Old 01-10-2009, 10:19 PM   #1
boxerfxt
Member#: 163728
Default help with dyno graph?
wtf? look at this.......
what is wrong with my forester?
Blouch TD06-18G ported and polished with 15 lb w/g acc.
spearco tmic
wbr el-headers and up-pipe
dw-740 injectors
turbo xs tbe
perrin turbo inlet hose
ap v2
pro tune
somebody help! is it because of the 4.44 ratio? not loading the turbo? the car sees 20-21 lbs of boost and runs well but feels like a 2-stroke motorcycle on the pipe!!!!!
boxerfxt is offline   Reply With Quote
Old 01-10-2009, 10:21 PM   #2
Ej205scoob
Member#: 153117
2004 Impreza WRX
Platinum Silver
i dont get it? whats the problem? The graph looks ok, if its a low reading mustang dyno the numbers are fine. If it just feels slow then i have no idea
Ej205scoob is offline   Reply With Quote
Old 01-10-2009, 10:22 PM   #3
hanzo918
Member#: 82148
1992 Daihatsu
Charade
Uhhh looks good to me?
hanzo918 is offline   Reply With Quote
Old 01-10-2009, 10:27 PM   #4
boxerfxt
Member#: 163728
look at how slow the tq rises and it makes power real late in the power band? what gives? and it was a MD @ GST!
Old 01-10-2009, 10:32 PM   #5
boxerfxt
Member#: 163728
It dont feel slow lazy maybe! and on my 39 I went 13.12 and trapped 104 now it runs 13.4 and traps 105-106 I think the powerband is real real narrow (hard to launch) maybe a driver mod is in order? I just thought it looked weird?
Old 01-10-2009, 11:56 PM   #6
testes1010
Member#: 47145
2005 LGT 5MT VF52'd
from the graph alone, it does look to be a laggy b1tch. What RPM are you hitting peak boost? Are you using the stock boost control solenoid?
testes1010 is offline   Reply With Quote
Old 01-11-2009, 01:09 AM   #7
boxerfxt
Member#: 163728
4300 and gm 3port bcs....
Old 01-11-2009, 09:52 AM   #8
testes1010
Member#: 47145
2005 LGT 5MT VF52'd
^ something is causing quite a bit of lag in the system. You should be fully spooled by less than 3500rpm or so.
Old 01-11-2009, 02:07 PM   #9
boxerfxt
Member#: 163728
yea what?
Old 01-11-2009, 02:26 PM   #10
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
. do you have any leaks before the turbo?
autvincereautmori is offline   Reply With Quote
Old 01-11-2009, 02:55 PM   #11
STiHILMY
Member#: 111925
2005 STi
PSM SOLD!!!!!
uppipe? what boost solenoid are you running?
STiHILMY is offline   Reply With Quote
Old 01-11-2009, 03:56 PM   #12
modaddict
Member#: 95840
sold to a good bud
awaiting next car
is this in 1st gear or 5th?
modaddict is offline   Reply With Quote
Old 01-11-2009, 04:27 PM   #13
boxerfxt
Member#: 163728
3rd or 4th gear 1st gear I only see about 14lbs 2nd is 18.5 lbs and 3rd is 19.8 4th can see 21-22lbs same with 5th
Old 01-11-2009, 04:29 PM   #14
modaddict
Member#: 95840
sold to a good bud
awaiting next car
^^^yeah, you have issues.
If it makes you feel any better, I can hit 29psi in 1st gear with my stock boost control system on my 35r.
