Old 01-11-2009, 01:21 AM   #1
klime
Member#: 186772
Default Battery disconnect, bad idle.
1996 Impreza Lx.
My battery was recently disconnected, and now the engine refuses to idle. The car drives (if continually given gas), but if I brake and slow down the engine seems to enter a limp mode and no longer accepts any revs at all, and if it comes to a complete stop (such as at a stop sign) the engine stalls. I was told this could be due to an ECU reset and driving it for awhile the ECU would "relearn" how to idle. I did this by taking it on the highway for awhile but nothing changed. Any ideas on what's causing the problem?
klime is offline   Reply With Quote
Old 01-11-2009, 02:13 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
try this
car cold as in not driven in 8 hours or more
disconnect the battery......press brake pedal 2-3 times
re-connect battery
get in car and WITHOUT EVER TOUCHING THE GAS PEDAL AT ALL!!!!
out the key in and start the car
DO NOT TOUCH THE GAS PEDAL AT ALL!!!
Let the car warm up until the radiator fans come on and the thermostat opens....15-20 minutes maybe...
turn the car OFF and take the key out
put the key back in and start the car and go for a drive
___________________________________
also....why was the battery disconnected and what was done at that time????
Old 01-11-2009, 11:21 AM   #3
darament
Member#: 199818
2008 WRX
WR Blue
it could just be a coincidence that the problem showed up at the time it did. One time I went in to get my brakes checked and after the report saying that they were fine and everything I started having braking problems. well the idiot workers only checked one side of the disk brakes which for whatever reason did not grab when braking and so the outside calipers had something like 80% life left and the inside ones were worn down to bare metal. this problem came up right after I had my service done and I thought maybe the technician left something in my car and that it couldn't be the brakes... well driving bare metal to metal ended up costing me another $300 for new rotors.
darament is offline   Reply With Quote
Note on alarm after battery disconnect jblaine Car Audio, Video & Security 14 09-30-2013 08:10 PM
Disconnected battery... car won't idle?! coffmc03 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 05-21-2010 10:02 PM
Will Apex'i AVC-R and Power FC lose settings if battery disconnected? annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-07-2002 10:42 AM
Capacitor Question - Re: Battery disconnect WRSport Car Audio, Video & Security 6 03-05-2002 12:57 PM
Help! Lights won't stop flashing after battery disconnected. Richard A. General Forum Archive 7 02-19-2001 07:07 AM
