Old 01-10-2009, 06:06 PM   #1
Dutchman1101
Member#: 155735
2005 '05 LGT LTD
Satin White Pearl
Default 05 Saabaru 4EAT Stage II
I dont have a scanner right now so I hope this pic works
2005 Aero 4EAT
STI Uppipe
Cobb Catted DP
STI Cat Back Exhaust
Elevation-5400 feet
91 octane
Tuned by Harvey aka The Boost Creep at Super Repair in Boulder, CO
191.3whp/200wtq
Dutchman1101 is offline   Reply With Quote
Old 01-10-2009, 10:36 PM   #2
p19124
Member#: 130303
2004 wrx
psm
when i was stage 1 (93 octane and sea level) i made about the same numbers about 5 to 10 lower maybe that was a while ago
now I'm evoIII 16g
if you make it to the track please do post i don't get to see 4eat time to often
p19124 is offline   Reply With Quote
Old 01-11-2009, 12:00 AM   #3
JawKnee
Member#: 16105
04 WRX Wagon |
05 S2000 | 08 G35S Sedan
Just dyno'd my '04 4EAT WRX Wagon today, and was curious if the #s are in line with expectations.
K&N Typhoon short-ram intake, Helix UP, Helix DP with cat, Greddy Evo 2 CBE; everything else completely stock power-wise. It was road-tuned via open source last week. Car has 70.5k miles on 92 octane.
It put down 211.xx HP and between 198-201 for TQ UNCORRECTED (56 degrees F, 51% Humidity) on a DYNOJET 424xLC2. I believe SAE correction yielded 200 HP, but I don't recall the TQ. Once I get the .drf files, I'll confirm.
I believe the final runs were done in 2nd gear.
I assume I'm where I should be?
JawKnee is offline   Reply With Quote
Old 01-11-2009, 01:28 AM   #4
Dutchman1101
Member#: 155735
2005 '05 LGT LTD
Satin White Pearl
That is about right being you're running 92 octane and have a 3" TBE. Of course the Dynojet is inflating the numbers a bit. Do you have the graph so we can see your curves?
Old 01-11-2009, 01:30 AM   #5
JawKnee
Member#: 16105
04 WRX Wagon |
I'll post it after I get a chance to scan it later.
Old 01-11-2009, 01:38 AM   #6
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
Not bad for your very mild mods. have fun with it
evan_impreza is offline   Reply With Quote
Old 01-11-2009, 01:52 AM   #7
JawKnee
Member#: 16105
04 WRX Wagon |
Date: 2009-01-10
Dyno: Dynojet 424xLC2
Car: 2004 4EAT WRX Wagon
Mileage: 70,805
Gas: 92 Chevron
Mods: K&N Typhoon short-ram intake, Helix UP, Helix DP with cat, Greddy Evo2 CBE, road tuned via open source.
Old 01-11-2009, 10:53 AM   #8
SkateAndDestroy
Member#: 133893
JBP 04 Forester XT
PSM 02 WRX Wagon
For that pint size turbo he needs to start logging data before 3500 RPM on the dyno pull.
SkateAndDestroy is offline   Reply With Quote
Old 01-11-2009, 11:43 AM   #9
Dutchman1101
Member#: 155735
2005 '05 LGT LTD
Satin White Pearl
For reference, here is what a stock 05 WRX wagon 5MT ran on the same dyno.
Old 01-11-2009, 11:57 AM   #10
scooterforever
Member#: 55011
Decent numbers. In my experience 4EATs are generally faster than their dyno #s would indicate. Torque converters and dyno's sometimes produce weird results.
2.5L TD06 20G 4EAT
scooterforever is offline   Reply With Quote
Old 01-11-2009, 12:33 PM   #11
Dutchman1101
Member#: 155735
2005 '05 LGT LTD
Satin White Pearl
Also guys, I forgot to mention that on a pull Harvey did at the end when the car sat for a while and cooled down I got 200whp/210wtq.
