Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 01-11-2009, 08:47 PM   #1
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Default Some questions on an EJ25
Alright, recently rod bearing number 4 deciding to go spinning. I have several questions now.
  1. when i get my new engine would using a 10mm sti oil pump help prevent this in the future?
  2. Is the stock WRX oil pan any better than the stock RS oil pan?
  3. Will the STi head gasket fit the SOHC EJ25 for a 2000 2.5rs?
Mr_Snips is offline   Reply With Quote
Old 01-11-2009, 08:51 PM   #2
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
If you are buying a 10mm, why not go for the 11mm off the 08?
Pretty similar design, a better upgrade would be the STI pan with pick-up tube
Physically, yes it will fit.
Old 01-11-2009, 08:53 PM   #3
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
the STi pan does have better baffling?
Old 01-11-2009, 09:40 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
what oil were you using?
the afaik....the pickup has to match the pan....so it would be either use it or not
Old 01-11-2009, 09:44 PM   #5
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
i was using mobil 1. but it was only in 100 miles or so.
Old 01-11-2009, 09:46 PM   #6
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
Old 01-11-2009, 10:00 PM   #7
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
this isnt an argument about oil
Old 01-11-2009, 10:01 PM   #8
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
That's why I simply left my post blank.
I'm done getting into arguments about it, the numbers speak for themselves.
Old 01-11-2009, 10:03 PM   #9
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
haha...yup. i've had no issues thus far but i'll try something else next time.
Need some help on the ej25. TooTallB Newbies & FAQs 5 11-08-2007 09:18 AM
Pulley install on an EJ25 question agent007kimball Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-01-2003 12:26 PM
EJ20 Intake Manifold on an EJ25? Lo0mis Normally Aspirated with bolt-on Forced Induction Powertrain 6 05-05-2003 01:06 PM
STi V5/6 5MT on an EJ25? NicGordon Transmission (AT/MT) & Driveline 4 10-16-2002 08:28 PM
Base line MAP for a Link on an EJ25 PunKidd Normally Aspirated with bolt-on Forced Induction Powertrain 2 04-05-2002 07:04 PM
