Old 01-12-2009, 02:57 AM   #1
caterpill
Member#: 27136
Default Aftermarket radiator fans (slim) - They work better than stock or what?
Need some insight on an aftermarket radiator fan setup.. Stock radiator is finally squirting out of the top plastic endtank at 98k mi.
Of course.. i'd like to replace it with something more reliable. Debating between a Mishi, Koyo or C&R Racing radiator, in order of price.
Only problem is that i'd also like to swap out the fans for something slimmer, but my question is are slim fans really an upgrade? Supposedly some aftermarket fans flow more than stock, so I can understand that being an upgrade if you use them on a stock radiator.. But some aftermarket setups are bundled with a fat shiny radiator and THEN considered an upgrade.. know what I mean? I don't see any much reviews for subarus though. I had an eye out for the C&R racing radiator, but it won't accomodate the OE fans.
Anyone have / forsee any problems with the aftermarket setups? OEM is a 2-speed setup (4 wires?) versus most aftermarket setups which are 1-speed. (2 wire) I rarely hear my fans switch to high speed. I think the only time was once on a hot day with a/c on after some hilly driving.
Well, any insight is appreciated. I was looking into some name brand setups like SPAL/Flex-a-lite but I hope it doesn't cost too much.
caterpill is offline   Reply With Quote
Old 01-12-2009, 09:34 AM   #2
quazimoto
Member#: 70395
Upgraded fans not really needed.An aftermarket radiator shroud will make more difference for cheap.Also in Romraider (opensource tuning software) you can change some of the fan functions like which fans turn on when and I think temp setting as well.
quazimoto is offline   Reply With Quote
Old 01-12-2009, 11:37 AM   #3
van_dutch
Member#: 198633
2004 WRX
I have heard of people having some problems with an aftermarket radiator. The increased core thickness can result in some of the hoses rubbing on the fans. I believe this can be avoided by properly trimming the hoses to fit. The slim fans aren't a huge upgrade, however. Look at their rated airflow vs the stock. I don't know off the top of my head the listed airflow (in cfm typically) for the stock fans, however. The way to really improve cooling is as dumdum said and get a shroud.
van_dutch is online now   Reply With Quote
Old 01-12-2009, 07:23 PM   #4
caterpill
Member#: 27136
I see a flex-a-lite dual fan setup pulls about 2300cfm.. but at the price of $250.
Someone here was selling such a setup with a koyo radiator.. Maybe it worked alright for them? hm.
Old 01-12-2009, 08:32 PM   #5
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
i always suggest stock fans over aftermarket...why? because the stock fans have 2 speeds...aftermarket usually do not. so on that hot summer day in traffic when your ac is on...your car will over heat...case closed
IMPORTIMAGE is offline   Reply With Quote
Old 01-12-2009, 09:03 PM   #6
scooterforever
Member#: 55011
[off topic] A few weeks back I had a Mishimoto installed on my '02 from ImportImage above and it's worked out great. Excellent vendor. [on topic]
I used my stock fans on the Mishimoto.
scooterforever is offline   Reply With Quote
Old 01-12-2009, 09:59 PM   #7
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
thanks scooter
stock fans and aftermarket radiator are really the way to go...
mishimoto does make a plug in radiator shroud kit...but those are for the people who have the extra money to spare.
Old 02-25-2009, 04:45 AM   #8
jlugo05
Member#: 123891
2002 wrx psm hawkeye
02 wrx AW*secret project*
Originally Posted by IMPORTIMAGE View Post
thanks scooter
i got the mishimoto radiator and dual 10" fans with the shroud but now i hae to figure out hot to make it work with ac and also temp
jlugo05 is offline   Reply With Quote
Old 02-25-2009, 12:02 PM   #9
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
yeah thats the problem i was talking about
im always happy to sell the radiators with the shrouds but i like telling the customer what they are getting into before they get into it. Overheating...really bad
Old 02-25-2009, 09:01 PM   #10
Knightmare69
Member#: 25039
2005 CGM Stage 2 WRX
SQC 275
I remember in an older thread about fans, it was suggested to just plug in the high speed wire for the fans, so then there should be no overheating issues correct? I ask because I'm contemplating slimmer fans as well.
Knightmare69 is offline   Reply With Quote
Old 02-25-2009, 09:04 PM   #11
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
that would work as well if you just blow on high all the time (although it would make the car sound kind of funny having them on high all the time)
Old 02-25-2009, 09:08 PM   #12
Knightmare69
Member#: 25039
SQC 275
Eh, I'm pretty sure the exhaust would drown that noise out, either that or build some sort of switch/relay to incorporate the low and high mode?
