Old 01-13-2009, 08:31 PM   #1
CYNCRVR
Member#: 190363
2005 Wrx Sti
Default APS cold air and Cobb Accessport
im running stage 2 with the cobb accessport can i put an aps cold air intake on without any additional tuning?
CYNCRVR is offline   Reply With Quote
Old 01-13-2009, 08:37 PM   #2
novacivic
Member#: 117980
2005 sti
wr blue
what do the map notes say?
Designed for cars with stock intake!!!
If you really want it then do it and log the car a couple of times and make sure everything is ok.
novacivic is offline   Reply With Quote
Old 01-13-2009, 08:42 PM   #3
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Technically, you can, but it would not be in your best interest. If you want to put on the intake, do it and get protuned.
k04sti is offline   Reply With Quote
Old 01-13-2009, 08:43 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Bad advice. Logging won't do crap. DO NOT run the intake at all whatsoever.
Old 01-13-2009, 08:48 PM   #5
1sicWRX
Member#: 104631
96 Cobra, TBird SC
88 Mustang 5.0
The OTS map is also compatible with Cobbs short ram intake. Get a protune to maximize the potential of your APS CAI.
1sicWRX is offline   Reply With Quote
Old 01-14-2009, 12:18 AM   #6
CYNCRVR
Member#: 190363
2005 Wrx Sti
alright thanks unabomber, and the rest. will not run.
Old 01-14-2009, 12:40 AM   #7
p01ntb1ank
Member#: 134299
you can run it as long as its the 65mm version.
p01ntb1ank is offline   Reply With Quote
Old 01-14-2009, 07:06 AM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You need to STOP posting when you have no idea or proof. You can can ONLY run the intakes listed on in the sticky thread in the AccessPORT forum. How do I know this? I asked Cobb directly. Proof>>>>internet opinions.
Old 01-14-2009, 10:41 AM   #9
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
The reason cobb will tell you that the ONLY intakes you can run on their OTS maps is that they are INCREDIBLY careful and anal retentive about their claims. I am not saying this is a BAD thing, its just the way it is.
They will not release a product or make a claim without a ton of testing (I mean a LOT, seriously, loads of testing) to ensure that it will work well.
As there are many aftermarket intakes other than theirs, taking the time to test all those intakes, is just not a realistic proposition. Therefor, its easier for them to just say only stock, or their intake.
The reality is that there are a couple intakes out there that DO WORK FINE. And yes, there is proof. A lot of people having pulled datalogs, showing no problems, IS proof.
Cobb telling you no, doesnt change the reality that other intakes DO WORK FINE.
Saying datalogging does nothing is laughable at best. I am not even sure where someone can come up with that mindset. Datalogging tells you beyond a shadow of doubt how your car is running. In other words, if you slap an intake on your car, regardless of it being the Cobb intake, or something you cobbled together from old soup cans, you can datalog the car and know 100% if the car is running safely.
I really think that telling people NO, without explaining why or why not, does a huge disservice to them. If you understand what makes an intake work well or not work well, and what intakes out there fit certain specs, you can tell right off if something is most likely going to work. Then you can look at overall results from years of using a part, and come to a very solid conclusion.
Here is the reality
Stock intake
Cobb short ram+heat sheild
SPT short ram+ heat sheild
K&N Typhoon short ram+heat sheild
APS65mm cai
ALL OF THOSE have been shown to work well with either no engine management, or with the AP off the shelf maps. The AP, just like the OEM ecu, can adapt to minor changes just fine, and none of these intakes cause anything other than VERY minor changes. We are talking .1-.2 difference in AFR right off, which the ECU adjusts and compensates for withing @100 miles.
Defiant Autospeed is offline   Reply With Quote
Old 01-14-2009, 10:42 AM   #10
Davenow
Member#: 23676
Originally Posted by Unabomber View Post
Bad advice
Yes, yes it was. How about real info instead of blanket statements?
