Old 01-13-2009, 01:13 AM   #1
turbotimein253
Member#: 117409
Default 04 STI GT52 Tuned By Pina Motorsports In Kent WA
Im really happy with the results now i need a intake manifold and some TGV deletes to help the top end department.
The Car
turbotimein253 is offline   Reply With Quote
Old 01-13-2009, 01:17 AM   #2
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Looks fun, Car looks good too...get the hella outta my way lol
TDagen is offline   Reply With Quote
Old 01-13-2009, 01:19 AM   #3
turbotimein253
Member#: 117409
Thank you. Im going to takt he front sti badges off and the side ones to. So it can be a 2.5rs with a scoop lol...
Old 01-13-2009, 01:21 AM   #4
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Lol until all four tires break loose and your gone, then it looks like no 2.5rs lol
Old 01-13-2009, 02:50 AM   #5
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
If you really want a sleeper, take that scoop off. Otherwise there's no way in hell you're fooling anyone into thinking it's an RS.
Audiosavvy is offline   Reply With Quote
Old 01-13-2009, 10:38 AM   #6
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
What race gas or METH combo you have in that and where are the mods?
4ST-AIR is offline   Reply With Quote
Old 01-13-2009, 11:39 AM   #7
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Holy Tapering Power, Batman! Have you considered cams?
bluescoobywagon is offline   Reply With Quote
Old 01-13-2009, 12:23 PM   #8
turbotimein253
Member#: 117409
Pump gas. No meth.
Spt cat back
helix down pipe
turbo xs up pipe
Gt spec header
gt52 turbo internally gated
perrin FMIC
perrin Big maf
perrin turbo inlet
Perrin modded injectors
perrin fuel rails
walbro fuel bump
worldone built shortblock with JDM forester sti heads
Oem STI Spark Plugs
cooler thermostat
i might be missing something but this is off the top of my head now LOL.
Old 01-13-2009, 01:37 PM   #9
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
So unless those JDM Forester heads are built I'm having a hard time imaging all that power.
Just to confirm your running 93 oct hitting peak boost at 4400RPMs @ 25.5psi tapering to 23.5ps i@ 6900rpm's? On an Internally gated setup, and stock MAP Sensor?
Oh god and SPT exhaust That SPT chokes turbos like I choke my chicken. That is a lot of power to the ground for that setup.
Ive seen guys running GT52/Hydra/Hydrmist and not come close to that on pump.
Old 01-13-2009, 01:43 PM   #10
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i say go EWG, maybe it will help you hold power a little better
seanathanq83 is offline   Reply With Quote
Old 01-13-2009, 01:47 PM   #11
gtasti
Member#: 152036
2004 Sti
I'd get rid of that spt and throw on a ewg kit then you may hold more power up top
gtasti is offline   Reply With Quote
Old 01-13-2009, 03:16 PM   #12
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Default ???
4st the stock MAP sensor will maxed out about 25 psi so that boost level can be reached but not so sure you want to do that on 93 octane. The peak numbers are nice but they drop off a lot. My set up with the 20G on 93 octane is holding up better up top which tells me something is holding you back up top (cams, SPT exhaust...) or the tune can be improved. This is the link to my thread just in case you want to compare.
http://forums.nasioc.com/forums/show...t=junior+tuned
My peak numbers are not as high but the drop off is not as bad. I don't want to hijack the thread but i've done some improvements on the road using open ecu and airboys spreadsheet is recording up to like 375whp which is very nice for pump on a simple setup. Toback up the improvements right after i tuned the car i used airboys spreadheet and it was dead on with the dyno numbers so is a fair comparisson. I can post those graphs later on today if someone wants to see the improvements made.
wil06STI is offline   Reply With Quote
Old 01-13-2009, 05:10 PM   #13
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Very nice numbers for an Element GT52. I wouldn't change a thing!
Congrats!
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 01-13-2009, 06:28 PM   #14
flystiguy14
Member#: 74416
91 SS leggy
pearl white
Just to confirm your running 92 oct hitting peak boost at 4400RPMs @ 25.5psi tapering to 23.5ps i@ 6900rpm's? On an Internally gated setup, and stock MAP Sensor?
