Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 01-14-2009, 06:15 PM   #1
Maxwell Power
Vendor Sales Rating: (16)
Member#: 190729
Default Turbos, Engines, Custom Hybrid Components, Valvetrain and more...
For those of you that don't know, Maxwell Power Services is where it's at!
We have been building high reliability Subaru engines for aircraft for many years. Located in Arlington at the airport, we have a very large facility (20,000 sq ft +).
At our facility you'll find:
Engine Assembly Clean Rooms
Hanger with Subaru powered Aircraft and install bays
Superflow engine dyno
Engine Techs with over 30 years combined experience
Machine Shop
*4WD Chassis dyno coming in March*
Maxwell Propulsion is a dealer for ATP factory location Garrett Turbos like the GT35R, 28R, 3071R and 3076R.
If you haven't seen these turbos, you need to!
They are very stylish with polished compressor housings, standard!!
They are full Garrett Dual Ball Bearing Cartridges with custom compressor and turbine housings to fit our tight space requirements in our Subarus. These turbos spool very fast and feel amazing. For example, the GT3071R spools like the factory VF39/43 but makes over 100 more horsepower.
In stock we have:
GT35R w/ adjustable internal wastegate, Used condition: $1200.00 Retail is $1995.00
GT3071R w/ adjustable internal wastegate: $1550.00 shipped **SPECIAL PRICE**
Tial 44mm EWG Red: $375.00
Tial 38mm EWG Silver: $225.00
includes gaskets, nipples and bolts
11mm Oil Pumps Silver: $160.00
Pumps are disassembled and the relief valve and bore are polished to increase reliability. Factory pump found in the 08STi. Excellent pump for your high hp high rpm build.
FP Green, 8cm2, 3" inlet. Used. SOLD
4340 Billet Crankshaft 79mm $1450.00
Supertech Valvetrain Dual Springs, Titanium Retainers, Locators $400.00
GMS Turbo Inlet Red $135.00
GMS MAF Tube Red or Black $55.00
GMS Radiator Hoses Black $75.00
New EJ257 Shortblock $1800.00
New WRX Valvetrain (springs, retainers, Valves, locators, locks, buckets w/shims) Pulled from brand new heads, never used. $300.00 Picture shows only one side. Price is for both heads
STi Valve Springs and Retainers $100.00 Used 15k miles.
* All ATP turbos come with installation kit:
Oil feed line with restrictor.
Oil drain line with clamps
Water lines
Discharge hose with clamps
Pressure port
Up pipe spacer
Stepdown sleeve for 2.4 inlets (not recommended, but supplied regardless)
EVERYTHING you need to install an ATP turbo. This is what makes these turbos a deal.
Compare to non-ball bearing color coded turbos at 1399, add braided oil line for 75 dollars and you are only 50 dollars less than the first ATP Ball bearing turbo.
Building a Hybrid? We have a custom Hybrid rotating assembly here on the shelf:
Custom JE Pistons (99.5mm/ 8.8:1/WRX heads)
Tool Steel Wrist Pins
Custom Long Rods
STi crank
ACL Bearings
$1700.00
Anything else you need or want we can get in short order.
We do Engine Builds. Dominic and Craig are currently building some very wild custom builds to include a 9k rpm capable 2.35L and a twin GT2860RS turbo system that will make full boost by 3300rpm and carry 700hp at over 8krpm.
Call for more information.
Maxwell Propulsion Systems
19132 59th Dr NE
Arlington, WA 98223
360-474-8118
www.maxwellpropulsion.com
__________________
[SIZE=3][COLOR=red][I]Engine builds * Custom Fabrication * Albins Gearsets* DomTunes. [SIZE=1][COLOR=magenta]PBFL[/COLOR][/SIZE][/I]
[SIZE=2][COLOR=black]
[/COLOR][/SIZE]
[SIZE=2][COLOR=black]Hydra, AEM, COBB, Open Source, JE, Tial, Crower, Garrett, ARP, ATP, Racing Brake, Ferrea, Perrin,
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Maxwell Power is offline
Old 01-14-2009, 09:21 PM   #2
forenote
Member Sales Rating: (4)
Member#: 115213
06 wrx
cgm
Default about engines
i talk with guys over there .. Very nice .. and know what they are talking about ..thanks for your help guys ...
forenote is offline
Old 01-15-2009, 01:29 AM   #3
sanjay
Member Sales Rating: (7)
Member#: 100624
2004 WRX Wagon
Do you have any pictures of the FP Green and GT35R? What kind of condition are the turbo in?
sanjay is offline
Old 01-15-2009, 12:24 PM   #4
Maxwell Power
Member#: 190729
Both turbos are in good shape with no excessive shaft play and good bearings. I'll take pictures and a video clip of me spinning the shafts if you'd like.
I'll post them up later on today.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 01-15-2009, 06:39 PM   #5
zeropsi
Member Sales Rating: (27)
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
EJ257 longblock - comes with the heads I'm guessing, but what about the intake?
I've been following a lot of threads about 2.0 based strokers. Any kits for that?
zeropsi is offline
Old 01-15-2009, 07:08 PM   #6
Maxwell Power
Member#: 190729
good catch. Sorry that's a typo. It's a new shortblock. Sorry.
I have some pistons on order for a 2L stroker kit. I have the rods, crank and bearings already. I'm just waiting on the pistons.
I have a complete stroker shortblock on hand. It's a base stroker engine.
EJ205 block
Coated CP pistons (92.5mm bore)
STi rods
STi crank
ACL bearings
$3000.00
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 01-15-2009, 07:30 PM   #7
zeropsi
Member#: 175453
AE86 GT-S coupe
Nice! Fully assembled? With the rods being stock STi, what redline would you recommend, based on what the rod/stroke ratio could support?
zeropsi is offline
Old 01-15-2009, 07:51 PM   #8
Maxwell Power
Member#: 190729
It is fully assembled and sitting here.