We went with the 191.3whp/200wtq numbers because they are more indicative of daily driving conditions.
Old 01-11-2009, 01:10 PM   #12
Dobbs
Member#: 28291
2015 WRX
that sounds pretty reasonable. do you recall your peak psi? you may be able to eek another 20-30ft-lbs and maybe +10hp, i'm at 7200 ft and am making the same power you are, so there is a little bit on the table.
Dobbs is offline   Reply With Quote
Old 01-11-2009, 01:48 PM   #13
Dutchman1101
Member#: 155735
2005 '05 LGT LTD
Satin White Pearl
I believe it was a little over 15 psi. Harvey did leave a little on the table. He wanted a safe tune and I was more then happy with that.
My car was doing some weird stuff at first and ran lean and had a little detonation on one pull so at this point I just want a tune that gets me some decent power and is healthy for my car.
Like one of the previous posters said Autos read funny on dynos and are probably faster then thier number indicate. It would not surprise me at all is my car has more power then my graphs show.
Old 01-11-2009, 02:54 PM   #14
scooterforever
Member#: 55011
Here's a dyno graph from several years ago, back when I had a Stage 2 setup (IIRC). You can see the weird torque spike at the start of the pull; that's the torque converter.
Old 01-11-2009, 09:26 PM   #15
p19124
Member#: 130303
2004 wrx
psm
looks like this tread is mostly about just guys with 4eats (good thing)
anyone have upgraded turbo numbers and track times
Old 01-11-2009, 10:06 PM   #16
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
when i get my 18g+meth tuned at the end of the month i will throw my #'s in here.
i am happy to see a thread with 4eat.
jeremywrx15554 is offline   Reply With Quote
Old 01-11-2009, 10:36 PM   #17
GDB FAN
Member#: 105814
Not bad, I made about the same with my stage 2.
GDB FAN is offline   Reply With Quote
Old 01-12-2009, 02:21 PM   #18
JawKnee
Member#: 16105
04 WRX Wagon |
Originally Posted by scooterforever View Post
Scooter, would you mind cleaning out your PM box? I'd like to PM you about something
Old 01-12-2009, 04:13 PM   #19
p19124
Member#: 130303
2004 wrx
psm
this inspiring me maybe ill make my own thread
Thank you
Old 03-01-2009, 02:33 AM   #20
JawKnee
Member#: 16105
04 WRX Wagon |
Started own thread, didn't want to hi-jack any further
Old 03-01-2009, 02:34 AM   #21
JawKnee
Member#: 16105
04 WRX Wagon |
Old 03-02-2009, 12:28 AM   #22
Misanthrope789
Member#: 174595
2005 STi
Frank Dux Edition
your car put down some nice numbers yesterday, Matt is the man! We road tuned my car back in the summer and I couldn't be happier. I wanted to get on the dyno, but I am waiting for my boost control to get here.
Dcups Saabaru put down some sweet numbers as well!
Misanthrope789 is offline   Reply With Quote
FS: AZ 05 WRB WRX Stage II - $16,900 41K Mi - FREE 1 -WAY Southwest Ticket to PHX fieldy72233 SWIC Private Classifieds 7 03-18-2008 09:42 PM
FS: 05 WRB WRX Stage II - $16,900 41K Mi fieldy72233 Private Vehicle 'For Sale' Classifieds 32 02-25-2008 12:52 PM
FS: 05 WRB WRX Stage II - $16,900 41K Mi fieldy72233 SWIC Private Classifieds 28 02-18-2008 11:45 AM
FS: 05 WRB WRX Stage II - $16,900 41K Mi fieldy72233 SCIC Private Classifieds 2 01-28-2008 06:49 PM
FS: MA - 05 WRX COBB STAGE II Part Out Nads07 Engine/Power/Exhaust 20 05-04-2007 01:28 PM
