Closed Thread
Old 01-12-2009, 03:48 PM   #1
jagretzky02
Member#: 136479
2004 WRX / STi
Default Drive shaft U Joints
Anybody had to deal with changing out there drive shaft due to there u joints going bad. My u joints are starting to go stiff, i have been looking for U joints to replace them, but no luck, according to subaru you have to replace the whole drive shaft. Any help would be greatly appreciated.
jagretzky02 is offline
Old 01-12-2009, 06:47 PM   #2
StrictlySubarus
Member#: 199648
04 Swapped GC
too many colors to list
Usually going bad there is a lot of slop to them .Going stiff is a bad thing ?
Most ppl just get a new/used shaft ( no pun intended) since they're really not serviceable, Maybe try spraying some "penetrate" lube like P.B?
StrictlySubarus is offline
Old 01-12-2009, 07:13 PM   #3
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
You pretty well have to replace the whole drive shaft. U joints aren't replaceable. May as well look into a lighter one, I would get the aluminium one if I had to do it again...
wrxdrvr is offline
Old 01-12-2009, 07:22 PM   #4
DS1
Vendor
Member#: 111780
The joints are non serviceable in the subaru shafts, you'll have to replace the whole shaft.
If you need a replacement, let me know
-Dylan @Ds1
DS1 is offline
Old 01-12-2009, 09:43 PM   #5
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Just throwing this out there, since I have not looked into it...
My local machine shop did some driveshaft-related work for me recently, and they suggested looking for a u-joint kit that would fit the STI driveshaft. The owner said that there should be something that will work with the wide variety of cars on the road these days. The one that came with my swap had some serious flat spots in the u-joints. It would most likely require some machining, and the old u-joints would have to be pressed out, but in the end you would have an STI driveshaft with ungraded, changeable u-joints.
This may not be possible due to the lack of available replacement u-joints, but evidently it is common on a lot of other types of cars with non-serviceable u-joints. Seems like it is worth a look, no?
aboothman is offline
Old 01-13-2009, 03:40 PM   #6
jagretzky02
Member#: 136479
2004 WRX / STi
Yeah somebody also told me I might be able to try to measuring them and find a close match and pressing them in. The only problem is, I don't know if they are pressed in or what actually holds them together. I do think this is possible to do and I am probally gonna order a new shaft and when I get the old one out, I will mess with it and try to replace the u joints. I was just wondering if anybody has actually tried it yet. Either way I will post the results when I do it. If anybody else has any insight, let me know. Thanks
Old 01-13-2009, 03:47 PM   #7
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Anything "CAN" be done, Is it worth it in this case...? The U joint is swag-ed and spot welded in there so....
wrxdrvr is offline
Old 01-13-2009, 09:17 PM   #8
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Ya, I will give it a go as well once I get some extra cash together. I have a good local machine shop that likes oddball projects, and they charge $70 an hour so it is affordable.
Generally, U-joints are pressed in, but many use low enough amount of force that you can do them at home. They have a seal, and then an expanding clip that sits inside a groove which holds everything together. When I find the pics I have I will post them up.
Old 01-14-2009, 03:33 PM   #9
DS1
Vendor
Member#: 111780
The subaru u-joints are not held in by pressing them in. There is a retainer that gets destroyed when you disassemble them. (I know I tried )
Between the the price of the joints and the labor to try and adapt them, you can get a used shaft (I sell used 5mt shafts for $15 + shipping)
-Dylan @ Ds1
DS1 is offline
Old 01-14-2009, 05:55 PM   #10
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I know, I was referring to using aftermarket u-joints. Who in their right mind would go through the trouble of removing the OEM joints just to replace them with the same crappy joint?
How much would you want for an STi driveshaft shipped to 95540?
Old 06-18-2009, 07:52 PM   #11
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
I'm having a noise/vibration issue on my impreza with 05 RS transmission and 96 center driveshaft and rear end. I removed my driveshaft at work recently and the universal joints on both ends seemed to have center detents, they don't move without drag. Seems like all four joints do the same thing but the center joint moves freely in all directions. The other guys at work told me they were shot and I needed a new shaft. I ordered a driveshaft from a 5spd 06wrx and the joints do the same thing... what gives?
2slofouru is offline
Old 07-07-2009, 01:46 PM   #12
my05legacy
Member#: 106873
2013 sti hatch
cbs
I get a clicking sort of sound when I left off the gas with or without the clutch in. Soon as I step back on the gas it goes away...that sound like a bad u joint?
my05legacy is offline
Old 07-27-2009, 03:27 PM   #13
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Same issue here in my 03 wrx wagon. Clicking noise that seems to be centered (ie not wheel bearing or axle related). Can't seem to find and answer.
