Old 01-13-2009, 12:59 PM   #1
Richardcranium419
Member#: 156906
2004 STI
AWDtuning Tuned
Default 04 HID to 4 beam halogen ?
I am posting my question here due to the possibility of someone here doing this on there car. Most want the HIDs. Only someone wanting to lose weight on their car for motorsports purposes would want to do this. IMO
I am debating on changing out my 04 STI lights for a set of the Multi Reflector 4 beam halogen WRX head lights. Question has anyone done this before?
Any idea on the weight lose potential of this swap?
What would need to be swapped over?
Could the wires be spliced in?
Would it be possible to change over the lighting wire harness?
This would also fit into the rule books under retro fit/ back dating.
Thanks ahead of time for any info.
PS I want to do the change over with someone local. So I will not have my 04 STI lights for sale.
Richardcranium419 is offline   Reply With Quote
Old 01-13-2009, 01:52 PM   #2
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
You'd lose the weight of the ballasts. Maybe 3lbs tops.
sniper1rfa is offline   Reply With Quote
Old 01-13-2009, 02:13 PM   #3
Richardcranium419
Member#: 156906
2004 STI
AWDtuning Tuned
3 pounds ea? or total? What about the incar hight level?
Old 01-13-2009, 03:36 PM   #4
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Ballasts weigh about 1lb a piece. Leveling motors and associated wiring might weigh a couple of pounds.
Not worth it, IMO. You can find other easier places to shed a few pounds.
Regardless, I think the lights are plug and play. At least, Im 99% sure the STI>WRX conversion is plug and play, so I dont see a reason it wouldnt be the opposite.
cucamelsmd15 is offline   Reply With Quote
Old 01-13-2009, 03:46 PM   #5
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
It's not. The ballasts on the STI are tied directly to the battery because they optimally need the full 12V for startup. The halogen WRX headlights draw power from the harness which may not be able to handle the amps of the ignition from the ballast; as such, many people wire a relay system to the HID ballasts, using the harness as a switch and tying the ballasts directly to the battery (for putting STI HIDs on a WRX).
IMO, don't do it, not worth the effort or time.
dLo R6 is offline   Reply With Quote
Old 01-13-2009, 03:46 PM   #6
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
I have no input on the weight savings or feasibility, but I have a question:
Which rule book are we looking at? What type of motorsports?
I only ask because in the solo book the WRX and the WRX/STI are on different lines, so UD/BD does not apply.
mccanixx is offline   Reply With Quote
Old 01-13-2009, 04:03 PM   #7
cucamelsmd15
Member#: 122980
Not sure about the battery harness stuff, but I agree. More trouble than its worth
http://forums.nasioc.com/forums/show...hlight=sti+hid
Old 01-13-2009, 04:13 PM   #8
Richardcranium419
Member#: 156906
2004 STI
AWDtuning Tuned
Thanks for the input on this.
I could lose weight in other areas, but not much more left to lose.
Car is down to 2824 now. With out me in it and 3/4 tank of gas. And almost full interior. The interior will also be comming out soon.
Old 01-13-2009, 07:56 PM   #9
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
What class? What type of motorsport?
speedyHAM is offline   Reply With Quote
Old 01-13-2009, 08:03 PM   #10
full of dents
Member#: 181717
12 sti hatch
w r b
ill tell ya a better thing. we trade headlights and u get to have the benefits of weight loss
full of dents is offline   Reply With Quote
Old 01-14-2009, 11:13 PM   #11
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
as an electrical engineer i can tell you there is a reason i didn't go that route when i installed mine - further searching on that topic showed me the relay setup. the stock halogen harnesses just aren't designed to flow that much current on ballast ignition, and there have been cases where the wiring has melted due to excess temperature from the current. for the most part it'll work, but i decided to be more careful.
04 WRX to 04 STi HID conversion mygreenbird007 Electrical & Lighting 2 12-20-2007 12:23 PM
04-05 headlight: add cut-off to hi beam housing? scooby_x Electrical & Lighting 4 11-01-2007 08:49 AM
04 - 05 Subaru JDM HID Headlights 4 sale! CrAzY AsIaN Private 'For Sale' Classifieds 1 07-27-2006 11:20 PM
BRAND NEW CATZ 9007 dual beam hid system 4 sale chav101 Private 'For Sale' Classifieds 1 05-08-2005 11:09 AM
STi HID Projectors + High Beams Imprezer Interior & Exterior Modification 22 06-22-2002 10:25 PM
