Old 01-13-2009, 11:04 AM   #1
SharpByCoop
Member#: 199906
2008 Infiniti G37S
World's quickest: 11.13"
Default '06 STI - 500whp / 500 wtq AMR built
Hi folks,
'Coop', here. I am new to the NASIOC forums, and I hope you will enjoy these figures:
Numbers:
Dyno: Dyno Dynamics (zero correction factor)
Tuner: Rob Bonamici
Wheel HP: 500.4
Wheel TQ: 505
Ambient Temp: 60
Elevation: Sea level
Current setup included:
AMR Front-mount intercooler (+100whp increase w/tune!)
AEM gauges: UEGO / Boost w/controller
AEM Meth nozzles in intake tract (2)
ACT 6-puck clutch
Upgraded tuning - 29lbs boost
Previous installations:
AEM Meth injection (into prior TMIC)
High-flow 850cc Injectors
AMR custom turboback 3" exhaust (vibration coupling, two resonators and a muffler)
AMR BMI cold air system
AMR T-60R Turbo unit
AMR Header & up pipe (Amazing welds!)
Walbro Fuel Pump
Hard-pipe inlet hose
TGV deletes and porting
AMR boost solenoid
THIS made a big difference:
Original HP with AMR TMIC: 400whp
I brought the car back into the Automaster shop primarily for a couple of things, and ended up with MUCH more than I anticipated.
I needed gauges, and Rob convinced me about the quality of the AEM gauges. I went with a dash pod and included a whiteface Autometer analog clock. (Time is important, too!)
The AEM UEGO A/F gauge, and the boost gauge with (2) programmable limits.
I wanted a stronger than OEM clutch and we agreed to the ACT 6-puck version. (This was an anticipated need, yet OEM wasn't acting improper.)
I wanted them to push it up and give me two tunes: One for track nights and to really press it. And another for 'safer' around town cruising.
Parts installed, Al and Rob pushed my TMIC as best as they could, but could not press beyond the 400hp limit. (50lbs torque increase, but no more HP.)
They even removed my custom quieter AMR exhaust, and only found a 4-hp increase. So, that wasn't clogging up the progress. What's the holdup....?
The TMIC has a smaller diameter inlet and outlet, even though it was a performance version from the AMR shop. Time to open the holes up...
After querying whether the FMIC would lose my low-end driveability, the guys convinced me the benefits would FAR outweigh any perceived penalty. OK, it's the slow Christmas season, let's go for it... (Of course they were right.)
Forgive the cheesy commentary by me, but here is the video I shot when they told me I was ready:
http://www.youtube.com/watch?v=bITTfaoTimM
Here's the underhood shot. Note the hidden turbo is not rotated, and see the dual meth injectors Al plumbed inline:
Here's the kicker: I still have the OEM lower end. This project is, ostensibly, a bolt-on. Now, I know the rules and understand that this could go awry if I work it too hard or too often. But, I am convinced that the failures of pistons under horsepower stresses is MUCH less than the failures resulting from detonation. And so they have tuned it correctly, and I have to be judicious. This was my choice and their skills.
(The AEM secondary boost setting draws it down to 23lbs and it still made 448whp.)
The drive home was on a crowded hiway, but BOY can I tell the difference. "Insane!"
I hope Rob will come in and comment on whatever I have missed and clarify. Thanks for reading.
Coop
SharpByCoop is offline   Reply With Quote
Old 01-13-2009, 11:06 AM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
welcome to nasioc
any other pics?
Old 01-13-2009, 11:15 AM   #3
SharpByCoop
Member#: 199906
2008 Infiniti G37S
Originally Posted by nhat View Post
welcome to nasioc
any other pics?
Thanks, nhat.
Here it is just before I switched out to the WRX spoiler. I want the 'sleeper look'.
THX.
Coop
Old 01-13-2009, 11:15 AM   #4
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
WHOA! That sounds awesome!
ScoobyNubieToo! is offline   Reply With Quote
Old 01-13-2009, 03:57 PM   #5
1sicWRX
Member#: 104631
96 Cobra, TBird SC
88 Mustang 5.0
That is a very nice. Way to go man, looks really good.
1sicWRX is offline   Reply With Quote
Old 01-13-2009, 04:08 PM   #6
sleepersti04
Member#: 146554
2004 STi WRB
30R
killer numbers
sleepersti04 is offline   Reply With Quote
Old 01-13-2009, 05:46 PM   #7
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Nice #'s for Rob's dyno, but I can't imagine the stock bottom end holding up for long...
Look forward to seeing you on the streets!
Gfunk720 is offline   Reply With Quote
Old 01-13-2009, 05:48 PM   #8
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Agreed very nice power!!
Agreed kiss that stock bottom goodbye
4ST-AIR is offline   Reply With Quote
Old 01-13-2009, 05:48 PM   #9
TurboDXsti
Member#: 106671
2006 Sti
grey
very nice and on the stock block , good for you bro
TurboDXsti is offline   Reply With Quote
Old 01-13-2009, 06:30 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
the hp seems to be peaking early for a 60 lb/min turbo......and dropping 70 hp from peak to redline seems to be alot if my memory serves me right.
Got a boost plot?
