Notices
Old 01-15-2009, 11:27 AM   #26
r8r4life
Member#: 101464
I love the sound screw rerouting it back into the exhaust.
r8r4life is offline   Reply With Quote
Old 01-15-2009, 11:38 AM   #27
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
i agree so do any tuners know if this sound should have me worried? should i not boost?
06HAWKMAN is offline   Reply With Quote
Old 01-15-2009, 12:05 PM   #28
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Originally Posted by 06HAWKMAN View Post
they sound amazing dont they
vids vids vids vids
Justin
GrimmSpeed is offline   Reply With Quote
Old 01-15-2009, 12:10 PM   #29
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
i am workin on it, trying to get the sound to match what i hear! so justin does this seem normal? no boost but while it is building it clatters like a woodpecker or paintball gun w/o co2?
Old 01-15-2009, 12:13 PM   #30
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
yeah as stated above it could either be flutter or if you have a loud solenoid it may be that as well. either way it doesnt sound like anything that would be harmful.
as for the post above about not being able to use a blocking style solenoid on an ewg, i dont believe this to be true. we've had tons of customers install these ewg's with gm/perrin/prodrive/etc BCS's and have had no issues. also we sell these ewg's to a lot of tuners and they typically are tuning them with some sort of blocking BCS. i have heard people having issues trying to run the oem bleed style solenoid with the ewgs though.
Justin
Old 01-15-2009, 12:21 PM   #31
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
awesome thank you for the help here is a craptastic vid that my lady took on her camera for now
http://www.youtube.com/watch?v=7A7W9vyw5t4
Old 01-15-2009, 12:51 PM   #32
Member#: 182795
My thought is it is the sound of the solenoid. I did not hear anything out of the ordinary while tuning. The Prodrive/HOA solenoids tend to make a ticking sound when actuating. The sound you hear while building boost is most likely the gate opening. It has a distinct sound, but I could see someone describing it as fluttering...just a really loud/mean aggressive flutter.
John
John@Cobb is offline   Reply With Quote
Old 01-15-2009, 01:13 PM   #33
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
awesome john thanks for the input! this car is mean man, thanks for taking the time to tune my car! you are the man. I will just continue to watch everything and if anything happens i will let you know. again thanks and props to you
Old 01-15-2009, 01:43 PM   #34
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
it could be 2 things.
1. your ebcs clicking and where it is installed the metal resonates the sound. If this is the case, it is fine, just a bit annoying.
2. Wastegate flutter, when you build boost in low rpm the wastegate opens and shuts to control boost so you don't overboost. This will cause a flutter (possibly wood pecker) sound. Best way to avoid this is don't do 2,500 rpm pulls, drop a gear so you rev at 4,000. This is easier on the turbo anyway.
I will see you at MMP. Debating on bringing my car. I hate you though because now I am debating on getting the EWG kit you got. WRX's with VF39's used to only make 260-264 whp on cobbs dyno, and extra 15-20 whp is a good deal for that part
Stames_wiltz is offline   Reply With Quote
Old 01-15-2009, 01:51 PM   #35
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
stames thank you for the input! also john said the dyno had been reading low as he tuned a dom3 that only made 310 whp a day or two earlier so....... i think at sea level with a dynojet i would make some pretty crazy numbers for not having crazy mods. definately get ewg it is so awesome and still good for dd imo. i cant get enough of the scream and my gas gauge shows it too. so i am going to try and relocate the bcs and see if that makes the sound less audible. In the case that is is the bcs i will not worry and just mount it back up where it was, i just want to be sure everything is working as it should. Thanks all for the input i will report back shortly with my findings. also if you can think of anything more lmk.
Old 01-15-2009, 01:57 PM   #36
Stames_wiltz
Member#: 143264
2006 WRX TR
I talked with Noah at Solid, he said that he mounted it right up without any rubber behind it. He said if you just un screw it and put something to deaden the sound you won't hear it. It is just the solenoid resonating on the metal. Everything is fine!
