Old 01-15-2009, 03:11 AM   #1
subaru fan
Member#: 127910
04 STI silver
Default vf39??
right now iam stage 2 on cobb ap full turbo back
and on a stock turbo what are some modds i can put on my car before i get a protune to get the most horse power
so with out touching big engine internals
any words of advice thanks
and any possibles of porting and polishing my turbo out?
subaru fan is offline   Reply With Quote
Old 01-15-2009, 03:36 AM   #2
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
you could port/polish..you can install 20g compressor wheel. you can install meth. there's really lots of stuff you can do, your question is way too vague
VladiWrX is offline   Reply With Quote
Old 01-15-2009, 04:05 AM   #3
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
Meth inj.
intercooler
fuel pump
ewg
mrubino83 is offline   Reply With Quote
Old 01-15-2009, 04:18 AM   #4
dan240
Member#: 57969
2004 WRX
wrong forum
dan240 is offline   Reply With Quote
Old 01-15-2009, 08:18 AM   #5
Chris_Lee
Member#: 110667
2006 WRX
A front mount and a CAI will get you some more ponies when you go get a protune. Don't put the CAI on till the day of the protune. Other than that start saving for a 20g or one of the Blouch Dominators. Just my .02 cents.
http://www.blouchturbo.com/turbos/Su...minator_2.5R_/
http://www.blouchturbo.com/turbos/WR...Dominator_1.0/
Chris_Lee is offline   Reply With Quote
Old 01-15-2009, 01:56 PM   #6
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
My vote goes to EWG. The IWG on my vf-43 seems to be doing a pretty crappy job at holding boost levels after getting pro-tuned. An EWG will flatten your torque and hp curve by allowing you to hold more boost as you get towards redline.
I also think you should look into a set of port-matched, ceramic coated manifold elbows. This will make your boost response almost immediate and if you want a bit more top-end you can pick up a cross pipe to go with them.
Injectors are also a good idea as most pro-tuned STI's get pretty close to maxing out the stock ones. If you plan on going with a larger turbo sooner than later and don't want to buy injectors twice (like myself) you can pick up a 255lph fuel pump to help lower IDC's for the mean time.
Steve.804 is offline   Reply With Quote
Old 01-15-2009, 01:58 PM   #7
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
turbo inlet-top mount-ewg-injectors-fuel pump-headers-pnp everything(grimmspeed) phenolic spacers-meth-water sprayer-gears! the list goes on and on
06HAWKMAN is offline   Reply With Quote
Old 01-15-2009, 01:59 PM   #8
klenboy
Member#: 130521
2006 Subaru STi
I think some EL headers with a CAI and turbo inlet will really wake up that VF39.
klenboy is offline   Reply With Quote
Old 01-15-2009, 01:59 PM   #9
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
and a fuel pump wont really lower idc that is the job of the pressure regulator that you can mod for free to give you about 10 more psi
Old 01-15-2009, 02:01 PM   #10
lowrider89
Member#: 143022
2005 modded S4
EQUAL length headers.... about 10 WHP right there
lowrider89 is offline   Reply With Quote
Old 01-15-2009, 02:20 PM   #11
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I vote for a PnP exhaust manifold and highflow x pipe combo
http://www.grimmspeed.com/catalog/pr...7ggmmh8pba2ls3
A nice up pipe is always a good addition as well!
Don't hesitate to ask us if you have any questions!!
Mike
GrimmSpeed is offline   Reply With Quote
Old 01-15-2009, 08:20 PM   #12
downsti
Member#: 63179
2006 Stock Turbo STi
[email protected] VF39
front mount is waste of money for the stock turbo
it all comes down to the tuner skills, and of course with right boost controller set up
EWG is not needed
downsti is offline   Reply With Quote
Old 01-15-2009, 10:14 PM   #13
subenerd
Member#: 72630
2004 STi
Ask your tuner.
subenerd is offline   Reply With Quote
Old 01-15-2009, 10:41 PM   #14
Shamoo
Member#: 188107
2007 STi. [email protected]
Green Wheelz
Agree'd FMIC is a waste.. if anything go with a big TMIC like APS or TurboXS.
Go with the APS 70mm off the bat, don't waste your money on a 65mm.
Tapering boost is the product of the stock turbo's exhaust side being too small, nothing to do with IWG. A MBC and/or 3port BCS will greatly help with boost control and spool-up.