Fixed that there for ya.
flystiguy14 is offline   Reply With Quote
Old 01-13-2009, 06:40 PM   #15
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
LMAO I'm finding that even harder to believe then.
Stock MAP can read accurately up to ~24psi but he is hitting 25.5psi and now Im being told this is on 92 oct? That's living on the serious edge of a time bomb.
These are most definitely SAE corrected numbers.
Old 01-13-2009, 06:58 PM   #16
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
[email protected] / JR Tuned
sickk numbers.. congrats on the build and car looks sick bro.. i get gold wheels and we would look the same lol
OVeRBOOSTn is offline   Reply With Quote
Old 01-13-2009, 07:06 PM   #17
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
25psi and 11.5-11.7:1 on pump gas?? Do you have an EGT gauge?
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 01-13-2009, 07:52 PM   #18
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
-- Ed
25.5psi on 92
Old 01-13-2009, 10:27 PM   #19
chlnOrSlpn?
Member#: 97785
2015 WRB STi Limited
EFI Logics/CTSUBIE
I understand why you're running 25.5psi on pump on a built block, but you're happy with such a late spooling GT52? That torque drops off worse than a VF39 and your HP drops off pretty bad as well. I see GT35R spool with VF39 power curve...
chlnOrSlpn? is offline   Reply With Quote
Old 01-13-2009, 10:40 PM   #20
GDB FAN
Member#: 105814
92 is the highest pump fuel in WA.
True story.
GDB FAN is offline   Reply With Quote
Old 01-13-2009, 11:53 PM   #21
Ray_STi
Member#: 97683
2005 WRX STi
CGM/Gold - Element GT52
Nice numbers.. but to be honest, something is wrong with the graph..
Your bottom end is hurting bad.. anyway your tuner can tune that out..
Also your taking a HUGE risk with 25psi and 92 octane...
Ray_STi is offline   Reply With Quote
Old 01-14-2009, 12:14 AM   #22
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
True story.
regardless thats insane power @ insane boost. That is either HP #'s or going to blow very soon. I have been there so many times its not even funny.
Old 01-14-2009, 12:23 AM   #23
SplatZ400
Member#: 84377
2011 335d
thats is exactly what i was thinking. I also hit 23-24psi about 1000rpm quicker.
SplatZ400 is offline   Reply With Quote
Old 01-14-2009, 02:03 AM   #24
turbotimein253
Member#: 117409
I believe there is some tweaking to do with the GAIN on the turbosmart e-boost.
Yes it was tuned with 76 92 octane.
I really love the feel of the GT52 it dosnt feel laggy like the graph shows..
There is more power to be made on it specially since i still have the TGV's....
Thanks for all your feedback.
My plan here real soon is to go external wastegate and intake manifold and TGV deletes.
I have the SPT exahust because i dont want a modfied exhaust ticket.. If i get stopped i have the SPT advertisement and i can show the cop it is a factory option.
But i am thinking of running the electric cut out valve again...
Old 01-14-2009, 10:35 AM   #25
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
HAHAHAHA you always know when I am talking about you
06 WRX 365whp/360wtq [GT52, tuned by Pirouz @ DPS] EGY5 Proven Power Bragging 10 06-13-2009 09:08 AM
FS U.Racing 785cc, HDi E Boost, PMU STI Pads Defi Boost Gauge (White/Bar) Kent, WA thetomstudley NWIC Private Classifieds 6 06-08-2009 04:05 AM
FS 785cc, 565cc, HDi E Boost, PMU STI Pads Defi Boost Gauge (White/Bar) Kent, WA thetomstudley Engine/Power/Exhaust 3 06-08-2009 03:45 AM
05 STi - GT52 Tuned by Agile Auto boost junkie Proven Power Bragging 28 02-27-2008 12:20 AM
Anyone tuned by Swift Motorsports? bonesmuggler New England Impreza Club Forum -- NESIC 11 11-12-2007 05:19 PM
