Old 01-14-2009, 03:19 AM   #1
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
Default p0301! compession test?
Well I've thrown the same code for the third time misfire cylinder 1 and figured enough was enough. Pulled the plugs out that only had 7k miles on them they looked perfect. The decided to do a compression check.
I did it cold cause by the time I got everything off it was.
1. 107
2. 105
3. 105
4. 105
They are within 10% of each other. But couldn't for the life of me find anything on the search for cold compression specs. Is there one?
I rotated that coil pack from 1 to 3 and that plug from 1 to 2 so now I can follow the problem if it comes up again but anyone got any other thoughts if it comes back or knowledge on the compression?
Thanks
Greenie
greenspeed is offline   Reply With Quote
Old 01-14-2009, 11:00 AM   #2
r8r4life
Member#: 101464
Try the injector if that doesn't work.
r8r4life is offline   Reply With Quote
Old 01-14-2009, 01:12 PM   #3
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
That was going to be my next step but I don't want to get injectors just yet cause I'll end up getting 650's and the a huge turbo and blah blah Lol
Old 01-15-2009, 02:00 PM   #4
r8r4life
Member#: 101464
Oh I meant swap around like you did with your coils.
Old 01-15-2009, 03:29 PM   #5
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
Check the lash between the cam and the lifter. .008" intake and .010" exhaust. My guess is your exhaust valve clearance is too tight.
PSolbergfan is offline   Reply With Quote
Old 01-15-2009, 04:29 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
greenie, with compression specs that tightly grouped i would initially look elsewhere for your problem (ie, coil/injector).
Old 01-15-2009, 10:53 PM   #7
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
I never thought of checking valve clearances.
I have an automotive class in college this semester so I might do a valve clearance check while I spend all semester tweaking my car
Old 01-15-2009, 11:49 PM   #8
mrjoshm
Member#: 100437
2002 wrx wagon
cobb stg 2, PPGs, wrb
how cold was the car when you did the check? like the next morning? i assume that subaru knows the car is going to be cooling down a bit when doing the check since they know what the book time is for removing the parts..
mrjoshm is offline   Reply With Quote
Old 01-16-2009, 12:24 AM   #9
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
I pulled the car in the shop around 2 and did the test aroung 5
Compession test prob builtsubie Built Motor Discussion 15 01-11-2010 01:46 AM
P0301 + Compression test says: 90-150-150-150 0db Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-14-2009 07:56 AM
compession check blazin sti Subaru Conversions 2 01-21-2006 11:57 PM
how accurate are compession/leakdown tests BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 06-02-2005 03:52 AM
P0301 Misfire Cyl 1 and CE light 2yLiTe Normally Aspirated Powertrain 20 11-11-2001 01:13 PM
