Old 01-12-2009, 11:58 PM   #1
DC16A2
Member#: 174357
2002 OBS
Default Radiator fans run excessively.
The radiator fans seem to be running excessively these days, even though in this weather it never goes above 40F and it's often around 20F when I start driving. The fans come on during idle more, and when I'm parked, they stay on for minutes at a time. They never used to do this -before, they would switch on and off every few minutes, and that included in the summer.
Is it the thermostat, radiator blockage, or something else acting up?
Any help would be appreciated =)
DC16A2 is offline   Reply With Quote
Old 01-13-2009, 09:41 AM   #2
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Has your coolant temp reading changed at all during any of this extra activity?
Has your cold coolant overflow level been stable?
surowrxa is offline   Reply With Quote
Old 01-13-2009, 10:04 AM   #3
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Have you put the defrost to full defrost? The AC comes on and the fans will run...
wrxdrvr is offline   Reply With Quote
Old 01-13-2009, 11:29 AM   #4
rkramer
Member#: 118209
2015 WRX Limitec
full or even the floor/defrost mix will turn on the fans.
Old 01-14-2009, 10:01 AM   #5
DC16A2
Member#: 174357
2002 OBS
Ahhh, leave it to my northern neighbors to points out the defrost/fan link =)
I think you guys may be right.. the coolant levels and overflow have been normal. Also, I will try driving with absolutely no heater/AC use and those with to test this out the fan.
Thanks guys!
Old 01-26-2009, 12:15 PM   #6
mrjoshm
Member#: 100437
2002 wrx wagon
cobb stg 2, PPGs, wrb
how does the defrost thing work if the A/C system is empty and the clutch never engages? or if the A/C is stripped from the car?
mrjoshm is offline   Reply With Quote
Old 01-26-2009, 06:50 PM   #7
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
it doesn't, it just sends air at the windshield. There are probably some electrical contacts in there somewhere that turn on the AC. If it doesn't exist, no big deal. if it turns on the compressor and there's no refrigerant, too bad.
Old 01-26-2009, 11:49 PM   #8
DC16A2
Member#: 174357
2002 OBS
Okay, so after two weeks of careful observation: no use of any AC/heat and the radiator fans still come on excessively -I wait more than 5 minutes for them to turn off and they still keep going. I'm doing normal suburban driving, and the coolant temps range 194F to 204F. Coolant itself is OEM from dealer and less than a year old.
Perhaps I should get a new OEM thermostat?
Old 01-27-2009, 01:57 AM   #9
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
if your coolant temps are good (i assume you have an after market guage), the thermostat is probably ok. coolant temp sending unit might be bad. grab a chiltons or haynes manual from your local parts store, it will tell you how to change the sending unit.
Bacon117 is offline   Reply With Quote
Old 01-27-2009, 12:23 PM   #10
DC16A2
Member#: 174357
2002 OBS
^Thanks! It seems like that there's a lack of Chilton/Haynes manuals for our cars.. but I'll look into this "sending unit." My "aftermarket gauge" is just a ScanGuage2 grabbing values from the ECU.
Old 01-27-2009, 12:33 PM   #11
mrjoshm
Member#: 100437
2002 wrx wagon
i just checked last night at an ambient temp of about 15F with my AP and my fans kicked on at idle at 205/206F and i watched at it cooled the car to 203F then turned it off cause it was taking forever. so with the a/c stripped from the car, it just blows hot air at the windshield...maybe i'll rewire the a/c button to do something cool like i/c water spray or open a downpipe cut-out
Old 05-19-2009, 01:43 PM   #12
DC16A2
Member#: 174357
2002 OBS
Strangely, my radiator fans are now cycling normally. They kick in at 204F, blow for about 30 seconds, and shut off when the water temp dips to 193F.
Old 12-17-2009, 03:32 PM   #13
controler
Member#: 100271
I'm having the same problem. Temp gauge doesn't move below just half way and the fans are coming on in the cold temps <40 degrees. With or without the heat/defrost being on. No check engine lights either. I replaced the radiator in August with one from Napa and coolant from subaru. No coolant leaks either. 92k miles, stage 2.
What was the fix?
controler is offline   Reply With Quote
radiator fans running when car is off pannell77 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 04-06-2010 07:36 AM
Radiator fan running a lot jonney_boy Newbies & FAQs 5 02-01-2008 12:44 AM
Do both radiator fans run together? kharris4 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-11-2007 12:18 AM
radiator fans not running? mikey-babo Service & Maintenance 1 09-14-2005 02:03 PM
How-To, Reverse run the radiator fans? makofoto Electrical & Lighting 4 05-21-2004 04:12 PM