Old 03-20-2009, 08:50 AM   #13
sean18337
Member#: 135588
2007 STI *SOLD*
Thats what I want to do. I just need to figure out which color wire is the high speed wire....
sean18337 is offline   Reply With Quote
Old 03-22-2009, 03:28 PM   #14
caterpill
Member#: 27136
Picked up a C&R radiator with optional SPAL fan setup.. a while back.
Never had any overheating issues yet.
I had to splice the high & low speed wires together because the spal setup only has one speed.
Dunno how the Mishimoto & others are but apparently this is a common issue.
Old 03-22-2009, 07:17 PM   #15
sean18337
Member#: 135588
2007 STI *SOLD*
OK, so if you splice the high & low speed wires together will any aftermarket fan with 2 wires (power and ground) still run high & low speeds?
If so that would be great!
Old 03-22-2009, 08:06 PM   #16
rougeben83
Member#: 115154
2005 Outback XT
White on grey
no, it will only run on the default speed of the fan (usually high). Only the stock ones are capable of 2 speed settings AFAIK.
rougeben83 is offline   Reply With Quote
Old 03-22-2009, 11:10 PM   #17
caterpill
Member#: 27136
You have to check the schematic.. I think I posted another thread about this.
What happens, is that when your ECU commands low/high speed, your one-speed fan will come on because it is spliced into the two circuits, but either command will activate the fans at full speed.
It's the only choice you have with fans that don't have seperate low/high speed inputs.. If you leave the low speed circuit disconnected, your car will probably run hot.
Old 03-22-2009, 11:21 PM   #18
Knightmare69
Member#: 25039
SQC 275
I take it the OEM fan harness is only 2 wires? I'm sure there is a external fan controller you can buy.
Old 03-23-2009, 01:07 AM   #19
rougeben83
Member#: 115154
2005 Outback XT
White on grey
any particular reason why you guys are so adamant about slim fans? The OEM has been proven to fit and work just as well if not better than these, and without the speed headaches...
Old 04-02-2009, 02:49 PM   #20
sean18337
Member#: 135588
2007 STI *SOLD*
I have the mushimotor rad with their slim fax/shround. It looks nice ansd saves a lot of room.. Especially when trying to rotate the crank pulley
So all I need to do is splice both (high & low speed) power wires together and run these wires to the power wire of the slim fan?
Old 04-02-2009, 09:53 PM   #21
caterpill
Member#: 27136
Yeah.
Double check your wiring diagram and don't splice the ground. :P
Old 04-03-2009, 12:18 AM   #22
rexblake
Member#: 178426
2010 S4
Gray
I have the koyo rad on an 02 WRX and the stock fans worked fine. You just have to trim the hoses a bit and make sure to check that they are not rubbing.
rexblake is offline   Reply With Quote
Old 04-03-2009, 01:40 AM   #23
Knightmare69
Member#: 25039
SQC 275
Well I for one am looking into it simply for the peace of mind in case I end up going rotated manifold where the pipe goes down the front of the engine.
Old 04-03-2009, 03:07 AM   #24
sorrowfulkiller
Member#: 170439
I <3 Lamp
I've got a cxracing radiator myself and I'm sure that audiosavvy would agree, it's a great buy. I personally used stock fans and had to trim a bit off of the silicone radiator hoses I bought also. Works perfect though... I would even go as far to say I would use no fans on most days as long as i wasn't stuck in traffic
sorrowfulkiller is offline   Reply With Quote
Old 05-19-2009, 02:46 PM   #25
jlugo05
Member#: 123891
I picked up the mishimoto radiator and fan shroud kit with radiator hose, i talked to electricians and they said the fan ill turn the same speed on hi or low but its better to put it on low so its on most of the time. i am about to try this out i will report later
radiator fans...do they both turn on? MO_MD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-01-2006 08:37 PM
Aftermarket Coilovers much better than stock? shemoves Brakes, Steering & Suspension 11 08-19-2005 04:12 PM
So MWIC thinks they are better than Texas... Marcin Texas Impreza Club Forum -- TXIC 28 06-12-2003 10:44 PM
Hella 500 Fog owners, are they much better than stock? Arnie Interior & Exterior Modification 6 06-26-2001 04:06 PM
