Old 01-07-2009, 09:54 PM   #1
chargerbry
Member#: 154007
2004 WRX Evo3 16g'D
07 6 speed
Default Anyone have any problems waiting the 105k for timing belt change?
I now have 86k on my car and saw in my book that the timing belt doesn't have to be changed till 105k. That to me seems like a lot to me. I have worked on cars all my life and have never seen an interval that high. Anyone have one break before 105k? I'll wait that long if I can(Lazy if you know what I mean) But if they don't make it that long sometimes I want to do it at 90k or so.
Thanks for the input
chargerbry is offline   Reply With Quote
Old 01-07-2009, 10:37 PM   #2
turd_ferguson
Member#: 114609
I did mine at something like 115,xxx miles and the belt looked like it could have gone another 50,000. The recommended 105k interval should be fine.
turd_ferguson is offline   Reply With Quote
Old 01-07-2009, 10:51 PM   #3
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
I wouldn't go more than 105k miles. The tensioners on these cars seem to go bad, plus its better to have a new water pump/thermostat installed at the same time. I did mine at 95k miles, with a new water pump, tensioner, idler pullies. The belt istself looked brand new.
rexman2002 is offline   Reply With Quote
Old 01-08-2009, 12:37 AM   #4
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
Is that what they recommend for the USDM STI too? JDM version is 100K Kms = 62,000 miles
Micky is offline   Reply With Quote
Old 01-08-2009, 12:37 AM   #5
chargerbry
Member#: 154007
2004 WRX Evo3 16g'D
07 6 speed
Cool. Thanks for the input
Old 01-08-2009, 02:16 AM   #6
Feign
Member#: 68604
06 STi
http://www.subaru.com/owners/schedules/index.jsp
And to mirror everyone else, I just did mine this past weekend at ~110,000mi. Belt was a little worn from a bad idler/pulley but otherwise looked great. Replaced the thermostat while I was in there along with 3/4 of those expensive ass idlers/pullies and the tensioner.
Feign is offline   Reply With Quote
Old 01-08-2009, 08:47 AM   #7
rkramer
Member#: 118209
2015 WRX Limitec
105k (or more) is VERY common on vehicles made since 2000. Ironically it seems domestics are kicking imports around in this area, some imports still require a 60k change interval. Read around here, there are VERY few threads of a timing belt or water pump actually failing. It is probably more the tensioner than anything else that is prone to fail.
Old 01-08-2009, 11:49 AM   #8
sigurd
Member#: 128721
2002 impreza WRX
psm
yeah no reason to do it early really. did mine at 103k and it still looked fine.
I did the waterpump, tensioner, and thermostat also.
sigurd is offline   Reply With Quote
Old 01-08-2009, 03:36 PM   #9
strohausii
Member#: 26770
'02 WRX
midnight black
Mine was done at 110k, by my local dealership w/ tensioner and idlers. They steathoscoped the water pump (and idler bearings) as that was a concern for me and they said the water pump was fine but the idlers need replacing, the tensioner was a required replace for the T-belt maintainance.
Then the AC idler siezed 6-9 months after the timing belt was replaced.
Last edited by strohausii; 01-14-2009 at 10:39 AM. Reason: //reworded for clarity//
strohausii is offline   Reply With Quote
Old 01-08-2009, 11:03 PM   #10
chargerbry
Member#: 154007
2004 WRX Evo3 16g'D
07 6 speed
Cool. Thanks guys. I'll wait and do the water pump and idle pully at the same time.
Old 01-08-2009, 11:11 PM   #11
Scav1180
Member#: 56832
2004 STI
Java black
I wish I made it to 80k..
70k..
blown bearings.. shreded belt.. 2 bent exhaust valves.. 3k out of pocket.. lol
Scav1180 is offline   Reply With Quote
Old 01-13-2009, 08:03 PM   #12
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
I think mine went 152k until it got changed (not original owner so don't know for sure). The belt was pretty worn along with pretty much everything else minus the tensioners.
RallyLegacy is offline   Reply With Quote
Old 01-13-2009, 08:05 PM   #13
P-Tein
Member#: 197399
Blue 2006 WRX TR
1990 Mustang GT
I wouldn't go past 100,000 miles without replacing the timing belt.