Old 01-14-2009, 11:01 AM   #11
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Here is the reality
Stock intake
APS65mm cai
Now this is very good information it should be added to the Accessport sticky.
jnorth85 is offline   Reply With Quote
Old 01-14-2009, 11:24 AM   #12
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
BTW, dont get me wrong, I am not saying slap it on and never bother making sure. While you can be fairly safe (as safe as any non tuned motor can ever be, and any OTS map, is untuned) doing so, you really should be logging the car after you add any mods, just to make sure. Its not hard to see what the IAM is, and if its way down, you know there is a problem.
Honestly, you should do that even if you use the exact mod list that Cobb (or any tuning company) recommends. You can never EVER just slap a mod on your car and know 100% that it will run safe. I have seen cars that slap engine management on (of any variety, not just the AP) and run so poorly that they will likely have engine damage in short order, and I have seen them run amazingly well. Even an OTS map, with the exact recommended supporting parts can be very unsafe. Or very safe.
What baffles me is that people jump up and down about running a non cobb intake, but they completely ignore the fact that Cobbs OTS maps are also designed for a high flow cat downpipe. People scream and yell about an intake, but they completely ignore that many people are running catless downpipes.
Old 01-14-2009, 11:28 AM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if you have to ASK....ASSume NO as in NOT
more will be revealed
Old 01-14-2009, 11:36 AM   #14
PlanetGranite
Member#: 156635
2005 Sti
CGM
I had to remove my APS 65mm intake after I switched from UTEC to the AP. The short term fuel trims were maxed out at idle, because under the cobb map, the car couldn't get to the target 14.7 afr.
PlanetGranite is offline   Reply With Quote
Old 01-14-2009, 11:37 AM   #15
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
If your really wanting to use the intake, id reccommend putting on the intake and getting a protune.
Super_HKS is offline   Reply With Quote
Old 01-14-2009, 12:13 PM   #16
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
How long did you give it?
I ask because 9 out of 10 cars are fine with it.
But, this is an EXCELLENT example of why you have to datalog ANY changes. Regardless of what others experience.
Really, and this SHOULD be obvious, if you have an AP and want an intake and dont already have one, just buy the Cobb intake. Its not that much more expensive than the other aftermarket intakes, in fact its cheap than some.
If you have an intake, install it and datalog it. WHen you first start the car, if the AFR isnt where it should be, let it idle a while (20 min maybe) then drive it NICELY around the block or something for 15-20 min, then see where the AFRs are. They should be much closer, if not dead on.
If they arent, maybe give it a little longer. If it doesnt come in line then, take it off till you get tuned.
But in general, those intakes listed, work fine. This guy is an example of one that doesnt. Datalogging is the key
Old 01-14-2009, 02:05 PM   #17
PlanetGranite
Member#: 156635
2005 Sti
CGM
Car was still warm from my drive to the shop, we set the UTEC to bypass, loaded the COBB stg 2 map, and watched the short term fuel trim and idle hunt for about 10 minutes until we pulled the plug. Switched over to a factory intake within a matter of minutes, and BAM . . . no more idle hunt or fuel trim.
YMMV.
Running 92 oct (on the 91 oct map) @ sea level @ approx. 65 degree temp.
05 STI Perrin Header, Invidia G200, Samco MAF, APS Cold air and more bcorn Engine/Power/Exhaust 19 02-02-2010 02:32 PM
brand new aps cold air and PE 800cc injectors kefalonitis Engine/Power/Exhaust 0 02-08-2009 12:17 PM
APS Cold Air and MANY STOCK WRX PARTS gnarlyWRX Engine/Power/Exhaust 3 02-25-2007 01:51 PM
Noticable difference between APS Cold Air and TurboXS SRI? Inprogress Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-18-2005 11:06 AM
For Sale: APS DR725 FMIC, APS BOV and APS cold air intake syoung0298 Private 'For Sale' Classifieds 2 08-05-2005 04:32 PM
