Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 01-09-2009, 01:49 PM   #1
ggogll
Member#: 183283
2003 WRX
Default sqweeky belts?
alrite, so recently one of my belts have been sqweeking in my car, it happens most when my car is cold or its raining, also when i first start up my car and try to turn the wheel all the way to the left or right it has resistance as if it has no power steering and the belt sqweeks while im turning the wheel? any idea of what this is? the belts are about 2 months old if even so im thinking that they did not put the belts on correctly? thanks!
ggogll is offline   Reply With Quote
Old 01-09-2009, 02:19 PM   #2
pauli18c
Member#: 174553
2005 STi 360whp
345wtq on 93oct @ 20psi
belt not tight enough. tighten er up a few turns.
general rule of thumb is that you should be able to twist the belt sideways 90 degrees, but not any further. of course use common sense when applying pressure....
pauli18c is offline   Reply With Quote
Old 01-09-2009, 02:24 PM   #3
ggogll
Member#: 183283
2003 WRX
alrite thanks, the only problem is im not quite sure where the belt is located, i have an 03 bugeye so would u beable to point me in the general direction? thanks
Old 01-09-2009, 03:08 PM   #4
tdiz
Member#: 149040
2003 wrx
there is a DIY seatbelt mod you can do. It requires sanding down the ridges on the inside of the plastoc cover. search it up.
tdiz is offline   Reply With Quote
Old 01-09-2009, 03:09 PM   #5
tdiz
Member#: 149040
2003 wrx
lol delete.
Old 01-11-2009, 06:21 PM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Here, try this...
KillerBMotorsport is offline   Reply With Quote
Old 01-12-2009, 03:48 PM   #7
ggogll
Member#: 183283
2003 WRX
thanks for the diagrams, im gonna give it a try in a day or two when the weather gets a bit better, ill let u know how it goes tho thank you
Old 01-14-2009, 06:28 PM   #8
DC16A2
Member#: 174357
2002 OBS
I love it when people post up diagrams and such =)
DC16A2 is offline   Reply With Quote
wtb the two front belt ac belt and crank belt blackstidriver123 Private 'Wanted' Classifieds 2 12-12-2009 06:46 PM
Sqweeky clutch SHARP_DAL Service & Maintenance 16 09-16-2008 09:46 PM
Timing Belt? Drive belt? AzNStiImpreza Service & Maintenance 5 01-18-2004 11:44 PM
Timing belt installation for a PE belt? IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-27-2003 04:45 PM
60 K T belt = timing belt? DoinkMobb Service & Maintenance 10 07-22-2002 02:02 PM
