Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 01-08-2009, 01:04 PM   #1
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Default Back to back Camshaft dyno plots??
Is there any no bull****, real information, regarding power pickup with camshafts in our engines?
If you have some back to back dyno plots or testimonials about your cams, please post them up.
wrxwhat is offline   Reply With Quote
Old 01-08-2009, 05:29 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I'd love to find some concrete info but there really is no such thing as back to back when it comes to dynoing a car, pulling the motor to swap cams, then dynoing again. That's a lot of work and time in between just to compare numbers.
I changed to many things when I installed my cams so I can't attribute all my gains to just the cams.
Old 01-08-2009, 05:59 PM   #3
jays05
Member#: 78165
05 STI 35r + e85
I changed a lot of things also when I installed my cams (cosworth 278/274 avcs) but I'm happy I got em, besides the fact that the first set of cams broke. Comparing maf volts to boost pressure, the difference is night and day. At 22psi on pump/93 with the cammed built motor I made slightly more HP than my stock motor+35r did at 26psi on 93+meth.... and it made more power with 5 degrees less ignition timing and a full point AFR richer. But I also changed the fmic, headers, uppipe, had some head porting done, larger valves, pistons/rods, etc.
jays05 is offline   Reply With Quote
Old 01-08-2009, 08:29 PM   #4
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
I wish I could rev my engine out to make use of some of the higher duration camshafts.. I really wish there was some solid evidence of how much just camshafts affect our engines.
Old 01-08-2009, 10:13 PM   #5
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Eventhough I'm only rocking an 18G right not the car itself is much more excited in the upper rpm range and there's not a day when I don't get jiggy @ 7600rpm. I have the 3076 ready to go and I'm stoked because if my car feels this good with the 18G on it, it's gonna be re-goddamdickulous with the 3076 on + cams.
Old 01-08-2009, 10:30 PM   #6
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Just think if your car was tuned properly
BTW are you going to make it to the track this weekend?
Infamous1 is offline   Reply With Quote
Old 01-08-2009, 10:51 PM   #7
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Sup man, I just changed my plugs out. The very same plugs I put in the day before we went to the track last. I put the wrong damn heat range in there and those plugs had been running a little hot. I wonder if that may have been contributing to the knock you where logging? Compression still 160 across the board.
I'm gonna be out in LA Friday night but I'll try and make it to the track. Maybe you can log me again.
Old 01-08-2009, 11:28 PM   #8
dmross
Member#: 2818
2000 2.5RS
I've posted this up few times but I'll post it again. This was a 2.5L with 2.0 STI heads, stock cam vs kelford 272 cam, everything else was the same. Picked up almost 80whp at 7000rpm.
http://chrono.firex.org/images/cam_comparison.jpg
dmross is offline   Reply With Quote
Old 01-08-2009, 11:56 PM   #9
chad1979
Member#: 173122
96 LEGACY/wrx
black
Holy Sh_t!!
chad1979 is offline   Reply With Quote
Old 01-09-2009, 01:54 AM   #10
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Awesome, any headwork done with the camshafts?
Old 01-09-2009, 10:42 AM   #11
dmross
Member#: 2818
2000 2.5RS
The heads were large-port heads to begin with (non-AVCS) but they were the same in both plots. The stock 2.0 cam profile in the 2.0 head is simply too mild for the 2.5 bottom end. If I was running 2.5 heads with stock STI cams it would probably fall between the two plots.
Basically, I think this is a best case scenario because it's a hybrid. You may not see the same magnitude of gains in another setup until you're pushing a lot of air through the motor. There's a couple of posts showing tremendous gains with the GSC cams on TopSpeeds time attack car, you might want to search for those as well.
Old 01-09-2009, 10:55 AM   #12
Dobbs
Member#: 28291
2015 WRX
http://forums.nasioc.com/forums/show....php?t=1456543
2.5 + GSC stg 2 cams + gt35r with spool like a gt30r... ya i'd say they work well
Dobbs is offline   Reply With Quote
Old 01-09-2009, 11:45 AM   #13
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Again, I'm not trying to say this is what TopSpeed is doing, but if I wanted to push a product, I'd make sure the cams I wanted to sell "made more horsepower" than another manufacturer, thus why I wanted more independent results.
Old 01-09-2009, 11:48 AM   #14
modaddict
Member#: 95840
sold to a good bud
awaiting next car
That's not 30r spool silly.....
.......ask me how I know.
modaddict is offline   Reply With Quote
Old 01-09-2009, 12:45 PM   #15
Dobbs
Member#: 28291
2015 WRX
spool was a misnomer... i meant identical power at lower rpm's
Old 04-12-2009, 06:40 PM   #16
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
what version 2.0 STi heads and cams where you using?
Surfer Steve is offline   Reply With Quote
Old 04-12-2009, 08:23 PM   #17
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
Just about any good aftermarket cam with the right supporting mods is going to pick you up at least 60whp.I personally prefer kelfords and with talking with Kevin Ban the owner of Kelford he grinds a lot of the custom cams for the Rigolis and their **** flies.
john 1badSTI is offline   Reply With Quote
Old 04-12-2009, 09:39 PM   #18
S L O W W R X
Member#: 95109
No but thats what you are implying and its pretty ****ty of you to do that.
S L O W W R X is offline   Reply With Quote
Old 04-12-2009, 10:04 PM   #19
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
aint that big of a deal man. but i agree with you, why shouldnt they post their results?
godforbid67 is offline   Reply With Quote
Old 04-13-2009, 10:08 AM   #20
dmross
Member#: 2818
2000 2.5RS
Version 6 type RA. Larger ports, no AVCS.
Anyone else gonna be a SW nerd and watch all 6 movies back to back to back? blue-sun Off-Topic 21 04-12-2009 12:12 AM
rollin, rollin...back to back...to.... Deezy1678 Off-Topic 30 09-14-2008 04:15 PM
RACECOMP gets 2 back to back podiums at Sebring Panoz Race(wanted to share)with MID-A RaceComp Engineering Mid Atlantic Impreza Club -- MAIC 52 02-10-2007 01:13 AM
2002 SCCA rallies back to back on SpeedTV gpd323 North West Impreza Club Forum -- NWIC 7 07-16-2002 10:53 PM
Back-to-back Auto-Xes in Rome, NY 7/27 & 7/28 Mike Smith Tri-State Area Forum 6 06-11-2002 09:23 PM