Old 01-11-2009, 06:29 PM   #15
boxerfxt
Member#: 163728
oh yea much better! thanks and I dont think I have ay leaks as ive been smoke tested 3 times
Old 01-11-2009, 09:49 PM   #16
testes1010
Member#: 47145
2005 LGT 5MT VF52'd
If there are no leaks, that means the 3port isn't dialed in properly
Old 01-11-2009, 09:49 PM   #17
4ST-AIR
Member#: 148681
2007 0-60 in $65,000
SOLD!!SOLD!!SOLD!!SOLD!!
hahaha your such a NASIOC Brute
4ST-AIR is offline   Reply With Quote
Old 01-11-2009, 10:51 PM   #18
crazymikie
Member#: 56321
2008 Lexus IS-F
i would check for post turbo intake leaks, pre turbo exhaust leaks and try doing a compression test. all of those things could contribute to slow spool.
spearco tmic
dw-740 injectors
turbo xs tbe
ap v2
pro tune
crazymikie is offline   Reply With Quote
Old 01-12-2009, 04:42 AM   #19
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Yeah, nothing else it could be if you have tested for leaks and compression.
Ya know I think everyone is so focused on your peak points that we are all missing the fact that a 2.5L with a huge tmic, headers ,inlet and ported 18G is only making 301 whp. My old 2.0L/20G set up made 300 whp on buschur's Mustang dyno without headers,inlet, and a smaller TXS tmic.I know all dynos read different and so on but those peak power numbers seem low for your set up to me. You are running enough boost though I don't know when you are hitting 21 pounds and for how long. Just seems that 21 pounds of boost and your mods should land you about 50 or so whp & tq more. If you have not had a compression test done I highly recommend that you do.
Tenacious Bee is offline   Reply With Quote
Old 01-12-2009, 10:29 AM   #20
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
what year is that fxt
dave
PerformanceAutoSolutions is offline   Reply With Quote
Old 01-12-2009, 10:40 PM   #21
boxerfxt
Member#: 163728
thanks guys yes Ive had a compression test done and its 150ish all across the board the forester is a 2005 and it only has 37k on it I would love to say its the bost sol. but Ive had it on when I had the 39 on my fxt and it spooled fine! full boost by 3100 or so and my forester holds the highest catted car he has tuned with a 18g matter of fact my 310hp 315tq dyno was only 10hp less than a 20g with a fmic on the same dyno.... but that is not what dyno's are for all of my dyno tunes have been on this dyno from my base dyno to my stage 2 protune too the 18g protune and they all keep getting better I picked up 40whp with just the 18g and injectors... but there is no meat to the powerband and I miss it!
Old 01-12-2009, 10:46 PM   #22
boxerfxt
Member#: 163728
Ya know I think everyone is so focused on your peak points that we are all missing the fact that a 2.5L with a huge tmic, headers ,inlet and ported 18G is only making 301 whp. My old 2.0L/20G set up made 300 whp on buschur's Mustang dyno without headers,inlet, and a smaller TXS tmic.I know all dynos read different and so on but those peak power numbers seem low for your set up to me. You are running enough boost though I don't know when you are hitting 21 pounds and for how long. Just seems that 21 pounds of boost and your mods should land you about 50 or so whp & tq more. If you have not had a compression test done I highly recommend that you do.[/quote]
dynos can read whatever you want them too I can get a dyno sheet that says my car put down xxxhp they are meant for a baseline and after on the same dyno! I can hit 21lbs in say 4th gear and hold at least 19. till 6800rpm I really think it has to do with the fact that it is a TD06 housing and a short 4.44 ratio I think It cant load the turbo enough to keep the torque for a long time..
Old 01-13-2009, 12:02 AM   #23
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Post a log and your problem should be easy to diagnos.
Infamous1 is offline   Reply With Quote
Old 01-13-2009, 08:04 AM   #24
steeda331
Member#: 125443
2006 WRX
Check all the common area. Do you have the A/F graph, that can tell me more about the tune, if its lean or rich, etc....
steeda331 is offline   Reply With Quote
04 STI open source tune with dyno graph Blee Proven Power Bragging 34 09-18-2009 04:13 PM
Whats With My Dyno Graph!!?? outlwstr Proven Power Bragging 47 03-09-2008 10:24 PM
Need help with Dyno Conversion of hp Sti"izzle" Proven Power Bragging 14 01-17-2007 04:23 PM
Help with turbo dyno graphs Unabomber Factory 2.0L Turbo Powertrain 23 03-30-2006 08:48 PM
Message Board Statistics All times are GMT -4. The time now is 01:52 AM.
