Old 01-12-2009, 05:00 PM   #1
Retiarius
Member#: 198130
Default Do coated pistons skirts really make that big of a difference?
I'm not concertned with noise, but in the long run from a wear perspective, will it really help?
Retiarius is offline   Reply With Quote
Old 01-12-2009, 07:43 PM   #2
hotrod
Member#: 14141
2002 Impreza WRX
Yes coated piston skirts help, but they are not coated to reduce wear. The coatings primary intent is to reduce friction (increases usable power, improves fuel economy and reduces engine heat). The increment is small but real.
Reduced wear on the cylinder wall if any is very small especially if using molyfaced rings which also lube the piston ring/cylinder wall contact point.
Larry
hotrod is offline   Reply With Quote
Old 01-12-2009, 10:16 PM   #3
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
And its also at the least cheap insurance for initial start-up and break-in (if the coating makes it that long).
Crystal_Imprezav is offline   Reply With Quote
Old 01-12-2009, 11:33 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
^^Ditto...and from what I've seen, I question whether or not typical skirt coating lasts that long as well. And if the oil film goes for whatever reason, coating won't save it. But cheap insurance for break-in? Worth every penny.
flycaster is offline   Reply With Quote
Old 01-12-2009, 11:53 PM   #5
n2oiroc
Member#: 141952
15 legacy 16 wrx
the skirt coating wont last very long, my stock pistons wore thru it in some spots in 7,000 miles.
n2oiroc is offline   Reply With Quote
Old 01-13-2009, 02:07 PM   #6
MS WRX
Member#: 117780
2004 WRX
No. Neat concept but i have had two very expensive longblocks and neither machinist reccomended skirt coating
MS WRX is offline   Reply With Quote
Old 01-13-2009, 04:16 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
There's always opinions on the other side as well. I've listened to talented engine builders discuss the importance of coatings in the overall engine design. Not just skirt coatings, but chamber, valve and ports.....
Our skirts aren't all that long to begin with. The coating is going to help.
my .02 anyway
Jay
Old 01-13-2009, 07:53 PM   #8
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Different piston designs of course but I've run Wisecos (coated) and CP's un-coated) and the wisecos seemed to be quieter for the first 5-10k or so. Can't say how those cars are doing now though but my wiseco block is still going strong and ok on noise. (I'm sure this has to do with the build spec too though as these were from different builders).
Fongers is offline   Reply With Quote
Old 01-13-2009, 11:58 PM   #9
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I got my Wiseco's recoated by Embee Performance (pretty much the same as swaintech, just local for me) and the two different types of coatings were a night and day looking difference. After seeing the difference, I would definitely say, it varies depending on what kind of coating you get. If you think about it, there are many different types. You have Cosworth's Xylene Type, Swaintech/Embee's TBC Slippery Tuff Skirt Style, Mahle's GraFal Style, Oil Shedding, TBC, Thermal Dispersant, Anti friction, and etc.... Look at the difference from my Wiseco OTS coatings and the Embee coating:
I wish I had a better picture of the OTS Wiseco skirts, they were nothing special and they chip/scratch very easily... Its almost like comparing rattle can paint vs. powdercoating.
For only (I think) about $20 a piston for tops & sides, IMO you would be a fool not to.
Old 02-02-2011, 10:04 AM   #10
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Larry
doesn't friction produces wear?
https://secure.buschurracing.com/cat...d943c6abd87874
These pistons have also been J&E tough skirt coated. This is a special process that helps with the oiling and prevents excess wear.
Old 02-02-2011, 10:21 AM   #11
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Old thread.
I think Larry meant that the skirts may not contribute to all expected wear, and that rings are also part of the equation.
I am a fan of coatings. After reading reports and various articles from/regarding racing teams, it seems to be proven technology.
ZeroDrift is offline   Reply With Quote
Old 02-02-2011, 10:27 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
IMO skirt coatings are a tough call. They often wear off and leave you with a little bit bigger PTW (though minute) than before. In many subaru cases, I've seen them lead to some odd wear patterns/scuffing...unexplained.
I don't run them personally though I may send my pistons down to Calico before putting the engine back together and experiment.
Homemade WRX is online now   Reply With Quote
Old 02-02-2011, 10:44 AM   #13
juanmedina
Member#: 133146
Originally Posted by ZeroDrift View Post
Old thread.
Isn't most of the wear produced on the cold start (especially with a 2618 alloy forged piston) when the piston skirt hits the cylinder wall (piston slap)? now I am even more confused
some piston coatings are designed to wear over time...
I am going to get my pistons coated for my next built.