MY99 2.5GT is offline
Old 09-14-2009, 12:26 AM   #14
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
my05leg - check ur axle nuts
FleaDog is offline
Old 10-04-2009, 03:26 AM   #15
adrianb
Member#: 205934
2004 WRX
java black
replacement U-joints for subarus including the wrx is made by a company called http://www.rockforddriveline.com under part number 430-10. They wont sell them to you but you can buy them from many 4x4 u-joint retailers like http://theujointstore.com/staked-in-...t-ujoints.html
adrianb is offline
Old 11-03-2009, 06:00 PM   #16
globalexcursion
Member#: 192979
I am having the same issues on my 04 WRX Wagon. Vibration from 30mph to 75mph.
Talked to Six States http://www.sixstates.com/products/products.jsp , they sell are reman DS for $450 + tax. The dealer wants $599 (part # for 04 WRX Wagon 5MT, 27111SE061) and a local shop wants $400 to replace the u joints with Nissan parts (Fuji Heavy Ind).
Sounds like you have to cut the original u joints out then install the Nissan ones with internal clips.
Also you can order The Drive Shaft Store's aluminum one piece for $456 shipped
http://www.driveshaftshop.com/pdetail.php?pid=585
http://thmotorsports.com/drive_shaft...=SUSH1-03-2003
I am torn between the reman from Six States or the one piece from TDSS
For now I turned the yoke 180* and took a hammer to it to loosen up the bearings. They move freely now, but for how long?? I haven't driven it yet, so I'll report back on how this temporary fix works.
Last edited by globalexcursion; 11-03-2009 at 06:04 PM. Reason: added OEM part number
globalexcursion is offline
Old 11-03-2009, 06:19 PM   #17
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Just buy a used shaft! Why would you ever consider a new one unless you needed an aluminum one or something? DS1 Motorsports just said he sells used 5MT shafts for $15 plus shipping. I see them on eBay all the time. I have two in my garage I can sell you.
450 vs 15... hmmmm....
kpluiten is offline
Old 12-29-2010, 08:18 PM   #18
csugden
Member#: 154959
04 JDM STI
Looking for a 6sp shaft, shipped to Trinidad & Tobago, W.I.
csugden is offline
Old 01-08-2011, 06:29 PM   #19
kboparai1
Member#: 103216
04 STi
black with silver rimz
<--Also looking for a used driveshaft for STi^^
kboparai1 is offline
Old 01-09-2011, 05:48 AM   #20
csugden
Member#: 154959
04 JDM STI
Default Sti Drive Shaft.
I got a used one for my car, I now have have a spare minus the center bearing, my mechanic also changed the cross (universal jt).
There is a dealer here who might ship one to you, his name is Gobin Mahedo, his email is [email protected].
I did not get mine from him, but I understand he has several and also exports.
csugden is offline
Old 01-09-2011, 05:17 PM   #21
kboparai1
Member#: 103216
04 STi
oh! i was mis informed then. I was under the impression you had to replace the driveshaft if your intent was to change the ujoint. I had some mechs check it out, they said my rear ujoint was "rough" which is why i can hear a weird rotating sound...
Old 07-18-2011, 09:14 AM   #22
Matchless
Member#: 288211
New to the forum and I need a little info. I have a 2001 ob H6 VDC and need a rear driveshaft, or parts to repair a failing center bearing. What is the difference of a 4 cyl shaft? Could I use the front or rear section from an auto 4 cyl. I can't source a used H6 shaft anywhere local. Thanks for any info!
Matchless is offline
Old 07-21-2011, 08:19 AM   #23
Matchless
Member#: 288211
No info out there? How about driveshaft length. On my H6 from the center of the bolt holding the carrier bearing to the forward end of the u-joint ear at the tranny it measures 21 15/16". This does not include the yoke in the tranny! Anyone out there with a four cylinder auto shaft that could verify if it's the same length? Thanks.
Old 07-21-2011, 01:28 PM   #24
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
the at driveshaft for my 4eat was a 1 piece driveshaft
todeswalzer is offline
Old 01-04-2012, 07:12 PM   #25
renly25
Member#: 284894
Default need used drive shaft
-Dylan @ Ds1
do u still offer u-joints for 02 wrx wagons?
renly25 is offline
Closed Thread
Drive Shaft Shop- 02-04 WRX Aluminum Drive Shaft UV BN RXD Drivetrain 20 09-10-2012 07:53 PM
drive shaft u-joint Jamil7 Transmission (AT/MT) & Driveline 17 07-08-2012 07:15 PM
Can u take the front drive shaft / axle out without pulling ball joint or strut off? qualityracer Transmission (AT/MT) & Driveline 5 02-21-2010 06:25 PM
sti front drive shafts+wrx rear drive shafts toulakid Drivetrain 1 03-13-2007 02:34 AM
Drive shaft "sludge" around U-joint? (pics) heffergm Transmission (AT/MT) & Driveline 3 01-22-2006 07:51 PM
