Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 01-13-2009, 08:26 AM   #1
ericburt
Member#: 177906
Default nitrous on a n/a subie?
I have a 1999 z28 camaro 6 speed and need a subie for winter and snowboarding and what not. Say if i were to get a 2000 2.5rs, has anyone ever installed nitrous on a stock motor like that, or can it be done safely? If so, can someone give me some info.
ericburt is offline   Reply With Quote
Old 01-13-2009, 08:53 AM   #2
cmiovino
Member#: 134005
2004 WRX Premium
Nitrous is generally bad for a daily driver. I'm kinda of assuming that's what you want to do with it if you're going snowboarding. A Subie would be great for getting stuff up the mountain, but doing it with nitrous is a little ridiculous.
To answer your question, it wouldn't last long on stock internals.
Old 01-13-2009, 10:47 AM   #3
Forester_007
Member#: 87139
2003 Forester XS
JBP
If you tune your car for nitrous and the shot is not too high yeah it will hold. Stock internal will hold, but if you very aggresive with nitrous any car can go boom, just got to play it right.
Forester_007 is offline   Reply With Quote
Old 01-13-2009, 02:12 PM   #4
Reble_45
Member#: 199014
Yea, I agree, Prob not the best idea. Better off either buying a project car and putting money into building a good motor that will take the boost and nos. Stock Nos just makes my stomach turn-over just thinking about it.
Reble_45 is offline   Reply With Quote
Old 02-26-2009, 08:19 AM   #5
Hites
Member#: 138997
0000 Nothing
Lol, you'll be fine with a 50shot. Just don't be stupid and spray all the damn time and empty a full bottle in a day, or spray for like a solid minute.
Hites is offline   Reply With Quote
Old 02-26-2009, 03:30 PM   #6
PA-Outback2000
Member#: 161832
2000 Outback Limited
smallest shot should work, but these cars can't handle that much NOS w/o proper mods.
PA-Outback2000 is offline   Reply With Quote
Old 02-26-2009, 03:50 PM   #7
blernin41
Member#: 200321
2009 Forester 2.5XP
Armpit Green
this seems a little strange...will you be in an extreme hurry to go snowboarding?
blernin41 is offline   Reply With Quote
Old 02-26-2009, 04:26 PM   #8
impreza_punk
Member#: 102900
2005 Impreza STi
With global warming snow is becoming more sparse...
impreza_punk is offline   Reply With Quote
Old 02-27-2009, 01:43 PM   #9
Dokturseuss
Member#: 102009
1999 impreza
...............fail
Dokturseuss is offline   Reply With Quote
Old 02-27-2009, 08:18 PM   #10
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Originally Posted by Dokturseuss View Post
...............fail
Fail? You would know about snow, because you live in the south right?
Smoke is offline   Reply With Quote
Old 02-27-2009, 08:58 PM   #11
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
Nitrous for a 2.5 RS is fine.
Most believe nitrous is bad.
Some might argue it's safer than a giant turbo, since you're only using it once in a while.
A simple 50 shot is about as big as I would go.
The safest way to start is with a 25 shot.
Wit NOS, you're usually only spraying at WOT (especially with a dry kit).
The "myth" that nitrous is dangerous is based on some fact.
If you are not in gear, or the car is off, but the ignition is on, and you have your nitrous kit turned on, you can mistakenly fill the intake manifold with nitrous. If you have an intake manifold full of nitrous, and start your car, BOOM! You will have a nitrous backfire.
There are easy ways to prevent this.
On my BMW, I had a secondary switch for nitrous. To activate the system, there was a huge, red switch that lit-up. You could see the thing in full sunlight.
I also had a red LED that lit every time the nitrous was spraying.
If you go so far as to install a "progressive" system, you can have the car spray a set amount, which increases with RPM.
With this type of system, I suggest a wet nitrous kit, which adds extra fuel to the nitrous spray to prevent det. These kits cost a bit more, but you can easily spray a 50 or 75 shot without worrying about running out of fuel.
Start with a small, 25 shot. This will allow you to get a feel for how your car reacts to nitrous. The 25 shot may be more than enough to give you that extra grunt you want. If you then decide to go for a 50 or 75 shot, you'll already know how nitrous works, and how to properly use your system without becoming another blown motor.
Nitrous can be a safe and easy way to add HP. It's also pretty cheap.
If you are a dumbass, though, it can make your engine go bye-bye.
The instant reaction most folks have to nitrous is, "Oh, no! You'll put your eye out, kid!"
In reality, if you blow your car up on nitrous, you simply did it wrong.
Good luck,
SOTC
saab-on-the-cobb is offline   Reply With Quote
Old 02-27-2009, 11:37 PM   #12
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I used to run nitrous on my 1990 wagon. Ended up running almost a 100 shot near the end. Can't remember if I ever blew a piston due to nitrous alone or not.
But it took me from 16.6 to 14.7!
Old 02-27-2009, 11:41 PM   #13
boostin23
Member#: 204172
---- 05 STi
my buddy gots a 93 wagon and has run over a 100 shot... as far as i know its running
boostin23 is offline   Reply With Quote
Old 02-28-2009, 11:20 AM   #14
VIsubi
Member#: 187834
06 2.5i impreza
Red
I'd say nothing more than a 50 shot to keep the innternals safe..they said this on Tuner Mag but with good pistons you could do it all day...well not really but more than with stock internals...
VIsubi is offline   Reply With Quote
Old 03-01-2009, 08:16 AM   #15
theuntouchable
Member#: 204334
I've got a 2008 legacy 3.0 spec b (6 cylinder boxer engine 243bhp 6 speed MT)
I've been asking around the forums what i would need to do if i wanted to turbo charge or add nitrous.
I guess i could go with a 25 shot or 50 shot of nitrous on stock internals.
But if money wasn't really an issue.... how far can i go? What would i need to change (internals) in order to turbo charge?
theuntouchable is offline   Reply With Quote
Old 03-01-2009, 09:45 AM   #16
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
I really, really want to take this spare intake manifold I have and tap it for a DP setup... the Zex kit allows you to get down to 12.5 hp per cylinder (50 shot) which is what I'd like to start on. I'm just not sure if it would be a good idea to try out on my car with stock 150k mile old internals...
bl_easy is offline   Reply With Quote
Old 03-01-2009, 09:47 AM   #17
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Alot...pistons and rods if you want to run any amount of boost. And also injectors and i'm sure the fuel pump. Also a custom manifold.
Mr_Snips is offline   Reply With Quote
Old 03-01-2009, 07:24 PM   #18
zorobyte
Member#: 204205
Remember premium gas and octane booster :P
zorobyte is offline   Reply With Quote
Old 03-02-2009, 01:08 AM   #19
CAMG3
Member#: 184738
2008 Outback Sport
How much would a reliable 50 shot kit cost?
And how easy is the installation?
Thanks
CAMG3 is offline   Reply With Quote
Whos running nitrous on their subies? v_dubs37 Water/Methanol Injection, Nitrous & Intercooler Cooling 34 06-27-2006 11:47 PM
Nitrous on EJ20? KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-24-2002 02:09 PM
Anybody know of an Impreza with nitrous on LSU campus? travman733 Mid West Subaru Owners Club Forum -- MWSOC 0 01-03-2002 09:49 PM
Nitrous on a Turbo MY01 KillerTHC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-30-2001 09:20 AM
