Old 01-07-2009, 04:51 PM   #1
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
Default Gruppe-S UEL Header questions
Thinking about picking up this header and was wondering if I would be able to install it with my stock wrx oil pan. I've heard of some headers that will need a sti oil pan to clear?
02aspenwrx is offline   Reply With Quote
Old 01-07-2009, 04:58 PM   #2
allmotorhatch
Member#: 174549
2002 wrx
black
you will be able to use your oil pan on your wrx if you were using there equal length you would need an sti oil pan.
allmotorhatch is offline   Reply With Quote
Old 01-07-2009, 05:00 PM   #3
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
Awesome! I Appreciate it.
Old 01-07-2009, 05:46 PM   #4
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Very good headers.........i had no problems at all with mine.
JMK508 is offline   Reply With Quote
Old 01-08-2009, 11:11 AM   #5
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
did you order them yet?
Marlons101 is offline   Reply With Quote
Old 01-09-2009, 01:27 AM   #6
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
Picking them up this weekend!
Old 01-09-2009, 01:29 AM   #7
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
You will need to swap out your oil pan for one off an STi.
illmatic is offline   Reply With Quote
Old 01-09-2009, 01:55 AM   #8
1sicWRX
Member#: 104631
96 Cobra, TBird SC
88 Mustang 5.0
^^^^Bad info here. You will be fine with your WRX oil pan. Here is the link for technical info. http://www.gruppe-s.com/Subaru/subex.htm
1sicWRX is offline   Reply With Quote
Old 01-09-2009, 10:20 AM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
I have this header and the stock oil pan. It fits fine, it is nowhere near the oil pan.
Old 01-09-2009, 03:40 PM   #10
Chuck H
Member#: 20442
Just be prepared for some additional turbo lag if you're basically stock and have already had your tune optimized for your stock manifolds/crosspipe. I put them on my 03 WRX a few years ago after having my setup all tuned for my stock manifolds and lost 20 hp, a ton of mid-range torque, and about 500 RPM in spool. To be fair, though, I had a custom tune that was optimized for the stock pre-turbo exhaust and spooled MUCH faster than stock and had WAY more mid-range power. My tuner was able to re-tune my car to get most of the power back, but could never get the super-fast spool that I had with the stock manifolds.
Chuck H is online now   Reply With Quote
Old 01-09-2009, 04:31 PM   #11
1sicWRX
Member#: 104631
96 Cobra, TBird SC
88 Mustang 5.0
This is true. With the 2.5l motor however you will see a gain in performance across the entire powerband. However, with the 2.0l, you will certainly lose some low end torque but gain a significant amount of mid range and top end power.
Old 01-13-2009, 12:21 PM   #12
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
I've got a vf34 and all the supporting mods + EWG. I found a deal on the gruppe-s so I had to jump on it. I'll let my tuner see what he can bring out of it. Im now contemplating on just selling the header and just porting my stocker. We'll see.
Old 01-13-2009, 12:37 PM   #13
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
I dont think youll regret it. Are you going to wrap your exhaust? what ewg kit you go with?
Old 01-13-2009, 01:55 PM   #14
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
I've been thinking about wrapping it. I went with the grimmspeed ewg.
Old 01-13-2009, 02:05 PM   #15
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
do you happen to know the inlet diameter of the header and uppipe?
Old 01-13-2009, 02:07 PM   #16
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
I sure don't. I bet we can run some searches and find out.
Old 01-13-2009, 02:12 PM   #17
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
reason i asked was i got the gruppes uel header and iag ewg uppipe. i think my uppipe is 2.3ID from the header, then tapers down to a 2" velocity stack...then tapers again to 1.7id which is the same as the turbo inlet? I dont really have a point in this I just wanted to know the ID of the grimmspeed as that was my first option to go with for the ewg but found a killer deal ona bnib iag ewg kit
Old 01-13-2009, 02:18 PM   #18
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
No, you've got a point. Let's see if we can get someone to point this out for us and or one of the grimmspeed people to chime in.
Old 01-13-2009, 04:06 PM   #19
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
i say f it and get a alky kit!
ownnij is offline   Reply With Quote
Old 01-13-2009, 04:36 PM   #20
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
02aspen what other mods do you have along with the header?
Old 01-13-2009, 05:21 PM   #21
ownnij
Member#: 70459
he has a vf34 with supporting mods including a ewg.
Old 01-13-2009, 05:31 PM   #22
Slayer_X
Member#: 170045
2004 WRX
How about with a 2.5l hybrid?
Slayer_X is offline   Reply With Quote
Old 01-14-2009, 08:51 AM   #23
gtfaded
Member#: 142322
2002 wrx
wrb
I am in the market for uel headers as well, i already have a 2in uppipe and 3in down and catback as well as a tune for it ( actually a re-flash by vishnu) but your saying that i'm going to lose power w/ the headers? i may just skip that mod all together then. Especially if im going to loose my quick spool, the whole reason i wanted to get them was to improve that.(swapping in a vf34 soon) But on gruppe-s they point out which headers will need an oilpan swap, and also have dyno charts on their headers.
gtfaded is offline   Reply With Quote
Old 01-14-2009, 02:38 PM   #24
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
that dyno chart is on a sti i believe...not a 2.0wrx
anybody find the size of gruppes header and grimmspeed uppipe ID?
Old 01-14-2009, 02:54 PM   #25
jays05
Member#: 78165
05 STI 35r + e85
I measured the collector on my gruppe-s UEL header and it was right around 2.35" ID.
jays05 is offline   Reply With Quote
FS NY: Heat coated Fujitsubo EL header, Gruppe-S UEL header, STi uppipe garface Engine/Power/Exhaust 27 05-07-2009 11:00 AM
FS : Gruppe-s UEL header and Upippe WRX_Mike SCIC Private Classifieds 5 03-18-2009 11:05 AM
Gruppe-s UEL header owners, chime in: Gaskets flatthump Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 10-25-2008 12:40 PM
WTB: Gruppe-S UEL Headers ASAP medrad_man Private 'Wanted' Classifieds 3 10-01-2008 12:19 AM
