Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 01-15-2009, 09:53 AM   #1
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
Default External w/g chattering help.
Ok before you ask i did do a search, and here is all relative info. 2006 wrx, vf39, sti topmount, hoa boost solenoid, cobb downpipe, invidia catback, cobb airbox, and the part in question grimmspeed/tial 44 ewg
Ok so i got tuned yesterday and am very happy, John at cobb is an amazing tuner and did everything i wanted to the car and it pulls very hard, on a low reading mustang dyno it put down 280 whp and 290 wtq. Also i had solid auto install the ewg and noah down there also did a very amazing job. Thanks to both of you very much! Now the question, when i start at around 2000 rpm and go full throttle i get this chatter sound from what i believe is my wastegate until i start to boost, it sounds like a paintball gun with no c02. it just makes a faint clacking sound like the piston inside the wastegate is not seating correctly. My boost does not fluctuate at all and holds very strong? also when i am approaching full boost it starts to flutter like crazy (this i believe is because my turbo is still to small and not pushing enough pressure?) so are these just the awesome sounds of a normally operating wastegate or do i need to have cobb/solid look at it? thank you for any input you guys might have!
06HAWKMAN is offline   Reply With Quote
Old 01-15-2009, 09:59 AM   #2
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
No that is not normal. It won't hurt anything but the WG is not tuned correctly. I went through this with the first few EWGs that I tuned.
I am not familiar with the HOA BCS but if it is a blocking interrupt style like the GM or Perrin, then that doesn't work well with the EWG. You would be better off using the stock bleed style and getting retuned.
Basically, the blocking style BCS uses less duty cycle to control boost and the EWG need less duty cycle also. It is very hard to tune a blocking style BCS for an EWG as a little less duty cycle, and you don't meet boost target. A little more and you get WG flutter (which is the noise you have now). It is too fine of an adjustment.
The blocking style BCS work awesome with IWG though.
blkscooby is offline   Reply With Quote
Old 01-15-2009, 10:03 AM   #3
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
that is no good man, i asked alot of people for recommendations and suggestions and this is the boost solenoid that everyone told me to run. So now i have paid and extra 100 for the solenoid and i need a retune. this is totally lame, is there any way to tune it as is?
Old 01-15-2009, 10:05 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We have interupt style solenoids on some car of our cars with EWG's and have no problems with them at all.
Old 01-15-2009, 10:07 AM   #5
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
text sent
bhhamblin is offline   Reply With Quote
Old 01-15-2009, 10:07 AM   #6
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
awesome so there is hope yet. so have you (turn in ) heard this noise i speak of?
Old 01-15-2009, 10:13 AM   #7
r8r4life
Member#: 101464
I have the same setup and have no issues with mine.Bigger turbo but same external setup.
r8r4life is offline   Reply With Quote
Old 01-15-2009, 10:14 AM   #8
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
so mr. hamblin had a good notion that it may just be the noise of the hoa, and because it is attatched to my strut frame it is loud. has anyone ever heard of this?
Old 01-15-2009, 10:15 AM   #9
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
r8r you maybe wanna take my car for a spin and see if you think its normal?
Old 01-15-2009, 10:19 AM   #10
r8r4life
Member#: 101464
Going out to miller this weekend?
Old 01-15-2009, 10:19 AM   #11
r8r4life
Member#: 101464
Originally Posted by bhhamblin View Post
text sent
Got your ricer wing on now?
Old 01-15-2009, 10:22 AM   #12
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
yeah i will be there and yeah brodacious' wing is on
Old 01-15-2009, 10:24 AM   #13
r8r4life
Member#: 101464
Come find me when you get out there and we can check it out.
Old 01-15-2009, 10:29 AM   #14
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
right on thanks! how is your car running anyway? i am gonna try and put some rubber grommets under the solenoid and see if that helps. any one else have some suggestions? r8r are you running the hoa? and if so is it bolted to the chassis?
Old 01-15-2009, 10:30 AM   #15
STIBungy
Member#: 51684
How are you vaccuum lines routed between the BCS and WG?
STIBungy is offline   Reply With Quote
Old 01-15-2009, 10:31 AM   #16
r8r4life
Member#: 101464
I am using the hoa and I bolted it to the inner fender part by the strut mount on the passenger side.
Old 01-15-2009, 10:39 AM   #17
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
stibungy, when i got to cobb john had said that the hoa vacuum lines were routed incorrectly by solid and he looked up the routing off of the interwebz and re-hooked it up properly. when i first got there my ewg wouldnt even open and it hit 25 psi but he said it was all routed correcly so i will go check after work and draw a diagram.
Old 01-15-2009, 10:43 AM   #18
r8r4life
Member#: 101464
I did the same thing when I did mine.30 lbs of boost FTW.You can always compare it to mine.When I did my tune Doug from topspeed,Christian and John got it figured out for me.
Old 01-15-2009, 10:46 AM   #19
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
YEAH BUT YOUR 30 PSI IS ALOT MORE THAN MINE! can you draw a diagram? ah this is semi frustrating. so does your(r8r) solenoid not make any noise?
Old 01-15-2009, 11:06 AM   #20
Ranatsu
Member#: 87314
2013 BRZ
Crystal Black Silica
I have a friend here in town who mounted his Perrin EBCS directly to the side of the car where the stock one is. And his sounds like a damn wood pecker going to town under the hood.. Pretty comical.
Ranatsu is offline   Reply With Quote
Old 01-15-2009, 11:08 AM   #21
r8r4life
Member#: 101464
Yea that 30 psi was not intended.My solenoid doesn't make any noise but I do have a little wastegate flutter at partial throttle when I let off.When I get home tonight I will draw out a diagram so you can match it up.
Old 01-15-2009, 11:09 AM   #22
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
That is exactly what my g/f said mine sounded like, a damned woodpecker! so if that is normal i dont care! i am trying a few things real quick! thanks for chiming in. if anyone else has expierience with this lmk, thanks!
Old 01-15-2009, 11:10 AM   #23
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
awesome thanks man! see this is why i like subies, everyone is so willing to help out! what ewg setup do you run r8r
Old 01-15-2009, 11:15 AM   #24
r8r4life
Member#: 101464
Tial 44mm to atmosphere.
Old 01-15-2009, 11:21 AM   #25
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
they sound amazing dont they
help!!! flashing cel and no one can help tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-05-2010 07:26 PM
External Waste Gate install help johnlattanzi Newbies & FAQs 23 03-17-2010 10:05 AM
External Wastegate Question plz help!!! ac23 Newbies & FAQs 1 06-08-2007 05:15 AM
97 Legacy GT AT Trans chatter, HELP? kecksubaru Transmission (AT/MT) & Driveline 1 09-27-2006 08:44 AM
How much is an external wastegate going to help? verc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-08-2005 09:38 AM
