Old 01-15-2009, 02:11 AM   #1
SP33Daddict
Member#: 197965
2005 STI Impala 300z
Blue, Burgundy
Default Car died today, advice plz.. If your tranny dies will the engine start?
Ok, so after a week or so of extensive weight reduction, I took my car (1996 L) out for a drive today. All seemed to be going well so I took it out to my favorite local mountain road to see if all that work made any difference. Unfortunately, on the way back toward my house, the car started losing power on the uphill. After the car was near a complete stop, I downshifted to L2, no response, L1, still nothing. The car completely crapped out on me. When I tried to crank it, it would turn, but wouldn't actually start. Weird thing is even when the car was completely off, the radiator fans would still turn. I started thinking maybe I crossed some wires up or something when I rehooked them, but then I went to check the fluids, everything was good except for the tranny fluid which was empty!! This came as a suprise to me because when I checked it a couple days earlier, it was full. When I looked under the car, sure enough tranny fluid was coating the underside. Kinda strange b/c I couldn't find where it was leaking from.
If you have read this far, thank you...
So anyway, I've had problems with torque bind until this point, but people talk about it like it's common and won't cause damage so I didn't think much of it and was planning to change the tranny fluid tomorrow. Unfortunately, thats not gonna work. Now, my engine won't start and I had to get it towed back today. My question is... Based on what I have written would you say that if I did not wire my car correctly it could cause this problem or the tranny was about to go out anyway? Also, would a bad tranny keep a car from starting?
It isn't that big of a deal because I was planning to do an STI swap anyway, but with only 101,000 miles I expected it to last until I could get the new engine in. Although I did want to try it out on some autocross courses first. Any help is greatly appreciated.
SP33Daddict is offline   Reply With Quote
Old 01-15-2009, 02:16 AM   #2
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
What did you do in terms of weight reduction?
XanRules is offline   Reply With Quote
Old 01-15-2009, 02:35 AM   #3
SP33Daddict
Member#: 197965
Blue, Burgundy
I removed the carpet, all seats except for the driver, chipped out all of the tar chips, removed most of the sound deadening mats on the firewall, windshield fluid tank, spare tire, everything else from the trunk, headliner, gutted the dashboard, removed hubcaps, airbags, speakers, stereo system, relocated ecu where passenger airbag used to be so I could remove ecu brackets, gutted rear doors completely and most of front doors (put door cards back on front doors), removed sunvisors, rear seat support bars, mud flaps, side trim, plastic front grill, various nuts and bolts, and a couple other things... thats about all I can think of right now. I had to completely remove the dash to take the airbags out so I unhooked a lot of wires and I think I put them back in the right way, but is there anyway that not hooking one of them in right could cause a tranny failure? (ECU was definately right)
Old 01-15-2009, 02:45 AM   #4
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
windshield fluid tank is connected to some fuses.
It could have been the ECU brackets, or maybe something in the dash when you gutted it?
Those are my only ideas.
Old 01-15-2009, 08:12 AM   #5
obs2008
Member#: 163068
08 outback sport
is this goin to be a race car/complete and total beater or are you just THAT gangsta?
obs2008 is offline   Reply With Quote
Old 01-15-2009, 08:49 AM   #6
nojokesniper
Member#: 192623
the tranny failed because there was no fluid in it
nojokesniper is offline   Reply With Quote
Old 01-15-2009, 10:35 AM   #7
Einimas
Member#: 176111
AT? or MT?
Einimas is offline   Reply With Quote
Old 01-15-2009, 12:15 PM   #8
SP33Daddict
Member#: 197965
Blue, Burgundy
Yes I'm planning to make this thing a track car, but I am planning to drive it to the track. So, yeah... I'm that gangsta :P It's an automatic tranny... what could make the transmission fluid all leak out like that?
Old 01-15-2009, 12:36 PM   #9
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
a hole?
watchunglava is offline   Reply With Quote
Old 01-15-2009, 01:15 PM   #10
Einimas
Member#: 176111
I dont know anything about auto, but you could start the engine with clutch engaged on MT so it's probably your tranny.
Old 01-15-2009, 01:30 PM   #11
watchunglava
Member#: 168862
fill it up with the cheapest tranny fluid you can find and see if it starts . should cost you $5.
if it doesnt its something else then yea?
Old 01-15-2009, 03:18 PM   #12
SP33Daddict
Member#: 197965
Blue, Burgundy
I took your advice and added new tranny fluid. It was topped off, but it still wouldn't start I checked under the car to see if it was leaking out somewhere, but didn't see any dripping or puddles. Strange situation. I guess I'll just have to start the swap a little earlier than I had planned. I really want to make sure that I have all of the wiring and everything else correct so that if it was something on my part, I can avoid it on the swap... really don't want anything to happen to the more expensive sti tranny if it can be avoided. Does anyone know where to find a really thorough wiring diagram for the gc8 that can show where everything plugs in? If not, I guess I'll just go with a front clip and take tons of pictures.
Old 01-15-2009, 03:21 PM   #13
onslot19
Member#: 191753
2003 Baja, legacy ss
Baja Yellow & black trim
i have the same problem it turns out that the input shaft seal went bad
onslot19 is offline   Reply With Quote
Old 01-15-2009, 03:26 PM   #14
watchunglava
Member#: 168862
still why wont it start???? did it sieze and it wont go into neutral? you said its cranking????? so i dont get it? do u have spark? do you have gas? can you move through the gears do you hear the transmission functioning or is it siezed?
i have a shop manual so if you need the wiring diagram hit me up ill email it to you.
Old 01-15-2009, 04:07 PM   #15
Storm
Member#: 5218
96L Most Over-
Developed Beater
I would think the ECU would be throwing codes if the motor was dying. Do you have any codes that might shed a little light on the subject? I don't know if there's a failsafe between the TCU and ECU which would inhibit the motor from starting if the trans died.
Jay
Old 01-16-2009, 12:46 AM   #16
SP33Daddict
Member#: 197965
Blue, Burgundy
Old 01-16-2009, 01:10 AM   #17
watchunglava
Member#: 168862
yahoo wont let you send files that big, do you have a gmail account?
its clicking because you have drained your battery now.
could be your tourque converter.
input shaft seal would allow the leak but not the non start issue.
you have to find where the leak is coming from.
you said u filled it with fluid.
did it leak out again?
if so from where?
if not, why not?
i would look at the torque converter
Old 01-16-2009, 01:14 AM   #18
watchunglava
Member#: 168862
your tranny is most likely toast too dude .
Old 01-16-2009, 01:16 AM   #19
watchunglava
Member#: 168862
good news is , cars tottaled now , you could get a new one for way cheaper than replacing half your drivetrain
Silly streetracers, dying only counts if youre IN the school zone... cucamelsmd15 Off-Topic 108 06-10-2011 02:39 PM
What happens if your Tranny is low on fluid? Sephro Off-Topic 3 09-28-2006 10:59 AM
After install Helix catless DP wills the Engine light comes on? sti-bullet Vancouver Impreza Club Forum -- VIC 7 03-16-2006 02:14 AM
How do you know if your wideband is telling the truth? xFactor Engine Management & Tuning 10 09-14-2005 12:11 PM
How to tell if your audio system is the upgraded factory Blazin Car Audio, Video & Security 17 09-01-2005 01:06 AM
