Old 01-08-2009, 09:50 AM   #1
Lordhowe
Member#: 35265
Default Quick question about accessory belt tension
I searched and found several helpful links but this one is the best:
http://forums.nasioc.com/forums/show...+tighten+belts
I can't really post #14 of the page (too small), can anyone please upload another one? or explain to me how to measure the tension of my belts?
Lordhowe is offline   Reply With Quote
Old 01-08-2009, 10:24 AM   #2
rkramer
Member#: 118209
2015 WRX Limitec
I can't really read the page (too small), can anyone please upload another one? or explain to me how to measure the tension of my belts?
If your accessory belts squeel, it is too loose. Technically there is a tool to empirically measure it, but generally it is just push on it some, it shouldn't easily move much, no more than 1/2 an inch.
Old 01-08-2009, 10:47 AM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
^^^ that's pretty much what the page you can't read says - it gives some actual deflection figures (7 - 11 mm depending on which belt / whether old or re-used) but in practice you aren't going to be able to measure the deflection OR the applied force to that precision
UkNuck is offline   Reply With Quote
Old 01-08-2009, 11:58 AM   #4
rick-l
Member#: 33868
2003 wrx
srp
Just a thought
Having the belt only deflect 5/16th of an inch when you press on them with 22 pounds of force over a belt span of about 10 inches is very tight.
You wouldn't be able to rotate the belt (twist) 90 degrees in this span would you?
rick-l is offline   Reply With Quote
I need a diagram or good pics of the accessories belt tensioner... jacobsen1 Service & Maintenance 14 10-07-2010 11:39 AM
accessorie belt tensioner question? 05 wrx Subey03 Newbies & FAQs 5 05-21-2010 12:33 AM
Quick question about timing belt guide pulley spoolinej25 Newbies & FAQs 0 04-10-2010 09:33 PM
Quick question about new belts and installation Drew888 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-19-2005 04:22 PM
Accessory belt tensioner pulley- making a squealing noise JayGold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-08-2004 04:16 PM
