#1 |
Member#: 41754
Vehicle:03 wrx gt35r, 2.5L, meth |
Hey guys,
Anyone know what size and pitch, length the subframe bolts are? Thanks! Ambert
#2 |
Member#: 41754
Ok found it. For future reference they are M12 x 40 and M14 x 45
#3 |
Member#: 207118
NWIC
Vehicle:2003 Wrx Wagon |
Noob question - I am having difficulty getting the couple of back 14mm bolts to thread (the two on each side under the plastic over, to the rear of the car)
There are two different lengths on each side, one fairly short, the other longer. Am I correct that the short bolt goes in the farthest rear spot (both are under the plastic cover) I think I may have switched the fronts/rears or I've cross threaded one. I had thought the longer bolt was closer to the front, shorter one in back, but since the longer one didn't go in all the way on one side, I stopped to ask. I'm hoping I just made a dumb mistake and the long one goes in the back, short in front? Thanks |
#4 |
Member#: 207118
NWIC
Found this diagram
The two in the back, listed as 3 and 5 - m10 (but length to show which is longer)? http://forums.nasioc.com/forums/show...=subframe+bolt |
| Thread Tools | |
| Display Modes | |
| What are the bolt specs on the subframe? | verc | Brakes, Steering & Suspension | 4 | 01-12-2009 07:26 PM |
| my new struts are on the way what are camber bolts? | autowagon | Brakes, Steering & Suspension | 5 | 01-21-2005 02:37 PM |
| What are good alignment specs for the street? | Schleppy | Brakes, Steering & Suspension | 5 | 12-11-2002 11:03 PM |
| What are those plastic pieces on the... | RoscoePColetrain | General Forum Archive | 10 | 06-19-2000 02:58 PM |
