnderson
Member#: 262026
2004 WRX Sedan
looks real good man... nice job.
TaylorAnderson is offline   Reply With Quote
Old 05-19-2011, 06:19 PM   #18
Cooper2.5
Member#: 280630
1998 Impreza 2.5RS
Came out a lot cleaner than I was expecting.
Looks good. Are you goin to put the emblem badge back on?
Cooper2.5 is offline   Reply With Quote
Old 12-23-2012, 01:22 PM   #19
larful
Member#: 227838
2007 WRX
Nice!
larful is offline   Reply With Quote
Old 06-07-2013, 06:50 PM   #20
jakeh9477
Member#: 358791
pretty legit dude. taking the logo out was a no go for me though
jakeh9477 is offline   Reply With Quote
Old 06-08-2013, 12:38 AM   #21
asmith765530
Member#: 358825
2011 impreza STi
Pearl white
Brilliant! I was just looking at my hoodscoop the other day and noticed it was wide open i need to think of something like that to protect it a bit more.
asmith765530 is offline   Reply With Quote
Old 01-08-2015, 11:28 PM   #22
OpenHeadShot
Member#: 399420
thats actually pretty awesome to do
OpenHeadShot is offline   Reply With Quote
Old 05-19-2016, 01:10 PM   #23
pdcon37
Member#: 447237
some good ideas on here
pdcon37 is offline   Reply With Quote
Gutter Guard, Gutter Helmut, Gutter etc., Recommend me one OriginalSin Off-Topic 11 09-21-2009 11:56 AM
DIY: 2.5RS Emblem in Mesh Grill MykuL Interior & Exterior Modification 2 12-30-2008 12:34 PM
DIY: Custom Mesh grill for a GC MykuL Interior & Exterior Modification 20 10-12-2008 07:47 PM
DIY: uber ghetto mesh grille juniorbeatbox35 Interior & Exterior Modification 16 09-04-2008 02:44 AM
Asking for gutter guard grill mod instruction au112 Interior & Exterior Modification 10 05-22-2001 10:14 AM
