Old 01-08-2009, 11:14 AM   #1
bcristea
Member#: 11343
2008 STi
Default Removing Tire from Rim?
Ok,
This may or may not sound crazy.
Has anyone removed tires from rims by cutting them off? In my case I don't care if the tire gets destroyed (no tread life left).
I want to avoid having them dismounted because every time I take rims in they always damage them.
Anyone?
bcristea is offline   Reply With Quote
Old 01-08-2009, 12:43 PM   #2
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
I have and it wasn't fun. You will damage the wheel more than the shop will.
I had a old junker tire and wheel. I tried a hack saw,bolt cutters and a cut off wheel on a drill. Steel belts don't like to be cut and the bead(with steel cable inside) is harder to cut. I forgot how I even got the bead to pop off the rim but you need to pop it off first to cut the bead.
GDR is offline   Reply With Quote
Old 01-08-2009, 12:58 PM   #3
STIckySTIfee
Member#: 162812
2004 STI
you can always just try one wheel and if its a pain in the a$$, then just take the other 3 to a shop
STIckySTIfee is offline   Reply With Quote
How do you remove "Chrome" from rims? Cybergeist Tire & Wheel 7 08-18-2009 05:26 PM
How can I remove tires from wheels? RootUsr Tire & Wheel 24 04-21-2009 06:28 PM
Removing paint from rims Wannascooby Interior & Exterior Modification 12 01-30-2007 01:47 AM
Removing tires from wheels ? ZMANNH25rs Tire & Wheel 11 12-14-2005 04:36 PM
Removing tires from one set and re-installing onto another JF1GD2 Tire & Wheel 2 01-28-2004 07:19 AM
