Old 01-11-2009, 01:40 AM   #1
suberdave
Member#: 101865
88 GL-10 STi
Default what Acel. cable to use with EJ207?
i am installing a 99 V5 EJ207 into a 94 Impreza. the engine is in, the wiring is all done. the car runs awesome, but i have no Acel. cable...
94 Impreza cable dose not fit. and a USDM WRX cable dose not fit...
any ideas?
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 01-11-2009, 01:48 AM   #2
Aphex28
Member#: 11506
2015 WRX
what's the problem? How does it not fit? Too long? Too short? Hole too small? etc...
Aphex28 is offline   Reply With Quote
Old 01-11-2009, 01:50 AM   #3
suberdave
Member#: 101865
88 GL-10 STi
where it goes throught the firewall is a little different. the plastic caseing on the outside of the cable is to long, the cable inside is to short.
-=Suberdave=-
Old 01-11-2009, 12:34 PM   #4
Aphex28
Member#: 11506
2015 WRX
wish I knew enough to help you
Old 01-11-2009, 04:40 PM   #5
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
It seems when in doubt, check the '98 RS part.
rob is offline   Reply With Quote
Old 01-15-2009, 06:28 PM   #6
lazyjai123
Member#: 178538
99 rs cable should work
lazyjai123 is offline   Reply With Quote
what legacy cluster to use with 3 wire VSS? elsanto Subaru Conversions 2 08-02-2007 08:47 PM
what clutch/flywheel to use with hybrid 2.2/2.5? opious Subaru Conversions 9 03-28-2006 03:11 AM
What rear diff to use with STi Turbo Forester tranny? ImprezaRS dot com Transmission (AT/MT) & Driveline 0 05-30-2003 01:49 AM
Where to get info on Konig Wheels and what offset to use with springs? Kwyjibo Brakes, Steering & Suspension 7 12-15-2002 10:50 PM
what midpipe to use with scoobysport? rbehny Normally Aspirated Powertrain 11 05-13-2001 07:39 AM
