Old 01-13-2009, 05:55 AM   #1
VIsubi
Member#: 187834
06 2.5i impreza
Red
Default Tranny oil change
I was just wondering if anyone new how much oil does the tranny in the 2.5i 06-07 hold. I know its 75w90 is the vescosity grade but i didn't know how much gear oil to add to it once I drain it. I have 13245 miles on it but want to change the oil anyways. Anyone got a clue or done this yet to there 2.5i manual doesn't say
VIsubi is offline   Reply With Quote
Old 01-13-2009, 06:14 AM   #2
Rocketjones
Member#: 142754
2005 RS Wagon
Buy 4 qts. Add 3, then top up till the dip stick says stop.
Rocketjones is offline   Reply With Quote
Old 01-13-2009, 07:37 AM   #3
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
mine took 3L just yesterday. Published spec is 3.5L.
sniper1rfa is offline   Reply With Quote
Old 01-13-2009, 01:08 PM   #4
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
its accually 3.8
watchunglava is offline   Reply With Quote
Old 01-13-2009, 01:48 PM   #5
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
my manual states 3.5L. You can't even fit 3.8L in there (more than a gallon).
Old 01-13-2009, 01:52 PM   #6
watchunglava
Member#: 168862
sorry not 3.8
its 3.7 qt's thats what my manual says . and thats what ive put in there the 3 times ive changed it and it sits perfect on the stick.
you have to really drain it there are lots of gears in the tranny and it takes a while to get it all out .
ive run dyno fluid, which was great for like 1k miles, then felt like crap.
ive run red line 75-90 and redline 75-90 ns
the ns was ok
i now run amsoil severe gear 75-90 and love it
Old 01-13-2009, 01:55 PM   #7
watchunglava
Member#: 168862
Old 01-13-2009, 01:58 PM   #8
HeftyJo
Member#: 198984
2005 2.5RS
Amsoil makes the best oil bar none.
HeftyJo is offline   Reply With Quote
Old 01-13-2009, 02:00 PM   #9
watchunglava
Member#: 168862
Old 01-13-2009, 02:14 PM   #10
Reble_45
Member#: 199014
wow, way to kill the conversation with posting a scan of the tech manual....
Reble_45 is offline   Reply With Quote
Old 01-13-2009, 02:41 PM   #11
watchunglava
Member#: 168862
thanks i thought it was definitive as well . your welcome
Old 01-13-2009, 05:04 PM   #12
VIsubi
Member#: 187834
06 2.5i impreza
Red
lol thanks that helps gona throw in some royal purple in there tomorrow
Old 01-13-2009, 05:23 PM   #13
watchunglava
Member#: 168862
royal purple isnt the best for the syncros . because of the moly they put in there.
try redline 75-90 ns or amsoil severe gear
Old 01-13-2009, 05:26 PM   #14
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Really? ****, I just bought like 3 quarts of the stuff.
Car's got 200k on it, I can't imagine it'll do much more damage...but I guess I better return it anyway :[
Anyone?
XanRules is offline   Reply With Quote
Old 01-13-2009, 08:12 PM   #15
2.5ReallySexy
Member#: 167943
Royal purple will be fine
2.5ReallySexy is offline   Reply With Quote
Old 01-13-2009, 08:16 PM   #16
watchunglava
Member#: 168862
i used royal purple engine oil in my crankcase once . its known around as a poor mans way of polishing your crank. i have a magnetic drain plug , guys you should have seen how much fillings there was that change.
i dont think you want to do this to your tranny internals.
Old 01-13-2009, 08:20 PM   #17
2.5ReallySexy
Member#: 167943
so royal purple no good?
Old 01-13-2009, 08:23 PM   #18
mdungelman
Member#: 97251
'13 Impreza 2.0i
Just to let the OP know, you'll need a T-70 torx bit to loosen the plug. Its not necessarily something you find at every hardware store.
mdungelman is offline   Reply With Quote
Old 01-13-2009, 08:31 PM   #19
watchunglava
Member#: 168862
napa had a t-70 or they can order it for you.
well the moly in the oil is solid so if you imagine your tranny gears, the solids will fill the spots that should just be lubricated . they will polish these spots down and you will be left with a slipping trans eventually esspecially the syncros . thats the argument against
it.
Old 01-13-2009, 09:02 PM   #20
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
If you can't find a t70, a t60 will work too, as that is what I used. Be careful though, it slipped out of the tranny plug on the first try and whacked me in the face
chazly413 is offline   Reply With Quote
Old 01-13-2009, 09:35 PM   #21
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Sounds like a recipe for disaster.
Old 01-13-2009, 09:40 PM   #22
chazly413
Member#: 151079
2005 2.5RS RBP
Haha yeah it almost was, but it worked
Old 01-13-2009, 11:19 PM   #23
mdungelman
Member#: 97251
'13 Impreza 2.0i
Is it worth the pain in the ass of punching yourself in the face, or possibly stripping out the plug? Ebay is a good place to find the T-70 torx bit. A lot cheaper than having a parts store order one. Find the deal!
Old 01-13-2009, 11:41 PM   #24
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I will have to say the best trans oil has to be Redline Shock Proof. It's blue.
It makes my synchro's shift as if they were new and some of them have a lot of miles (170k on the trans). I really slam gears. As this is my 3rd gear set. As well a few shifter forks and several synchro's.
Yet use regular Redline gear oil in the rear diff.
After the oem oil and regular redline and a few others. I really can't say enough good stuff about this oil.
Old 01-14-2009, 01:18 AM   #25
2.5ReallySexy
Member#: 167943
hmm so the gl 5 75-90 should be ok for trans? I plan on doin mine tomorrow hopefully costless or the dealer sells that t-70 bit
First gear grinding after tranny oil change blue-ej20 Transmission (AT/MT) & Driveline 1 11-15-2003 09:20 AM
Tranny Oil change...when? KIMUTAKU Service & Maintenance 13 06-27-2003 12:46 PM
Tranny Oil Change ChrisV-FL Transmission (AT/MT) & Driveline 1 04-08-2002 05:16 PM
some advice for Tranny oil change hp12c Transmission (AT/MT) & Driveline 9 01-11-2002 03:12 PM
Tranny oil changed !! Need advice Ultraboy Technical Forum Archive 9 10-11-2000 12:43 AM
