Old 01-07-2009, 08:38 PM   #1
speed_ga
Member#: 188906
1999 Legacy SUS lmt.
Black Cherry
Default Lower Radiator hose busted...Now car overheats...?
Ok yesterday my friend said he smelt antifreeze....so I popped the hood to find that I had no anti-freeze in my expansion resevoir. So I put some in and later that day found a knife-like slash in my lower radiator hose. I replace the hose and refilled with anti-freeze.
Here's the problem....While idleing...the car will run great and at normal temp....even when I revved the car to 2500rpms after refilling to burp the engine.
Now when driving down the road....my expansion resevoir tank will fill up to the top....way past the full line. and my temp gauge will go to hot.
Anyways, does anyone have any ideas on what the problem is.
It's 1999 subaru legacy with the 2.5 EJ25
speed_ga is offline   Reply With Quote
Old 01-07-2009, 08:53 PM   #2
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Assuming its not the thermostat or water pump id say first make sure there is not any air bubbles in the cooling system anywhere.
stretchedk7 is offline   Reply With Quote
Old 01-07-2009, 08:55 PM   #3
speed_ga
Member#: 188906
Black Cherry
whats the best way to get rid of the air bubbles?
Old 01-07-2009, 09:55 PM   #4
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Sorry for the slow response. When the car is cold, remove the cap from the upper coolant tank abover turbo and make sure its full, then fire up the car and turn on the heater. Run the car and continue to fill this tank until the burping has stopped. If that doesn't help, you can take the cap off the radiator when the car is cool and run it again.
Old 01-08-2009, 05:50 PM   #5
speed_ga
Member#: 188906
Black Cherry
thanks so much!!
Besides the fact that I was sold a faulty thermostat that I had to replace... The burping really helped and now it's back to normal...or so I hope it is
mishimoto lower radiator hose sndc5 Engine/Power/Exhaust 3 08-25-2009 05:25 AM
Brand New Samco Sti Lower Radiator Hose!! Only Lower Hose New! Dugansti Engine/Power/Exhaust 0 12-12-2008 09:34 PM
WTB: WRX Water pump, Thermostat housing and lower radiator hose? CUNNINGHAM Private 'Wanted' Classifieds 1 04-13-2007 11:52 AM
NIB perrin LOWER radiator hose RED w/free scuffed up top one Sti-lin' Engine/Power/Exhaust 2 02-01-2007 01:20 PM
Best Lower Radiator Hose I can get. Dre2932 Normally Aspirated Powertrain 0 04-07-2004 12:34 PM
