Old 01-13-2009, 12:05 AM   #1
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Default 11mm oil pump
Would an 11mm oil pump on a 2000 rs be worth it? its the same price and i have to be in there anyways. Will it do any harm?
Mr_Snips is offline   Reply With Quote
Old 01-13-2009, 12:41 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
not really, unless you have dohc and variable valve timing....and maybe oil squirters. It may do harm if the pressure is higher than your seals are supposed to hold. I have a 10mm in a 2001 RS and it seems ok.
FS: 2008 STI 11mm oil pump brand new ownnij TXIC Private Classifieds 3 08-31-2009 12:24 AM
STi 11mm Oil Pumps - CP Pistions - OEM Subaru Engine Overhaul Gasket Kits FredBeansParts Engine/Power/Exhaust 0 07-20-2009 08:52 PM
08 STI has 11mm Oil Pump! sponaugle Built Motor Discussion 84 07-19-2008 08:21 PM
08 STI 11mm oil pump or JDM 12mm oil pump? Davenow Built Motor Discussion 82 06-28-2008 12:33 AM
2008 STi 11mm oil pump opened up. Badazzcr Built Motor Discussion 25 02-03-2008 12:47 PM
