Old 01-13-2009, 12:27 AM   #1
STi-MAN
Member#: 70252
05 STI
blue
Default really.. how bad is it to track on a blown coilover..
so my shock is blown... and i cant get it revalved in time for the next track outing... how bad is it really to track on a blown shock. I've tracked on this blown coilover last event and ran my fastest time, but really how dangerous is it?
STi-MAN is offline   Reply With Quote
Old 01-13-2009, 12:41 AM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I am amazed your even asking
Old 01-13-2009, 12:44 AM   #3
lemon19mmm
Member#: 144545
GG Wagon
I drove a nissan 240sx with totally blown shocks before. It was like driving a boat. You can feel much more weight transfer/ un-balanced body roll.
pay attention to those bumps, apex curbs, or any other ugly surface.
However, I would ask for credit if I were you.
lemon19mmm is online now   Reply With Quote
Old 01-13-2009, 12:45 AM   #4
STi-MAN
Member#: 70252
05 STI
blue
yea im wondering what do you expect? i've read that the corner might roll more... basically the kw is leaking through the compression adjustment hole.
Old 01-13-2009, 09:08 AM   #5
MasterKwan
Member#: 98961
2003 WRX
A little seepage probably isn't "blown". If it's not spraying oil out of the seal you're probably OK. The spring rate isn't changing so, the car's going to have the correct ride height. A truely blown CO, you'll probably see either no damping at all so, the car's different in dynamic situations (corner entry) or the valves will get stuck inside and not permit the CO to have the full range of movement because pressure builds up as it compresses and your effective spring rate increases as the suspension cycles. I had that happen to a strut and ended up with a bent wheel because there was no give when I hit a pot-hole.
Old 01-13-2009, 09:36 AM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Well the problem is that if you operate with little or no oil in the shock. You simply will cause serious damage. Specially if you bottom out.
Yet like above I agree with leaking oil. Not exactly a full blown problem unless there is no oil left. Yet having one shock doing this may cause some unusual drive conditions. So watch those corners.
Old 01-13-2009, 11:25 AM   #7
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
I wouldn't do it. My biggest concern would be unpredictable handling behavior, which you definitely don't want on the track.
boost junkie is offline   Reply With Quote
Old 01-13-2009, 01:10 PM   #8
STi-MAN
Member#: 70252
05 STI
blue
thanks for the advice.. yeah i would think the biggest thing is the unpredictability.. im going to try and have it rush fixed.
How bad is it to flog on the car when it's still cold. Hyelude Newbies & FAQs 24 10-22-2008 01:09 AM
How bad is it to run an APS DR525 on a stock TD04? jay25RS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 06-25-2007 11:23 AM
How bad is it to drive on a bent control arm? Prylex3 Brakes, Steering & Suspension 4 03-21-2007 02:42 PM
How bad is it to drive on snow tires in warmer weather??? Farnsrocket Tire & Wheel 4 12-16-2006 11:26 AM
I mean, really, how hard is it to write in complete sentences? DrDRum Off-Topic 13 11-11-2004 12:00 PM
