Old 01-11-2009, 11:51 PM   #1
Red Rexx
Member#: 67187
2004 STi
Exclamation * Calling All Specialists & Gurus: Help Me Diagnose My Strange STi Engine Problem! *
*** Fixed! Silly coolant leak ! ***
Thanks guys!
Red Rexx is offline   Reply With Quote
Old 01-12-2009, 02:01 AM   #2
Red Rexx
Member#: 67187
2004 STi
No one can enlighten me?
Old 01-12-2009, 03:06 AM   #3
x3vin
Member#: 186791
09 WRX Sedan
Stage 1
o.O there can be so many random, tiny little things that'll cause such a small loss (15HP) temporarily.... I'm scared to even make a suggestion.
x3vin is offline   Reply With Quote
Old 01-12-2009, 06:49 AM   #4
Vectors2Final
Member#: 15553
'17 Camaro 2SS
16 Jeep GC SRT
I would be worried about the bits of metal in the oil. That doesn't sound too good.
Vectors2Final is offline   Reply With Quote
Old 01-12-2009, 08:10 AM   #5
dunk
Member#: 15359
Spark breakup can cause some similiar problems. Have you pulled your plugs to look at them? When was the last time they were replaced?
-Duncan
dunk is offline   Reply With Quote
Old 01-12-2009, 08:59 AM   #6
Vectors2Final
Member#: 15553
'17 Camaro 2SS
16 Jeep GC SRT
-Duncan
Post #1, Red Rexx mentioned that P&L replaced them.
Old 01-12-2009, 09:30 AM   #7
dunk
Member#: 15359
Good catch. Don't know how I missed that. Might be a coil issue as well.
-Duncan
Old 01-12-2009, 09:37 AM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I'm thinking it's a coil issue as well. We have seen some very strange interference with electronic devices when the coils start to act up.
Tony
Old 01-12-2009, 10:04 AM   #9
Vectors2Final
Member#: 15553
'17 Camaro 2SS
16 Jeep GC SRT
-Duncan
NBD, happens to all of us.
Could the coils be the reason for the 15HP loss?
Did he change the oil, or the plugs first?
Old 01-12-2009, 11:00 AM   #10
jays05
Member#: 78165
05 STI 35r + e85
If there were little metal bits in the oil, the filter should be packed full of em - cut it open!
jays05 is offline   Reply With Quote
Old 01-12-2009, 11:07 AM   #11
P&L Motorsports Inc.
Member#: 67199
07 [email protected] STI
97 RS [email protected]
Unfortunately there is no history on the car (was purchased used with no compression test done prior). From what I can gather, my thoughts on the EKG plot are this:
Its either electrical/ignition.
Or it has to be compression.
Its too rhythmic to be otherwise.
Now, the metal flake and shards in the oil...
That's a completely different problem.
Ultimately, what it boils down to is just how much time and effort the OP wants to put into diagnosing it. Replace coils, start checking grounds, or harness, etc...
That's why I'll NEVER buy a used performance car.
-Jorge
P&L Motorsports Inc. is offline   Reply With Quote
Old 01-12-2009, 11:13 AM   #12
dunk
Member#: 15359
Well, I think the oil analysis should be a must do for the OP At least that he'll know what type of metal it is.
-Duncan
Old 01-12-2009, 12:52 PM   #13
Red Rexx
Member#: 67187
2004 STi
-Jorge
Thanks again for all the help Jorge. I'm going to try to diagnose this a little more before we put the car back to stock. I called Ty today and asked him to pause the "return back to stock."
Old 01-12-2009, 12:53 PM   #14
Red Rexx
Member#: 67187
2004 STi
I am not sure honestly. I will check into that. Any info on it Jorge or if we can somehow analyze what material the debris in the oil was?
Also, what are the possible reasons why there can be debris like the metal in the oil?
Old 01-12-2009, 07:12 PM   #15
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Dude!! A million things could be wrong man, i feel bad for you. You should have just done the tbe and mbc. When people add many parts at once it usually takes some time to sort out both mechanicaly and on the dyno.
You told me a few of your threads ago that you were gonna go with an agressive tune, maybe the tuner went a little too agressive with timing at peak torque and damaged the motor. Not saying anything bad about the tuner, but when your trying to extract good power from a baby turbo things can go wrong.