I'd go with EL headers or even UEL before PnP the stock manifolds.
I'd definitely pick up bigger injectors and a fuel pump. The fuel pump will NOT lower IDC's. The stock injectors could easily be maxed out on an agressive Stage2 tune.
How'd you come up with that??
EWG is not needed
Listen to him^^ Haha.
Shamoo is offline   Reply With Quote
Old 01-16-2009, 09:44 AM   #15
Chris_Lee
Member#: 110667
2006 WRX
EWG is not needed
subaru fan asked....I can put on my car before i get a protune to get the most horse power.
These are simple bolt ons he can do.
He needs to talk to the tuner about which boost control solenoid he likes to use.
If he is going to get a costume tune, the tuner will be able to make the most out of a CAI and a fmic. Now if he was running a ots map or something there would be no benefit but with a tune he will see gains. The situation really is dictated by the tuners abilities and what he likes to tune. Definitely contact the guy that will be tuning your car and get some input from him.
Old 01-16-2009, 11:08 AM   #16
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
My wastegate is simply not holding the boost pressures at upper RPM's. No tuner can tune around a faulty mechanical device. You could add a helper spring but if you havnt gotten tuned yet and have some extra cash to spend I'd just go with an EWG and reek the benefits.
Why would you not want PnP stock manifolds? I've seen nothing but great results with these (my own car being one of them) and compared to the price of aftermarket header's they're a deal. Plus you dont have to worry about crappy welds cracking.
I stand corrected on the fuel pump. I always figured the higher flowing pump helped with IDC's not sure where I picked up on that...
Old 01-16-2009, 12:00 PM   #17
Shamoo
Member#: 188107
Green Wheelz
Yes definitely talk to your tuner about what they like and feel comfortable with doing. A FMIC on the stock turbo is just not worth it, I know of alot of tuning headaches that come along with that.. screwy MAFv, rich dips in the AFR when the MAF has registered the extra air but it hasn't gotten through the whole IC setup up yet.. just too many problems with FMIC on the stock turbo. The stock STi TMIC works just fine but if he wanted to upgrade, I'd go with either the APS or TurboXS TMIC.
Nothing will help with your boost tapering off in the upper RPM's.. that's what the stock turbo does. The exhaust side is just too small to hold boost steady. Rigging up helper springs may work but your just putting the turbo out of its efficiency range and overworking it. Tapering boost is not a bad thing though if you know how to tune with it.
Like I said I would go equal length header before PnP manifolds. And if you don't buy a crappy header you won't hav crappy welds.. I haven't heard of anyone having cracking issues lately. There is a reason the JDM versions come with an equal length manifold .
Old 01-16-2009, 12:26 PM   #18
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
I did a lot of research on other people's pro-tuned results and it's not the numbers my car made as much as it is the shape of the graph. The car falls on it's face more than a typical Stage 2 protuned STI. It's the wastegate that is keeping me from making boost in the upper rpm's. You can hear the flutter coming from it right when boost comes on hard. Sounds like the flapper can't stay shut. Anyway I dont wanna derail this thread with my own car. If you want to check it out Shamoo I'd appreciate your feedback: My Pro-tuned results
Old 01-17-2009, 01:50 AM   #19
subaru fan
Member#: 127910
04 STI silver
wat is a good brand ewg to get and do i need a new uppipe with the ewg
Old 01-17-2009, 01:51 AM   #20
subaru fan
Member#: 127910
04 STI silver
all soo wats a good place to pp my turbo and is it possible to put a 20g part on my vf39?
upgrade form TD04 to VF39,do i have to get another inlet for vf39 or use stock one? pengmao Newbies & FAQs 14 02-07-2008 08:53 PM
WTT vf39 set up for stock VF39!!!!!!!!!! PSI_2_HIGH Private 'Wanted' Classifieds 2 07-30-2007 03:48 PM
Wtb: Ported Vf39 Or Vf39 xmystikx Private 'Wanted' Classifieds 3 08-01-2006 08:31 AM
WTT: My ported vf39 for your unported vf39! Bumsarama Mid West Subaru Owners Club Forum -- MWSOC 1 12-20-2005 08:11 AM
2005 STI VF39/STI VF39 Less than 5K $425 shipped (each) 02scooby Private 'For Sale' Classifieds 0 04-20-2005 07:00 PM