I recommend a redline of 8000+. The pistons are lighter than the 207 pistons and lighter than the STi pistons so the load on the rods is less at the higher rpms. The rod ratio affects the power band a little up there as well, but timing the cams properly would help get it back.
Crap, if an RB26 has a ratio of 1.5 and can do what it does, there's no reason we couldn't get this 1.66 ratio to scream.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 01-15-2009, 08:01 PM   #9
zeropsi
Member#: 175453
AE86 GT-S coupe
May just be interested and will give you a call sometime tomorrow.
Thanks for the info, now just to find some JDM heads.
zeropsi is offline
Old 01-19-2009, 08:52 PM   #10
Maxwell Power
Member#: 190729
Pictures of the GT35R.
This is a used GT3582R Center section with brand new ATP turbine and Compressor housings. It is available with a standard .63 A/R 4 bolt style Turbine housing for a rotated setup if someone desires. If purchased with the ATP turbine housing, a new ATP install kit will be included.
Install Kit:
ATP Install Kit:
Water lines
Pressure port
Up pipe spacer
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 01-22-2009, 06:44 PM   #11
Maxwell Power
Member#: 190729
.63 A/R turbine housing for GT3582R. used. $200.00
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 01-27-2009, 02:23 AM   #12
vdubvr6
Member#: 189644
what do you have in the form of a stock style STi complete engine? i spun a rod bearing in my '02 wrx and would rather swap the entire engine than try to break down the block to replace bearings.
OR
is there a much cheaper alternative i'm missing to getting my issue fixed? and while inside the block, swapping out some internals to make her a bit nastier than the stock WRX numbers?
thanks for any help.
Joel
vdubvr6 is offline
Old 01-27-2009, 10:35 AM   #13
ownnij
Member Sales Rating: (17)
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
pmed for some parts for my build..
ownnij is offline
Old 01-27-2009, 01:23 PM   #14
Maxwell Power
Member#: 190729
OR
Joel
sorry, don't have any complete factory STi engines. We do custom builds for the most part. We can order just about anything, but I don't tend to keep bone stock longblocks around. I have custom longblocks available. I'd offer you one, but you said "cheap". We don't do "cheap" when it comes to custom builds.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 02-04-2009, 01:45 PM   #15
Maxwell Power
Member#: 190729
Maxwell Propulsion Systems is now Maxwell Power Services.
To put it short, Craig Woolman and myself (Dominic Acia), have taken over the automotive division of Maxwell Propulsion Systems. Since we're in the same building, do the same job, have the same equipment, nothing has really changed except a lot of paperwork, new owners and the new name: Maxwell Power Services.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 02-05-2009, 09:10 AM   #16
Rasmusson14
Member Sales Rating: (12)
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Does that FP Green have a water jacket or is it oil cooled only? Any shaft play and pics?
Rasmusson14 is offline
Old 02-05-2009, 01:35 PM   #17
Maxwell Power
Member#: 190729
I'm sorry, I forgot to update the thread. The turbo is sold.
It was water cooled and oil cooled.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 02-05-2009, 01:38 PM   #18
Rasmusson14
Member#: 77658
Dah! Wish I would have seen that earlier.
Old 02-05-2009, 01:40 PM   #19
Maxwell Power
Member#: 190729
you could buy one of our hybrid rotating assemblies and then get the GT35R. We can do cams too!
You know, because money is no object...
spend all you want, they'll print more.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 02-05-2009, 02:14 PM   #20
Rasmusson14
Member#: 77658
Don't get me started on the idiots who are running this country.......
I see you do custom cam grinds, what about a JDM cams? I'm going to be swapping a version 7 and fear that cams will cost an arm and a leg if I ever go that far with this build.
Old 02-05-2009, 02:24 PM   #21
Maxwell Power
Member#: 190729
if you send the factory cams, we can have them ground to just about whatever you want.
I'd recommend sending the whole head to us. We can get the cams ground, put new valves in, grind the seats, new buckets and set the valve lash properly. They'll be like brand new heads.
We also do porting. CNC or hand porting.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 07-18-2009, 11:38 AM   #22
Beam
Member Sales Rating: (1)
Member#: 29742
2011 STI
15 S1000R
Bump for a great vendor!
Dom, when I was putting in the turbo, Dallas actually connected all the lines, and I'm not sure the oil restrictor went in. Where in the supply line is it, and what does it look like form the outside?
Beam is offline
Old 07-18-2009, 01:21 PM   #23
Maxwell Power
Member#: 190729
It's hard to miss. It's gold color and goes from an AN-4 to the turbo.
__________________
[/COLOR][/SIZE]
[/COLOR][/SIZE]
[/COLOR][/SIZE]
Old 05-11-2011, 01:13 PM   #24
silvrrubi0388
Member Sales Rating: (5)
Member#: 182473
subscribed... may be pming you about a 2.2 build..
silvrrubi0388 is offline
Closed Thread
Rota Torques,aps cai 65mm, inlet hard pipe and hybrid gfb bov and more Combsysti Private 'Wanted' Classifieds 0 09-24-2007 10:28 AM
FS: LI, NY: Bosal Downpipe, td04 turbo, UP, DP, exhaust manifold, midpipe, and more chrisarella Engine/Power/Exhaust 23 05-25-2007 02:38 PM
FS- Brand New APS Turbo Inlet Custom Powdercoated Candy Blue and TurboXS FMIC RR BuGGz Private 'For Sale' Classifieds 11 06-27-2006 03:13 PM
Turbo, Rack, Springs, STi stuff, Camera, and more! nhluhr Private 'For Sale' Classifieds 38 11-05-2004 08:30 PM