Old 01-13-2009, 07:49 PM   #11
SharpByCoop
Member#: 199906
2008 Infiniti G37S
Hi guys,
Thanks for the comments. Yes, I know I am at the upper limits with the lower end. I will have to be judicious in my usage. If that's possible...
Boost plot? Not me, but maybe Rob has that saved. I'll let him respond to that.
Thanks!
Coop
Old 01-13-2009, 11:25 PM   #12
Copper Rex
Member#: 53721
35R Bugeye
[email protected]
Dont worry, it should hold up for a while. Mines been holdin up for quite sometime now on the stock bottom end. As long as shes tuned perfect than you should have no worries. That doesnt mean its okay to drive it like u stole it everyday at 29lbs. of boost neither. There are 2 major factors you need to have a reliable motor. Awesome Tune and lots of DISCIPLINE to go with it. Good luck man.
Copper Rex is online now   Reply With Quote
Old 01-13-2009, 11:28 PM   #13
CosworthSTI77
Member#: 195473
2007 STI
Great looking car and build, but I would start thinking about that bottom end just to be on the safe side, 29psi is pushing it !!
CosworthSTI77 is offline   Reply With Quote
Old 01-13-2009, 11:33 PM   #14
SharpByCoop
Member#: 199906
2008 Infiniti G37S
BTW, I have (2) states of tune (boost). The readings here are at max. My daily driver will *only* be running @23lbs. boost.
I don't anticipate much drama.
Coop
Old 01-13-2009, 11:38 PM   #15
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
I Like. I Agree with Phatron seems pretty early for 60lb/min. Nice numbers!
TDagen is offline   Reply With Quote
Old 01-14-2009, 07:57 AM   #16
venom848
Member#: 189631
1994 Supra TT
very nice
venom848 is offline   Reply With Quote
Old 01-14-2009, 10:13 AM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
the 29psi is not that bad....he's probably only hitting it for a millisecond ~4600rpm.....
And by the looks of his tq tapering off 150 ft*lbs from peak to redline (which is alot compared to most others) in conjunction with his peak hp being around 5600rpm (which is way early for a 60 lb/min turbo, for reference my Green & HTA Green hit peak hp ~6000-6200rpm).......both of these things point to his boost dropping off drastically in the upper rpms. I'd venture to guess his boost peaks at 29psi and is tapering to 21-22psi at redline.
Old 01-14-2009, 10:13 AM   #18
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
The reason why the hp numbers drop at the top end is because it has a 7cm^2 exhaust housing with a 60' lb/min compressor. If this turbo was offer with an 8cm^2 it will be better up top but it will spool a bit later. I'm still impressed with these number and will consider this turbo if had the $2k.
Nice Numbers!!!!
wil06STI is offline   Reply With Quote
Old 01-14-2009, 10:56 AM   #19
AMR
NASIOC Manufacturer
Member#: 171509
Good eye. The TQ drop is due to the 7cm2 housing which "wil06STI" pointed out. This turbo is equipped with our custom billet actuator in which FORGE has custom made for us to fit our specifications. This vehicle holds 29psi straight to redline with no taper. I am also not running much timing up top. If I ramped the timing the TQ would carry a bit more. But before we get tuning happy, we must remember this is a stock engine. 500whp / 505wtq with zero correction is alot of power. So we left it there .
-Rob
AMR is online now   Reply With Quote
Old 01-14-2009, 12:51 PM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
hahah...my guess was a little off ......only by 7-8 psi
what do you consider "not much timing" up top? 16*? or 20* since its got meth?
Old 01-14-2009, 01:32 PM   #21
Demnowicz
Member#: 152277
13 WRX
Ice Silver
wow the FMIC added 100whp with a tune?
is that right?
Demnowicz is offline   Reply With Quote
Old 01-14-2009, 01:33 PM   #22
AMR
NASIOC Manufacturer
Member#: 171509
Not much to us would be around 15*-16* max up top.
-Rob
Old 01-14-2009, 01:41 PM   #23
Phatron
Member#: 36033
CEO PhatBottiTuning
yeah that is low for 93+meth.....
Old 01-14-2009, 02:21 PM   #24
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
That is low up top... 7cm hhhmmm I thought boost taper too, that makes sense though.
Old 01-14-2009, 03:42 PM   #25
modaddict
Member#: 95840
sold to a good bud
awaiting next car
-Rob
-Rob,
with all do respect, prove it. Throw his timing map up.....nothing else.
If it's like all your other tunes it will be about 11.0:1 AFR
modaddict is offline   Reply With Quote
'06 STI 527whp AMR/The Shop/Junior tune SharpByCoop Proven Power Bragging 34 06-11-2009 12:26 AM
over 500whp ls7 427 corvette built heads/cam 48k original miles! 30mpg :) IMPORTIMAGE Vehicle Sales 7 01-31-2009 01:06 PM
Built STI $17,500 Hoorayfortravi Private Vehicle 'For Sale' Classifieds 3 09-21-2008 10:58 PM
Built STI $17,500 373awhp Hoorayfortravi Private Vehicle 'For Sale' Classifieds 0 09-15-2008 06:38 PM
Built STI $17,500 Hoorayfortravi Private Vehicle 'For Sale' Classifieds 0 08-30-2008 12:54 PM