Old 01-15-2009, 02:01 PM   #37
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
awesome thanks man! tell noah i say hello and thanks for doing a great job on my car. I recommend them to every subie owner in utah! i will try that right now. stames what you doin tonight
Old 01-15-2009, 02:07 PM   #38
r8r4life
Member#: 101464
**** I didn't even think about it but does it sound like something is rattling under the hood like metal tapping or is it more of an air sound?
Old 01-15-2009, 02:08 PM   #39
r8r4life
Member#: 101464
Just come out saturday don't be a pussie I am taking my car out.
Old 01-15-2009, 02:12 PM   #40
Stames_wiltz
Member#: 143264
2006 WRX TR
working out at 24 hour fitness in jordan landing and then going home to hang with my wife and child. Why do you ask?
Old 01-15-2009, 02:56 PM   #41
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
sounds kind of like metal tapping. yours doin it too? stames just wanted to see if you wanted to do a mini cruise
Old 01-15-2009, 03:10 PM   #42
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
ok so i mounted some foam under it and it seemed to quite down a little. guess i wont worry bout it
Old 01-15-2009, 05:07 PM   #43
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
r8r are you hearing the click now? sorry if i made it so you could hear it this weekend should be fun, i wanna take a ride in a couple of your cars also! man turbo boxers with ewg's make some insane noises.
Old 01-15-2009, 08:45 PM   #44
Stames_wiltz
Member#: 143264
2006 WRX TR
why haven't you posted your Dyno plot on Proven power bragging yet?
Old 01-15-2009, 09:54 PM   #45
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
all in good time my camera is in my ladies car
Old 01-16-2009, 12:11 AM   #46
Super Nintendo
Member#: 73721
2007 STI
PTE 6266
Originally Posted by blkscooby View Post
No that is not normal. It won't hurt anything but the WG is not tuned correctly. I went through this with the first few EWGs that I tuned.
I am not familiar with the HOA BCS but if it is a blocking interrupt style like the GM or Perrin, then that doesn't work well with the EWG. You would be better off using the stock bleed style and getting retuned.
Basically, the blocking style BCS uses less duty cycle to control boost and the EWG need less duty cycle also. It is very hard to tune a blocking style BCS for an EWG as a little less duty cycle, and you don't meet boost target. A little more and you get WG flutter (which is the noise you have now). It is too fine of an adjustment.
The blocking style BCS work awesome with IWG though.
This is pretty terrible misinformation.
OP the sound you are hearing is your BCS clicking back and forth. Mount it with zip ties instead of a bolt and it won't be audible anymore.
Super Nintendo is offline   Reply With Quote
Old 01-16-2009, 12:51 AM   #47
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
Thanks homie! Went for a drive and can't get enough. Also it looks like Mr. John put launch control on now someone sell me a tranny!
Old 01-16-2009, 01:21 AM   #48
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
or hold off just for a little bit and we'll have the absolute best fitting/plug and play bcs option for you...that wont click!
already said to much, back to the basement i go.
Justin
Old 01-16-2009, 02:34 AM   #49
benw
Member#: 103320
1998 swapped
Forester L
Originally Posted by Turn in Concepts View Post
We have interupt style solenoids on some car of our cars with EWG's and have no problems with them at all.
seconded.
benw is offline   Reply With Quote
Old 01-16-2009, 03:38 AM   #50
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, DGM
Rotated EFR 6758
Glad to see John is still making the greater SLC area happy with supplying the horses, you guys still do the saturday cruises out there?
Krang is online now   Reply With Quote
help!!! flashing cel and no one can help tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-05-2010 07:26 PM
External Waste Gate install help johnlattanzi Newbies & FAQs 23 03-17-2010 10:05 AM
External Wastegate Question plz help!!! ac23 Newbies & FAQs 1 06-08-2007 05:15 AM
97 Legacy GT AT Trans chatter, HELP? kecksubaru Transmission (AT/MT) & Driveline 1 09-27-2006 08:44 AM
How much is an external wastegate going to help? verc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-08-2005 09:38 AM
