Old 01-09-2009, 01:22 PM   #1
Emperor WuRM
Member#: 169737
2006 Wrx Tr
Default symptoms of spun bearings
searched to no avail
I wrecked my car a year ago, finally finished getting her road worthy, I changed the oil and noticed about five pieces of copper shavings in the old oil. I know that this is a symptom of a spun bearing but I was wonding if there was anything else that the motor would do. Since I have been driving it, I have noticed that the engine Idles really rough, somtimes revs over 1K then just dies. There is also a tick coming for the motor. Not valves, not injectors, I have no idea what it is. I was wondering if there is a spun bearing would that cause this loud engine tick? any input is appreciated. Thanks
Emperor WuRM is offline   Reply With Quote
Old 01-09-2009, 01:25 PM   #2
dunk
Member#: 15359
Yes, bearing damange produces a tick or knocking sound that increases with RPM.
-Duncan
dunk is offline   Reply With Quote
Old 01-09-2009, 01:49 PM   #3
Emperor WuRM
Member#: 169737
2006 Wrx Tr
This can only happen if the motor is ran with low/no oil correct? I never ran the car with low oil...I am confused as to why this happened? The car did sit for a year before I drove it. But I primed the motor to get it lubricated....can bearing damage be caused if the timing belt skips?
Old 01-09-2009, 11:50 PM   #4
madmax718
Member#: 172501
It can happen under a variety of reasons. low oil is only one way. Even if the car did sit for a year, it generally doesnt do it. Oil is quite filmy, it will give protection (albiet marginal) to the bearings during startup until oil pressure is returned.
madmax718 is offline   Reply With Quote
Old 01-10-2009, 12:40 AM   #5
wuuusaa
Member#: 92894
2015 Wrx
it sounds like ****...pretty much sums it up. <<<< been through 2 motors so i should have some what of an idea by now. =(
Old 01-10-2009, 11:42 AM   #6
rdodger
Member#: 156447
99 18g'd 2.5RS-T
make a vid and put it on youtube for us to hear
rdodger is offline   Reply With Quote
Old 01-10-2009, 01:26 PM   #7
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
What oil are you running?
eurospek is offline   Reply With Quote
Old 01-12-2009, 11:20 AM   #8
Emperor WuRM
Member#: 169737
2006 Wrx Tr
mobil 5w30
full synthetic
Old 01-12-2009, 11:26 AM   #9
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
mobil 5w30
full synthetic
I would switch to something else immediately, just too many spun bearing threads running this oil.
Old 01-12-2009, 01:24 PM   #10
Emperor WuRM
Member#: 169737
2006 Wrx Tr
Really? Does the oil really matter that much? I read the OIL FAQ Thread which says oil is basically just preference, Mobil was rated according to the FAQ for 2006+ wrx. Motul and Royal Purple are not. What oil would you reccommend I run?
Old 01-14-2009, 07:44 AM   #11
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Yes because they all add different additives from different brands.
hangman is offline   Reply With Quote
Old 01-14-2009, 07:46 AM   #12
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Speaking from experience. When I used mobile 1, by the time an oil change would come around I found I was missing some oil. Usually 1/2 - 3/4 quart would disappear.
Switched to castrol syntech, saved some money, and what I put in is what I get out.
So it does make a difference. Mobile 1 is too thin, which is why it was disappearing
Bad Noodle is offline   Reply With Quote
Old 01-14-2009, 08:57 AM   #13
timmah
Member#: 54203
2011 WRX
Yup, I had the exact same symptoms. Been using Syntec for 40k miles now.
timmah is offline   Reply With Quote
Symptoms of a spun MAIN bearing? Chi_San Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-06-2009 08:19 PM
Will hot tank get rid of spun bearing remains CHEWY911 Built Motor Discussion 5 04-08-2009 10:50 AM
Symptoms for spun rod bearing? rougeben83 Normally Aspirated Powertrain 5 04-22-2008 10:55 AM
What are symptoms of wheel bearing problems? only1agam Brakes, Steering & Suspension 7 07-05-2005 05:13 PM
Symptom of wheel bearing going bad? txl146 Service & Maintenance 10 04-08-2005 12:56 AM