P-Tein is offline   Reply With Quote
Old 01-13-2009, 09:56 PM   #14
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
I don't understand why everyone brings the water pump into question. I've owned 3 Subaru's, all with over 200k miles, and they all have/had the original water pump.
Tensioners and idlers are a different story though. I just had an idler sieze and blow up on me last week. I got lucky though, eventhough the cam sprocket jumped 3 teeth I didn't bend any valves.
my4isflat is offline   Reply With Quote
Old 01-13-2009, 10:01 PM   #15
David Langseth
Member#: 130292
2002 Forester
I did mine at 109K on a stock 2001 Forester and the T-belt was in great shape. It looked like it had plenty of life left in it. The accessory belts, on the other hand, were ready to be replaced. The cogged idler was running a little rough, so I replaced that, but the other idlers and tensioner felt perfectly smooth, so I left them on. I did replace the water pump as a precaution - though it too seemed in great shape. Absolutely no leakage from the shaft seals, so I left them in place.
David Langseth is offline   Reply With Quote
Old 01-13-2009, 11:51 PM   #16
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
wonder if there would be a way to tell if buying from a dealer. looking at a car with 101k miles
wildacex187 is offline   Reply With Quote
Old 01-14-2009, 12:13 AM   #17
yellowmonkeyboy
Member#: 157124
2002 Wrx
i wish i read this thread , i did a timing belt, water pump change, and all acc belts,, at about 100k and now at 109k my a/c tension pulley siezed, im kinda scared that the other pulleys might have the same issue...(something that would effect my timing belt -something important)
yellowmonkeyboy is offline   Reply With Quote
Old 01-14-2009, 12:30 AM   #18
rkramer
Member#: 118209
2015 WRX Limitec
not really, even if you look at the belt they can look surprisingly good. I would say probably not, people usually don't do major maintenance and trade it off, most likely the upcoming cost of the timing belt was possibly one of the reasons they got rid of it.
Old 01-14-2009, 10:35 AM   #19
strohausii
Member#: 26770
'02 WRX
midnight black
In regard to the water pump, I don't think the concern is so much subaru specfic as it used to be a general rule with T-belt replacement on dual overhead cam engines. I had a previous car that was SOHC and did not have to remove the T-belt to replace it.
//edited my previous post//
Old 01-14-2009, 10:28 PM   #20
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
cool thanx for the tip. did everybody here take it to a shop or did anybody do it themselves?
Old 01-14-2009, 11:07 PM   #21
Feign
Member#: 68604
06 STi
Did it with a few extra hands for support. Surprisingly easy. Get a 10mm allen key or socket adaptor to hold the driver's side cams in place.
Old 01-15-2009, 10:57 AM   #22
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
My local dealer quoted me $425 parts + labor for the job (as opposed to $1100+ elsewhere), 2-3 hours max, and they said I can bring in the accessory belts if I would like (Subaru OEM timing belt + components). Not bad, that's very cheap service per 100K miles.
JamesWilson2 is offline   Reply With Quote
Old 01-15-2009, 09:20 PM   #23
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
'99 Forester went to 103K miles before the change. Everything went good except the the cover broke, got one used dirt cheap.
surowrxa is offline   Reply With Quote
Old 01-16-2009, 03:29 AM   #24
madmax718
Member#: 172501
That seems sorta correct, but pricey for the parts.
madmax718 is offline   Reply With Quote
Old 01-21-2009, 11:08 AM   #25
AWDrifter21
Member#: 51112
2004 WRX-sold T_T
now 2005 STi ^^
Tensioners and idlers ? could someone explain them and their importance.
Also... any recommendations to buy timing belt ? dont want to buy from subaru dealership.
AWDrifter21 is offline   Reply With Quote
Cheapest Garage For Timing Belt Change sciroccokid New England Impreza Club Forum -- NESIC 17 09-03-2008 10:45 AM
Cam locking tools for timing belt changes... where to rent/borrow? Buttsy Service & Maintenance 2 02-10-2008 08:56 PM
Tools needed for timing belt change? '95 Legacy highspeed11 Legacy Forum 3 11-05-2006 05:16 PM
good price for timing belt change? tmaler13 Normally Aspirated Powertrain 6 07-22-2002 10:35 PM
