Old 04-02-2002, 01:31 PM   #1
tora
Member#: 5851
09 Forester XT
+ NA Miata
Default H&R's do not fit MY00~ Legacy...
Well, after a long wait my springs finally arrived on Monday. I went to the shop, disassembled my stock suspension, took out my new springs (correct part number, confirmed with H&R on phone and on catalog), but they don't fit. So, we call up H&R and they say "didn't you see the little note in the box?" Well, yes we did but that is after we ordered them, after we paid for them, and after we opened the box in the shop to install them. The note read, "may not fit some applications". Well, I was slightly choked. They had said on the phone they would fit, they advertize in their new catalog that they fit, yet they do not fit. So, they were returned. Looks like I am getting either whitelines or the non-height/dampening adjustable JIC coilovers. I already have the part number for JIC but not for the whitlines.
If anyone has the part number for Legacy L Wagon springs (MY01), it would be appreciated.
tora is offline   Reply With Quote
Old 04-02-2002, 04:03 PM   #2
lucien2
Member#: 1519
1998 Volvo V70R
*sigh* that's because there are no springs for your car yet. Or struts. Or anything except coil-overs.
lucien2 is offline   Reply With Quote
Old 04-02-2002, 04:56 PM   #3
Mx5racer
Member#: 2629
How would you put coil overs on the back of the wagon when the spring and the shock are are seperate and not mounted together? Coil over kinda implies that the spring is mounted on the shock.
Mx5racer is offline   Reply With Quote
Old 04-02-2002, 05:07 PM   #4
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
On some cars (if not all) that have a separate shock/spring combo, manufacturers will "integrate" the shock and spring together, effectively making it a coilover system. They just don't use the original spring perches.
Jason
2.5GT is offline   Reply With Quote
Old 04-02-2002, 08:35 PM   #5
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
tora - what part # are they? I'll do a little research for you
GTBGUY is offline   Reply With Quote
Old 04-02-2002, 10:55 PM   #6
kbrate
Member#: 7472
2001 Legacy
Winestone Pearl
Question STi
Has anyone considered/tried the STi Struts/Shocks and Springs listed on their site? At one point in time Rallyspec thought they could get them for me - 4 way adjustable - 175/275 Lb/in springs -listed for BE/BH?
Just curious...
KCB
kbrate is offline   Reply With Quote
Old 04-02-2002, 11:50 PM   #7
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
Isr performance has king spring that are supposed to fit the BE/BH. I don't remember his full screen name, but Ryan (TY200somthing ) from Seatle ordered a pair. Hopefully they work out for him. I'm leary on being the first test subject.
nitrohuffer is offline   Reply With Quote
Old 04-03-2002, 12:06 AM   #8
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
Default Re: STi
Just curious...
KCB
Here is the STi spring's info
(F^3.1B-30 ST2033066000 K3.1]kgt/mm^@For GTBGT-B lower 30mm
(F^2.7B-30 ST2033066020 K2.7]kgt/mm^@For RS, RSK lower 30mm
R^4.9B-30 ST2034066000 K4.9]kgt/mm^@For GTBGT-B lower 30mm
R^4.8B-30 ST2034066010 K4.8]kgt/mm^@For RSBRSK lower 30mm
copied from http://www.subaru-sti.co.jp/parts/legacy/2-2b.html
Here is the rest of the list for STi Legacy parts.
http://www.subaru-sti.co.jp/parts/legacy/index.html
I am planning to purchase the kg/mm spring DR sports from Japan. The primary spring rate will be similar to STi while orginal rate will be about 30% stiffer. This might be an alternative solution.
Jason is offline   Reply With Quote
Old 04-03-2002, 03:34 AM   #9
shirokuma
Member#: 5489
2013 FR-S
AVO Orange
Default Re: Re: STi
(F^3.1B-30 ST2033066000 K*3.1]kgt/mm^@For GTBGT-B lower 30mm
(F^2.7B-30 ST2033066020 K*2.7]kgt/mm^@For RS, RSK lower 30mm
R^4.9B-30 ST2034066000 K*4.9]kgt/mm^@For GTBGT-B lower 30mm
R^4.8B-30 ST2034066010 K*4.8]kgt/mm^@For RSBRSK lower 30mm
Have to add in something here - the springs for the B4 RSK/GT-B are sized to fit the Bilstein shocks and the spring perches for those cars. As long as the spring perches are the correct size, the springs for JDM B4's and GT-B wagons should fit. However, some better damped shocks would be advisable.
Paul Hansen
shirokuma is offline   Reply With Quote
Old 04-03-2002, 06:36 PM   #10
tora
Member#: 5851
09 Forester XT
+ NA Miata
I can't remember the part # now. I'm back in Whistler.
It was the correct # that is listed in both the 2000 and 2001/2 catalog.
Don't the Whitelines fit? I think JIC has a coilover set as well that are supposed to fit. But after my spring/shock fiasco I'm pretty skeptical.
Old 04-04-2002, 07:37 AM   #11
DTR00GT
Member#: 7336
2000 Legacy GT
Titanium Pearl
Default Re: H&R's do not fit MY00~ Legacy...
Originally posted by tora
........ So, we call up H&R and they say "didn't you see the little note in the box?" Well, yes we did but that is after we ordered them, after we paid for them, and after we opened the box in the shop to install them. The note read, "may not fit some applications". ........
Personally, people who make comments like that (H&R) should automatically be dragged out back an shot :monkey: I mean really, that's got to be stupidest thing to say or maybe just they could care less.
H&R: ??? why didn' t read the note inside the box. The box you don't have till you have already ordered the product
DTR00GT is offline   Reply With Quote
Old 04-04-2002, 02:25 PM   #12
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
Looks like H&R has no intention to produce springs for MY00 Legacy sedan.
More than a year ago, after I installed a set of Tein spring, I sent in my stock spring to H&R by someone's request. They mentioned it was for R&D purpose.
Now, it's been over one year, and H&R has not coming out w/ sedan spring. seems like they don't care about the legacy market.
Damn! I want my spring back~:monkey:
Update:
After I sent a nearly "hate" mail to H&R. They finally responded something back to me.
We have been active in the Legacy sedan fitment issues and do not have a cure at this time. The sedan springs are not the same dimensions as the wagon and will not cross fit.
I do not have any springs to send you nor do I have in my possession the springs that we received through SPO Motorsports. The springs that we received from SPO went to H&R Germany to further our development. When we received these springs, we were told that these were extra springs and they would not need to be returned.
I can tell you that we are still working on the development of the sedan kit but I do not have any eta on this kit at this time. I will try to keep you informed when we do finish development.
Thank you,
Steven
WRX Sway Bar does NOT fit a Legacy!!!! Bronson M Legacy Forum 15 06-18-2006 01:45 PM
APS says WRX turbos do not fit? bikerboy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 10-06-2003 07:41 PM
Prodrive P1's do NOT fit the STI :( Redneck Ricer STi Forum Archive 27 06-18-2003 02:32 PM
DBA 2 piece rotors do NOT fit with stock 2 pot calipers Concillian Brakes, Steering & Suspension 11 06-02-2002 06:58 PM
Warning: some 15" rally wheels do not fit WRX Jon Bogert Brakes, Steering & Suspension 10 08-08-2001 03:56 PM