Tbe, mbc, some good gas, and you'll be flyin on the stocker man...
Good luck, hopefully the problem is something non-complicated and you can be up and running for opening day at the track.
STi Mikey is offline   Reply With Quote
Old 01-12-2009, 07:27 PM   #16
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Sorry... but I had to.
RiftsWRX is offline   Reply With Quote
Old 01-12-2009, 11:30 PM   #17
Red Rexx
Member#: 67187
2004 STi
I don't think you tuned it aggressively Jorge, ESPECIALLY on the 93. I said you can go slightly more aggressive on the 100 octane map since it would be ran rarely. We didnt even get to do the 100 octane map at all...
How could you tune it aggressively if you changed the oil and found this BEFORE the tune? That wouldnt make sense...
Old 01-12-2009, 11:46 PM   #18
n2oiroc
Member#: 141952
15 legacy 16 wrx
like this?
that was a good run. on one run there was a 60 whp dip from a bad misfire. watch the vid below, same thing but much worse on the street. does your boost fluctuate? sounds like a weak coil to me.
http://www.youtube.com/watch?v=04AFXNnPSwY
n2oiroc is offline   Reply With Quote
Old 01-13-2009, 01:03 AM   #19
Red Rexx
Member#: 67187
2004 STi
Originally Posted by n2oiroc View Post
like this?
Great post!
Any word Jorge?
Old 01-13-2009, 01:13 AM   #20
n2oiroc
Member#: 141952
15 legacy 16 wrx
the crappy part is you pretty much have to get ahold of some known good coils and rotate all the old ones out. i just got some new coils to try then my turbo blew so i still dont know if mine is fixed or not. you can do a few things to diagnose the issue without tossing more money into it. how does the car run/drive? power good on top or does it fluctuate?
Old 01-13-2009, 11:24 AM   #21
Member#: 67199
Exactly...
We never even got more then one or two exploratory pulls (partial at that) into the 93 map.
-Jorge
Old 01-13-2009, 11:25 AM   #22
Member#: 67199
Dave: Jup, that's what I'm thinking. Either a coil or plug issue. The bottom end decay is a completely different problem. But, if this car was misfiring over time (with the prior owner), it is very possible its been pounding a bearing away.
-Jorge
Old 01-13-2009, 12:56 PM   #23
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Why the rolleyes Jorge? I never mean and especially in this case did not impose anything derogatory. It was not specified if the shrapnel in the oil
was a problem before or after the few pulls. Based on a previous thread, Redd stated that he would receive an aggressive tune from you, and in all my time at the dyno it is apparent that the evo can take more high rpm knock than an STi during troubleshooting. Its not rare for these motors to pop under aggressive conditions, again, the conditions not being specfied.
I meant nothing by my post, I was just curious. I'm actually interested to see how this car does in the long run. You can tell by my profile I'm a firm believer in the STi's baby snail, and I love seeing people make progress with it.
Sorry if I came off wrong, and I hope all gets sorted out soon.
Old 01-13-2009, 01:06 PM   #24
r8r4life
Member#: 101464
Tbe and Mbc.
r8r4life is offline   Reply With Quote
Old 01-13-2009, 01:34 PM   #25
Red Rexx
Member#: 67187
2004 STi
The car ran perfectly normal to me prior to bringing it in. It felt normal, actually better than normal. It pulled like a BEAST with just the OTS AP Stage 2 map.
Jorge said the power on top was very good. It was doing 330wtq BEFORE tuning on a baseline running 93 octane. He never told me the whp number. That's damn good IMHO though and im not being biased...
Any input based on that?
Calling all Brake Experts! Please help me diagnose my soft pedal. kennyvb Brakes, Steering & Suspension 11 02-19-2009 10:52 AM
Help me diagnose my tranny (?) problem Bullitt 2496 Transmission (AT/MT) & Driveline 1 10-22-2007 11:11 PM
Help me diagnose my problem! (hit a curb) DefPDP Transmission (AT/MT) & Driveline 8 12-09-2005 07:20 PM
Help me diagnose my problem.....6speed/rear diff... wrxedya Transmission (AT/MT) & Driveline 3 10-08-2005 01:11 PM
Help me diagnose my engine problem! imprezive one Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-27-2003 10:42 AM
