Old 01-08-2009, 07:22 PM   #1
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
Default Temp gauge on dash is spiking red
My temp gauge in my gauge cluster will gradually go all the way to the red and then come back down to the neutral position. The car doesn't seem to be over heating but I wanted to know if it was an electrical problem anyone has heard of.
Ntercooled is offline   Reply With Quote
Old 01-08-2009, 07:47 PM   #2
GreenMarine
Member#: 36080
Thermostat sticking maybe??
How often has it done it??
~ Chris
GreenMarine is offline   Reply With Quote
Old 01-09-2009, 01:54 PM   #3
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
It does it at least once every time I drive.
Old 01-09-2009, 02:11 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
why do you think it isn't overheating? I'd trust the temp gauge more than a feeling. If the spike is instant, it probably electrical. if the spike is consistent with driving conditions, it is most likely actually overheating. (generally you don't get any symptoms of overheating until your head gasket lets go or your radiator blows an endcap, it will drive as good if not better than normal.)
Old 01-09-2009, 03:15 PM   #5
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
It drives normal. The gauge will slowly go up to the red and then slowly come back down to average like a minute later.
Old 01-09-2009, 03:36 PM   #6
leecea
Member#: 37359
2003 WRX
My first thought would be thermostat, as already mentioned by GreenMarineSVX.
leecea is offline   Reply With Quote
Old 01-09-2009, 07:30 PM   #7
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
I will have to check that out. Thanks everyone.
Old 01-09-2009, 10:37 PM   #8
dru_hill
Member#: 67661
2004 WRX sedan
Have you changed the coolant lately? Could be an air pocket.
dru_hill is offline   Reply With Quote
Old 01-10-2009, 11:46 AM   #9
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
Nope I have not in a while. I will try that first before I start shelling out too much money. Thanks
Old 01-10-2009, 12:29 PM   #10
my scoop eats babies
Member#: 174894
Err, yeah, that doesn't mean much. As someone mentioned, you would probably never be able to tell that your car was overheating if it weren't for the temp gauge, until your HG or something worse broke.
I'd get it looked at ASAP. It could be something as simple and cheap as a thermostat, but continuously overheating your engine, especially to the red, is putting your car at risk for other major & expensive issues. Blown head gaskets, warped or cracked heads, cracked block, etc etc.
my scoop eats babies is offline   Reply With Quote
Old 01-10-2009, 03:18 PM   #11
z&cobb
Member#: 12344
2002 2JC
blue
If you have a laser pointer IR thermometer, perhaps you could use it on parts of the cooling system/engine, when the gauge reads in the red.
z&cobb is offline   Reply With Quote
Old 01-10-2009, 07:25 PM   #12
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
I will get it checked out on Monday. Thanks Everyone
Busted temp gauge on '01 2.5 RS - Please help Neophyte Electrical & Lighting 2 03-21-2006 12:50 PM
Poll: How long will it take me to find a Greddy black 52mm oil temp gauge on nasioc? thechickencow Off-Topic 11 10-13-2005 06:36 PM
Temp gauge on cluster... is that oil or engine temp? gopsu Newbies & FAQs 1 10-02-2005 10:45 PM
Outside temp gauge on '04 STi chrisgru Electrical & Lighting 6 04-21-2004 01:00 AM