Tuff SkirtŪ (TS)
Tuff SkirtŪ is a JE Pistons trademark coating that is a lubricating, anti-friction / anti-wear coating applied to the piston skirt only. Unlike our standard Skirt Coating, Tuff SkirtŪ wears slowly over time and is designed to withstand many different types of endurance applications including NASCAR, rally and off-road racing.
http://www.jepistons.com/TechCorner/PistonCoatings.aspx
Old 02-02-2011, 10:53 AM   #14
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
depending on where you go they do in fact work. The swaintech coatings hang tight for a long time. They help with noise alot but more importantly they help with knock and detontation and save the sleeves/skirt and dome of the piston.
stretchedk7 is offline   Reply With Quote
Old 02-02-2011, 11:24 AM   #15
Homemade WRX
Member#: 33782
96 bastard child
I'm well aware of that. JE also offers two different skirt coatings
I know what they have and offer and don't run their coatings but I do use their pistons.
Old 02-02-2011, 01:50 PM   #16
quicksubie
Member#: 221140
2005 hybrid=fun :-D
93 L 2.5rs rally preped
I was instructed by nick at je not to coat the skirts because it's just going to wear off anyways so why waste the money. He did suggest to have the tops coated tho.
I guess some would say coating the skirts would make the piston slap a Lil less noisy but in a weird way I kinda like the sound of my car at idle.
quicksubie is offline   Reply With Quote
Old 02-02-2011, 02:27 PM   #17
Prevent
Member#: 149114
I had mine coated dome and skirt $163 for all 4 (shipping included) I think it was worth it.. OEM pistons come coated...
Prevent is offline   Reply With Quote
Old 02-02-2011, 02:45 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
yup and they are also cast, made on an assebmly line and they also have a factory allowable PTW clearance of about zero
The factory skirt coating also wears quickly.
I'm not saying it's right or wrong but simply that because the factory does it, isn't an argument for a forged piston, hand built, high-performance engine.
I will say that from my only experience on a tear down with the PC-9 (swaintech) coating is that it's pretty tough. The motor is a 102mm stroked (1.47:1 rod ratio IIRC) 4G63...it had spun a bearing so a tear down happened. The motor didn't have a lot of miles (under 8k) on it but the coating still looked good.
Old 02-02-2011, 02:50 PM   #19
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
First time I've had it done so we'll see how much of a noise diff there is.
sense of nature is offline   Reply With Quote
Old 02-02-2011, 03:25 PM   #20
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
It wont make much difference if any. Loud piston slap would be from excessive piston to cylinder wall clearance. The tighter the tolerance the less noise it will make. Hence why the OEM pistons dont make much noise because the PTW clearance is less than a thousandth. I dont know exactly what it is but its in the ten-thousandths. The reason that they can do that is because the piston material does not expand like forged pistons do.
2Fast4U1DAY is offline   Reply With Quote
Old 02-02-2011, 03:40 PM   #21
Prevent
Member#: 149114
my cp's seem quiet at cold start compared to other non coated, who knows $160 isn't much..
Old 02-02-2011, 03:48 PM   #22
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
I used coated CP's in my build... I wont know how loud they are until i do the engine swap in the spring tho... PTW is set to .003" (CP's recommendations) so we will see.
Prevent: What's your PTW tolerances?
Old 02-02-2011, 03:50 PM   #23
Prevent
Member#: 149114
.003" excluding the coating.. (however the machinist did it) I havent started up the car in cold weather... always plugged in and in a warm garage... I have to get a better map on the car because when it was cold it was idle searching like a mofo.
Old 02-02-2011, 05:06 PM   #24
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
I have always used calico for coating of my cp's for my builds and also for the race acl's(before calico started coating them and keeping them done on the shelf).The motors have always been a little quieter than without a coating and Calico does brg,piston and other engine part coatings for quite a few NASCAR teams.Like Micah said its personal preference but if some of these teams include this in their engine progarms it has to have positive results.Just my .02.
john 1badSTI is offline   Reply With Quote
Old 02-02-2011, 05:30 PM   #25
JayMeagher
Member#: 187911
03 WRX
Redish
I'd say that measuring your piston to wall first, without assumption would be step one before talking about noise and/or wear. I watched a video on here with the CP pistoned EJ "at .003 PTW" and it was much noisier than and forged engine I have had my hands on with that value. Just because "they" say .003 doesn't mean shi#. Don't think from bore to bore, top to bottom it's just "set at .003".... That's a fantasy world.
I have taken apart Modular Ford engines with 100k and still have a decent amount of coating intact. I have also used some aftermarket coatings that wore off quickly.... But if that was their intended lifespan I'm ok with it. I do believe there is a certain amount of time to make the components "familiar" with themselves, and if the coating helps with this relationship it's a win.
JayMeagher is offline   Reply With Quote
complaining about having to buy premium....really THAT big of a difference?? The Tree Off-Topic 67 05-22-2008 07:27 PM
Did my porting really make that big of a difference? tube Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-06-2007 04:11 PM
UP make that big of a difference? spooln407 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 02-03-2006 04:24 PM
do sti cams in wrx heads really make that much of a difference? legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-15-2006 01:31 PM
Is the STi really that big of a difference? rossscarbro General Community 41 01-29-2004 05:06 AM
