Old 01-08-2009, 04:53 PM   #1
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
Default Group N Engine Mount Fitment Issues...NA related...
i'm having my headgasket/TB/cams replaced at the dealership right now. unfortunately, no time or tools to do this on my own.
anyway since the engine was being pulled i ordered up a set of the group n engine mounts. the tech working on the car called and told me that the mounts would not fit and that the plate/mount were for turbo applications only. i was under the assumption that the group n mounts fit all impreza's 02-07 and even furter back.
part #'s
D1010FE110
D1010FE120
car
03 OBS EJ251
i told him if it was a fitment issue, then reuse the old plate...would this reduce the function/performance of the mount at all? i know it's a bit beefier.
have anyone of you had fitment issues with your NA imprezas? any help would be appreciated. thanks.
doubledribble is offline   Reply With Quote
Old 01-08-2009, 05:41 PM   #2
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
that tech is a moron seriously man! its the same block!!!!! i think he is just hating or too retarded .
they will definatly fit! and yes use the new plates they are of a much better design
watchunglava is offline   Reply With Quote
Old 01-08-2009, 05:41 PM   #3
Back Road Runner
Member#: 60082
2004 Forester STI
Uh...is the tech doing it wrong?
Did he say why they don't work?
Old 01-08-2009, 05:46 PM   #4
doubledribble
Member#: 42912
2003 Outback Sport
i assume if he took the old one off and oriented the GroupNs the same way it would be obvious if they fit. he said it had something to do with the bends in the plate they didn't seat right on the cross member...
Old 01-08-2009, 05:47 PM   #5
watchunglava
Member#: 168862
is your crossmember bent?
Old 01-08-2009, 05:48 PM   #6
watchunglava
Member#: 168862
Old 01-08-2009, 05:49 PM   #7
watchunglava
Member#: 168862
and if the guy wont do it here are install instructions
http://www.scoobymods.com/forums/sho...=&threadid=545
Old 01-08-2009, 05:54 PM   #8
Back Road Runner
Member#: 60082
2004 Forester STI
Yeah, just install yourself. All it takes is a floor jack. The only trick to the install is removing the pitch stop mount so the engine and tranny can shift forward/backward freely. Otherwise you'll never get the bolts back into the holes after you put the new ones on. This might have been the tech's mistake. I don't know... It's really an easy install for the most part.
Group N Engine Mount Fitment Issue... doubledribble Transmission (AT/MT) & Driveline 2 01-08-2009 12:48 PM
WTB: NEW group n engine mount n' 5 speed tranny mount GDA_WR1 Private 'Wanted' Classifieds 0 10-22-2008 01:14 AM
wtb: new sti stock engine mount / or group-n engine mount (CA) ttake Private 'Wanted' Classifieds 1 11-09-2007 11:07 AM
Cheapest Group N pitch stopper and Group N engine mounts? Steven Romero Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-09-2006 04:25 PM
Group N engine mounts, stock tranny mounts? bren wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 02-04-2006 12:00 PM
