Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Old 01-09-2009, 09:26 PM   #1
SedonaRed03WrX
Visiting NASIOC Timeout, again, because I created another account and couldn't leave well enough alone
Member Sales Rating: (30)
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
Default Lots of EJ20 Engine parts- parting out 2 engines
Parting out 2 complete EJ20's. One has 100k on it and one spun rod bearing. The other had 47k with 2 badly spun rod bearings. But both have good cylinder walls, and perfect for building. All parts priced to sell.
If there is no price Just PM me you're offer's
-Complete short block (one lightly spun rod bearing) Held 120-122 psi in all cylinders before heads were removed, 100k on it SOLD
-Complete short block 47k on it SOLD
-Intake manifold SOLD
-TGV's SOLD
-Alternator SOLD
-A/C pump w/bracket SOLD
-P/S pump (no bent pulley) SOLD
-P/S Resivor with hose'sSOLD
-Starter SOLD
-WRX Throttle body (missing IACV) SOLD
-complete wrx fuel rails
-OEM Turbo inlet SOLD
-Green brackets of death $free!!! lol
-OEM TB to IC coupler SOLD
-TMIC Intercooler brackets SOLD
-OEM air ram $15 SOLD
-OEM crank pulley (3) $5ea
-crank shaft timing gear (2) Both SOLD
-Upper water neck (under intake manifold) SOLD
-Oil pan with windage tray and oil pump pick up (both have a small dent that does not effect them) $10ea
-WRX Cams have 66k on them and look perfect still $45 for set of 4 cams one set sold
-Cam/timimg gears $12ea (Only the LH-IN gear is available)
-Crank position sensor (CPS) (2) $10ea
-Knock sensor SOLD
-EVAP solenoid SOLD
-Turbo mount brackets $5
-OEM flywheel (looks really good and could go right in with out surfacing) $15 one sold
-WRX Heads SOLD
-OEM Catted Up pipe (2) $15ea
-Ehaust manifold's $30 a set one left
-WRX engine mounts $20 a set
-Injector Wiring SOLD
-OEM mid pipe from a 02 wagon (will work with any GD body). Has 19k on it just been sitting in the garage
-OEM Down pipe has, 19k on it just been sitting in the garage
** I have a ton of stuff from these engines, if you dont see it listed just ask me and I probably have it.
Feel free to call or txt me any time. Im up early and awake usually until 1 or 2am.
Top feed Fuel rails and lines
WRX cams (really good condition)
Trades im looking for
STi block
4 matching Good rods and pistions for an EJ20
245/??/17 Tires used or new
600cc+ Injectors
and wagon parts
SedonaRed03WrX is offline   Reply With Quote
Old 01-11-2009, 03:55 AM   #2
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
WRX catted up pipe
IC brackets
WRX oil pan
Old 01-11-2009, 12:14 PM   #3
speedymaker
Member Sales Rating: (12)
Member#: 162070
2005 VF48 wrx wagon
pm'ed!!!!! let me know! i might be interested in more than what I just pmed about, i need to see what all I have already. thanks!
speedymaker is offline   Reply With Quote
Old 01-11-2009, 02:31 PM   #4
hybridpatient95
Scooby Scammer- Do Not Buy From User
Member Sales Rating: (11)
Member#: 127606
do you have the crank shaft timing gear? ill take it
hybridpatient95 is offline   Reply With Quote
Old 01-12-2009, 02:23 PM   #5
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
i have 2, Pmed ya
Old 01-12-2009, 07:22 PM   #6
h2oridr
Member Sales Rating: (16)
Member#: 151936
2003 wrx
Looking for a p/s pump.....let me know if there is still one... preferably the one with less miles on it if thats possible. Thanx
h2oridr is offline   Reply With Quote
Old 01-12-2009, 07:31 PM   #7
Phoryu2nv
Member Sales Rating: (35)
Member#: 30468
2003 EQTuned VF43Bug
ill take the inlet and bov hose
Phoryu2nv is offline   Reply With Quote
Old 01-12-2009, 07:52 PM   #8
excursionist
Member Sales Rating: (26)
Member#: 99283
sent u a pm
excursionist is offline   Reply With Quote
Old 01-13-2009, 01:04 AM   #9
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
Pm's replied, more pics up. Keep buying stuff guys.....
Old 01-13-2009, 05:20 AM   #10
excursionist
Member#: 99283
have not gotten a response
Old 01-13-2009, 11:21 AM   #11
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
to your second PM? I need to find out how much they weigh roughly so I can get you a quote. I had an emergency yesterday and didnt get time to but I will today.
Old 01-13-2009, 12:02 PM   #12
excursionist
Member#: 99283
pm sent
Old 01-14-2009, 02:48 AM   #13
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
t.t.t.
Old 01-15-2009, 04:56 AM   #14
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
bump for all PM's and list updates.
Old 01-15-2009, 12:34 PM   #15
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
t.t.t.
Old 01-16-2009, 02:58 PM   #16
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
almost gone, Thanks the everyone that has bought stuff
Old 01-16-2009, 09:09 PM   #17
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
making deals left and right......... keep em coming
Old 01-17-2009, 01:21 PM   #18
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
back again
Old 01-17-2009, 05:55 PM   #19
Shemp
Member#: 29754
2002 WRX Wagon
MBP
PM sent.
Shemp is offline   Reply With Quote
Old 01-18-2009, 02:14 PM   #20
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
sunday bump
Old 01-19-2009, 05:01 PM   #21
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
monday bump
Old 01-21-2009, 03:12 AM   #22
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
updated list and added some new parts
Old 01-24-2009, 03:17 PM   #23
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
Bumppp
Old 01-27-2009, 03:01 PM   #24
SedonaRed03WrX
Member#: 129117
300/ 292 03 SRP WRX
02 PSM WRX Wagon
bump..
Old 01-29-2009, 05:58 PM   #25
elsuicida
Member Sales Rating: (6)
Member#: 189889
02 Bug-Eye Stroker
*Twin Scroll Equipped*
Water pump with low miles?
elsuicida is offline   Reply With Quote
Lots of EJ20 Engine parts *CHEEP* (parting out 2 engines) SedonaRed03WrX SCIC Private Classifieds 32 03-05-2009 02:12 PM
Big Part Out.... Lots of stock and aftermarket parts new and used snwman NWIC Private Classifieds 14 02-08-2008 11:11 PM
04 WRX part out, LOTS of stock and aftermarket parts, SSR, STi, UTEC, QTP dudical26 Engine/Power/Exhaust 49 05-30-2007 04:35 PM
fs:A lot of goodies in NY Parting out my car JERMAINE Private 'For Sale' Classifieds 93 01-31-2005 02:24 PM
Lots of stuff for sale! parting out my car jimhoyd Bay Area Impreza Club Forum -- BAIC 28 10-25-2003 01:49 AM
