Old 01-15-2009, 10:03 AM   #1
97seadoospx
Member#: 197744
2009 Impreza Sport
Default 2009 Impreza OEM Subaru Remote Car Starter problems
Hi
2009 Impreza with a Subaru remote car starter installed at dealer, It's been -30 the last few days and when I tried to start the car with the remote car starter the headlights and tail lights flashed on and off 4 to 6 times with a few second in between and the car didn't ever try to turn over and then it didn't try again to start. It has done this the last few days first thing in the morning and after using the car later in the day the remote car starter works fine.
Any ideas on what is happening user error or a problem with the car?
I press the remote button twice and the car beeps twice and then should beep a third time and start but I don't get the third beep just lights flashing.
97seadoospx is offline   Reply With Quote
Old 01-15-2009, 10:51 AM   #2
RobM
Member#: 177056
2015 WRX - CVT
2009 Forester XT
With my wife's '09 Forester XT.
If you have the car plugged in, and the hood is not fully closed, the remote start will not work. This is kind of a pain, since the block-heater chord is short, and pretty much you need to keep the hood just sort of "latched" but not fully closed.
Make sure all four doors, the hatch, and the hood are fully closed, and the car is locked with the FOB.
The car sat in -30 C for about 5 days, and wasn't plugged in. I tried to remote start it. It cranked, but then fizzled out, and didn't start, (got no 3rd beep). A second attempt didn't start it either. I had to go out, key-in-ignition, and crank it about 3 times, for about 10 seconds each, before it turned over.
If the car is really cold, and it doesn't turn over right away, the remote start won't keep cranking the engine. It'll just give up.
RobM is offline   Reply With Quote
Old 01-15-2009, 11:44 AM   #3
Magic Marker
Member#: 181568
2011 3.6R Legacy LTD
Steel Silver Metallic
Damn, it's cold up there in Canada!
Magic Marker is offline   Reply With Quote
Old 01-15-2009, 12:08 PM   #4
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
2007 Legacy GT Spec-B
^ lol yup, -48 with the windchill today.
OP did you ever notice this problem when the temps weren't this bad, or is this the first this has happend?
V8Slayer is offline   Reply With Quote
Old 01-15-2009, 12:30 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
screw THAT
Old 01-15-2009, 07:46 PM   #6
08EJ25
Member#: 174022
2008 WRX
Lightning Red
Have a Compustar on my SUV and if you hit the button and it does not see 12V at the battery it will not start. I know it's not the Subie OEM one, but they could have set theirs up the same way.
08EJ25 is offline   Reply With Quote
Old 01-16-2009, 09:01 AM   #7
97seadoospx
Member#: 197744
2009 Impreza Sport
It's been -30 plus windsheld -40 in the morning the last 3 days and I do have it plugged in at night. Before i try to start the car I unlock the door and opened the car hood and unplugged the block heater cord and put the cord back inside the hood and then shut the hood. I then lock the doors and try to start the car with the remote car starter with no luck. I get 5 headlight flashes and then nothing after that so then I go in the car a manual start it. Later in the day the remote Car start works ok, this has only happened the last 3 very cold days. I have been using the remote car start for about a month with no problems befor this.
1) I'm thinking it might be a door sensor or hood sensor frozen when I open them etc.
2) A defective remote car starter or installed badly
3) There is a cold sensor and if it's too cold the car doesn't even try and start?
Old 01-16-2009, 09:42 AM   #8
3hunHP
Member#: 173473
2012 STI
Plasma Blue Pearl
3hunHP is offline   Reply With Quote
Old 01-16-2009, 07:11 PM   #9
civic_82
Member#: 189668
2007 2.5i sp ed
it's not that bad
civic_82 is offline   Reply With Quote
Old 01-16-2009, 10:43 PM   #10
SonicAZ
Member#: 200408
08 STI
Did it catch fire?
SonicAZ is offline   Reply With Quote
Old 01-16-2009, 11:01 PM   #11
Boosted WRX STi
Member#: 116731
2003 KB Cobra
Wow... -30 is wicked cold.. although I was in Montana skiing last week, and it was -25, but suprisingly it didn't feel as cold as the 10 (above 0) temps on the east coast, and I think its because the air is damper here.
At any rate, its sounds like RobM had the right idea with the remote start issues.
Hope you stay warm!
Boosted WRX STi is offline   Reply With Quote
Old 01-20-2009, 09:32 AM   #12
97seadoospx
Member#: 197744
2009 Impreza Sport
Exclamation
Well I did some testing, I opened the car door and started the car with the remote car starter (It started) so there is no sensor for the doors and then I opened the hood a crack and the car still started so I then opened the hood all the way and I get 2 fast beeps and no start. So the hood sensors and the door sensor have nothing to do with my problem.
The problem was starting the car with the remote car starter and the car didn't try to start at all what happened is five flashes of the head and tail lights.
Old 01-28-2009, 08:50 AM   #13
97seadoospx
Member#: 197744
2009 Impreza Sport
Ok so this is the latest news, the car has been starting ok for a week or so with the remote car starter and today it didn't work again. I went to start the car with the remote car starter and just got the five flashes of the head light/tail lights with no start, so I tried again right away with the remote car starter and this time the head/tail lights flashed 3 times and then the car started. So i'm thinking that the head/tail lights arn't error messages.
I don't know if this info makes any difference of trouble shooting it.
FS: (NJ) 2008-2009 Impreza OEM Subaru Floor Mats JZeezSTi Interior/Dressup/Audio & Security 8 07-03-2010 11:12 AM
remote car starter eb50 New England Impreza Club Forum -- NESIC 10 01-17-2004 10:04 PM
remote car starters batmanalan Electrical & Lighting 2 12-31-2003 08:48 PM
Remote car starters? Lou Car Audio, Video & Security 2 10-23-2002 03:08 PM
Remote car starters and the neutral switch on manual tranny. SilverSuby Car Audio, Video & Security 9 02-06-2001 11:13 AM
